Old 11-22-2017, 03:34 PM   #1
kram
kram's Avatar
Drives: 2010 CW GTI
Passenger wheel sticking out more than driverside after lowering.
Hi there,
Recently had Koni struts & DG springs installed. Had to do the fender screw mod due to rubbing. Had still heard a bit of rubbing on hard bumps (while turning) on the passenger side...but today realized how bad it was. The fender apparently has cut a groove into my new DWS & the fender underneath is bent to crap (no one will really see it, but I know its there).
Anyway - it appears the passenger side wheel is sticking out more than the driverside. Driverside never rubs. Is this something an alignment will take care of or do I need to mess with the subframe? I did have it aligned when the suspension was done, but maybe should have waited till it settled...
Thanks in advance for the help!
kram is offline   Reply With Quote
Old 11-22-2017, 03:36 PM   #2
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
I remember people having this issue on mk4's all the time. I don't remember what the fix for it was other than just run a spacer on the other side to make it even.
Old 11-22-2017, 03:58 PM   #3
kram
kram's Avatar
Drives: 2010 CW GTI
Yeah, I couldnt find much info that applied to MK6's... Just older gens w/ this issue.
Shouldve mentioned earlier... Not sure if it makes a difference, but the wheel bearing on passenger side was replaced about a year or so ago...
Old 11-24-2017, 04:09 AM   #4
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Roll the fenders
And I'd touch up that big chip on the fender....you don't want that to start rusting
2017 Passat VR6
2017 Passat R-line
Old 11-24-2017, 10:55 AM   #5
drval85
Make sure whoever rolls the fenders uses a heat gun. I don't think the shop that did mine used one, and now all that paint on the lip underneath is cracked and chipping.
Old 12-26-2017, 04:34 PM   #6
nvturbo
nvturbo's Avatar
That shop shouldn't be in business if they have to half-ass a simple fender roll. A good heat gun can be purchased from your local hardware store for around $20.
Old 12-26-2017, 08:50 PM   #7
drval85
I agree. And it also happens to be one of the top 3 shops that are always mentioned in the area.
Old 12-28-2017, 11:01 PM   #8
Pakman332
Pakman332's Avatar
Drives: 2010 GTI DSG
I had this issue as well, rolled fenders helped a lot. It can still rub but only if I hit a very big dip at speed or something.
Sent from my SM-N950U using Tapatalk
2010 GTI DSG
Tornado Red
| Unitronic Stage 2 | Uni Intake | Uni Turboback exhaust | ST coilovers | GFB DV+ | R8 Coilpacks | DEPO LED Tails |
Pakman332 is offline   Reply With Quote
Old 12-30-2017, 11:11 AM   #9
jay745
jay745's Avatar
Guessing one of the strut mounts is not oriented in the correct position. You got an alignment after the install correct? If not start with that.
