Old 12-01-2017, 03:08 PM   #29
lilonespaz
lilonespaz's Avatar
Originally Posted by zef View Post
Both use a spherical bearing and both are very similar in design. The largest differentiator is the ARP bolts with the ARP mount. ARP bolts are expensive, hence why the APR is more expensive. Not sure how you could otherwise come to a different conclusion.
I noticed 0 difference in NVH after replacing my dogbone with the 034 piece, and I already had VWR subframe pucks/034 mounts in place. It's a small bushing--replacing it is not going to have any huge effect on NVH regardless of what you choose.
i can see a difference just in bearing orientation.. just visual inspection one coul allow north south travel while the other could allow more east west travel.. Other then that yes they both use spherical bearings. 034 being a "Aurora Spherical Bearing " and APR being a "PTFE-lined spherical bearing". The difference between both bearing or whether they are the same i honestly cant tell you. APR comes with all 3 bolts use in replacement and they are ARP bolts. 034 only comes with 2 transmission bolts and you would need to buy a new stretch bolt for the mounting to the sub-frame.
Both are Billet Aluminum construction. 034 is T6-6061 APR does not list what class aluminum it uses.
But there are some difference the biggest being the mounting orientation of the bearing.
Old 12-02-2017, 12:19 AM   #30
zef
Point well taken, fair enough
Old 12-02-2017, 10:17 PM   #31
Roh Echt
Roh Echt's Avatar
Drives: 2007 MKV GTI
Originally Posted by GIACUser View Post
The insert is only for stock dogbone pucks which have big gaps to allow for movement and to minimize vibration (comfort over stiffness). Shoving the insert in those gaps helps minimize movement.
The 034 dogbones are solid no gaps, stiffer rubber and no place for an insert. (stiffness over comfort).
As mentioned my next upgrade will be the Motorsport engine and trans mount (Even more stiffness over comfort) along with the dogbone (pendulum) arm which contains a spherical bearing instead of something pliable. (Even more control but less comfort)
Moving a number of suspension parts from poly to spherical bearings as well all of which will contribute to NVH but improve handline and response.
I didn't know, and didn't give it enough thought that the 034 pendulum insert meant: https://store.034motorsport.com/bill...udi-tt-a3.html
I thought he was saying he pulled out the pucks, included in the 034 mount kit, in order to save his oem pendulum. So, why it seemed like a lot to do to save that oem pendulum. But still, I would've left the 034 insert in and trusted the oem pendulum.
K04 PLAY......ZOOMDIS!
`07 GTI/GIAC K04 files/AWE DV/APR HPFP/TTRS LPFP/Torqbyte PM3/S3 INJ's&fmic/RS4 fprv/FORGE fmtc,WG act.&TB HOSE/TechtonicsTuning TB/2.25" Turbo Outlet/BSH MOUNT's/NEUS. P-FLO&throttle pipe/GIAC DSG Tune/13.2BBK/W.A.L.K./H&R SS/H&R F&R-ARB's/Bilstein B8 Dampers My Dragtime link-GIAC tune2007 Volkswagen GTI : 12.823 @ 112.050 MPH
Roh Echt is offline   Reply With Quote
Old 12-02-2017, 11:20 PM   #32
FriggenT
I've simply heard of the OEM dogbone breaking several times, so I was trying to leave that area stock for now, or until I can afford the 034 or whichever
Old 12-03-2017, 08:00 AM   #33
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
The APR doggone follows the MK7 doggone engineering change. The MK6 design, in some instances either breaks or can strip the bolt out of the trans case.
APR doggone, spherical bearings pressed out, SuperPro bushings pressed in
VWR full subframe mount kit
034 street engine mount
034 street trans mount
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 12-03-2017, 09:21 AM   #34
FriggenT
I swear, this car has more sh*t to replace, it's just ridiculous.
Old 12-03-2017, 02:31 PM   #35
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
you mean there are a lot of things to upgrade?
YouTube: HYDE16
Old 12-03-2017, 04:04 PM   #36
zef
Yep it's a real weak point. Especially when people put stiff subframe pucks/inserts in and leave the dogbone stock. That's typically what does them in.
Old 12-04-2017, 09:02 AM   #37
GreyGti1990
Drives: 2011 Gti 4-door
This is me lol. Hasn't broken yet. But I've got the upper and lower VWR subframe mounts, and the street density 034 engine/tranny mounts with stock pendulum. I want the APR pendulum probably in the spring.
Old 12-04-2017, 10:21 AM   #38
FriggenT
Yes, I've known there were a lot, but it just seems like the list grows all the time. For right now, I have to solve high rpm misfires which is likely carbon needing to be clean but I just don't want to do the job.... not payingv 500.00 for it either though so no choice
Old 12-04-2017, 11:23 AM   #39
GreyGti1990
Lucky. A shop near me quoted $800+ to walnut blast and re-seal the injectors I think?
I'll need to find a more reasonable price sometime in the next year or so. My car is at 85k miles and I've owned it since 45k. I haven't done the cleaning and not sure if it has been done in the past. No misfiring issues just yet.
Old 12-04-2017, 01:25 PM   #40
FriggenT
I have a lot of 1/2 mile drives in my car, even though I've used the sprays and gotten induction cleaning done before, I'm pretty sure it might be ready to be cleaned.... I'm at 45k now. Mileage is down pretty low, feels like a miss here and there, the high rpm misfires, all point to that being a potential culprit.
Oh I've been quoted more, but a nother place said 500 to walnut blast, but idk if that included injector seals or anything.
Old 12-06-2017, 12:33 AM   #41
Chris659
Drives: 12 Beetle Turbo
Hey Ryan what’s they advantage of pressing out the spherical bearing for the SuperPro? Reduce noise?
I have same mount setup as you but with VT subframe pucks instead of VWR.
Old 12-06-2017, 08:13 AM   #42
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Spherical bearings on the street are never going to last long, I feel companies choose this option for inevitable replacement or recurring sales. With a true subframe mount solution like VWR or VT, a spherical bearing may be too much. For me, I wanted the upgraded engineering design and chose to use trusted SuperPro bushings.
YouTube: HYDE16
