Old 11-12-2017, 04:24 PM   #1
RingBredGTI
Drives: MK6 GTI
Humming sound while driving?
Hello All,
I noticed recently while driving above 30 mp/h or so there is a steady humming noise coming from somewhere. It gets louder the faster I go. I believe its from the front because when im turning right it goes away, when I turn left its sill there, it only goes away if I turn right. Does this sound like a wheel bearing issue, or maybe a issue with one of the tires?
Thank You
RingBredGTI is offline   Reply With Quote
Old 11-13-2017, 04:15 AM   #2
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Wheel bearing
2017 Passat VR6
2017 Passat R-line
Old 11-13-2017, 04:17 AM   #3
mistaleungg
Drives: GTI MK6
I got this in very occasional cases. But I can't tell which wheels it is sadly.
APR Stage 1, Michelin PSS, OZ Leggera HLT 18x8, Superpro LCA, Tyrolsport Rigid Collar, HPA 75A Puck, APR pendulum mount, 034 Motor Mount, Akrapovic Downpipe
mistaleungg is offline   Reply With Quote
Old 11-13-2017, 04:48 AM   #4
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Jack up the corner & check the wheel for play, or spin the wheel and listen to the center (with a mechanic's stethoscope) for noise
2017 Passat VR6
2017 Passat R-line
Old 01-02-2018, 03:25 AM   #5
JamieConway88
Drives: BMW
My friend's Toyota RAV4 2006 for sale he bought last year from a Japnese used car trading platform (https://carfromjapan.com/cheap-used-...-sale-year2006) also have the same problems because of the stuck tire. You should make sure that the lug nuts are tight and that the tires are not rubbing anything.
JamieConway88 is offline   Reply With Quote
Old 01-02-2018, 07:34 AM   #6
TimS
Drives: '12 Golf R
In addition to the wheel bearings, check your tires. My front right was cupped and it sounded like a bad bearing.
Old 01-04-2018, 09:42 AM   #7
Mk6Sam
Drives: '11 GTI 6MT Autobahn
THIS. I had a noise like you are describing that would come on around 20mph. I replaced my wheel bearings because I thought my noise was a failing one...
Ended up getting new wheels and tires last year and the noise went away. My 4 year old Pirelli tires, that probably weren't rotated by the PO, were the problem noise.
Put the spare tire on the side you feel is making the noise and see if it goes away after a short drive to see if you can confirm that is the issue.
Mk6Sam is offline   Reply With Quote
Old 01-04-2018, 10:11 AM   #8
riceburner
Drives: 2012 GTI DSG / K04
^kind of what i'm up against as well; i have tires with less than 20k on them but with all the rolling burnouts I've done i'm worried it slowly imbalances the wheels; sounds a lot like a wheel bearing with some of the humming i get and soft little thud-thud-thud-thud you get with that sometimes.
i gotta jack it up and investigate for wheel play; just doesn't sound like fun lol
