Old 11-13-2017, 03:14 AM   #1
Cal2000
Drives: 13' GTI 4DR AUTOBAHN
Fuse Tap for constant power (5 amp)
I need to fuse-tap for constant power (5 amp) on my 2013 GTI.
Any particular fuse that you recommend that I fuse-tap for constant power (not switched)?
Thanks!
Old 11-13-2017, 07:41 AM   #2
pdan
pdan's Avatar
Drives: 2009 VW Jetta TDI (sold), 2013 GTI
Do you really mean constant power as in always on, or ignition on only?? When I hardwired my radar detector I think I tapped into the sunroof fuse.
pdan is online now   Reply With Quote
Old 11-13-2017, 11:53 AM   #3
Orient Express
Drives: 2010 Mk6 GTI
There are several fuse positions that do not have a fuse installed, but have power. Get your volt meter out and pick one then use a fuse tap to get the power. Each year of GTI/Golf model has a different fuse layout, so you have to do some hunting.
Orient Express is offline   Reply With Quote
Old 11-13-2017, 05:30 PM   #4
Cal2000
Thanks! Yes, constant, always-on power. Itís for dashcam with parking mode.
Old 11-13-2017, 05:30 PM   #5
Cal2000
Will do. Thanks much!
Old 11-14-2017, 12:03 PM   #6
Orient Express
Here are some of the slots that I have used:
The reason that there are two fuses on these add-a-circuit taps is that one if the original fuse that was in that position, and the other is the fuse for the new application.
Old 11-14-2017, 09:47 PM   #7
Cal2000
Got it. Thanks much!
Old 11-15-2017, 12:11 PM   #8
Cal2000
Will I still need tow fuses if I'm tapping into an unused fuse slot?
Old 11-15-2017, 02:15 PM   #9
Tony48
Tony48's Avatar
No.
Here's a fuse box map. Search for a constant signal using a multimeter and install your add-a-circuit.
Old 11-15-2017, 08:52 PM   #10
Cal2000
Originally Posted by Tony48 View Post
No.
Thanks!
Old 12-26-2017, 04:36 AM   #11
Cal2000
No.
Do I need to disconnect car battery when I plug a piggyback fuse tab (5A) into a slot with constant (not switched) power?
Old 12-27-2017, 08:59 PM   #12
nockiboo
Drives: 2011 GTI Candy White 5dr
I'm also installing a dashcam as well, can you let us know which fuse slot you used for always on? Thanks!
nockiboo is offline   Reply With Quote
Old 12-27-2017, 09:25 PM   #13
B6JoeS4
B6JoeS4's Avatar
Drives: 12 CSG DSG 4D GTI
Horn is always on
APR Stg2 v2.4 || AWE intake || Cobb TBE || ARM FMIC || 034 Mounts || Depo LED's || Podi || Alzor Peelers || Eibach ProKit || R32 Brakes
B6JoeS4 is offline   Reply With Quote
Old 12-30-2017, 01:57 AM   #14
Cal2000
Mine is MY13. I checked and found that slots 22 and 33 are alway-on.
You might want to double check as VW changes fuse box config pretty much my to my. Hope it helps!
