Old 12-04-2017, 04:57 PM   #15
clementkk
Drives: mk6 gti
dogbone mount is on the way, yeah thats why I said tires first right after tensioner.
Current tires are Nitto motive still very new. I will use them while I save up some money for a set of pss.
clementkk is offline   Reply With Quote
Old 12-04-2017, 06:51 PM   #16
I'm running the old version 2? K04 file...there is no drop off at 4k. The guy that says a minivan will beat you to 35 is crazy. Besides the dogbone, consider the rear position lower control arm bushings, you can get them from Whiteline separately from the anit-lift kit. Really hooks up the front end.
Old 12-08-2017, 10:30 AM   #17
zef
I don't know why everyone knocks FWD for dig racing. I have zero problems with traction when launching. All you need is a LSD and sticky tires.
Old 12-16-2017, 05:08 PM   #18
Sauce118
Sauce118's Avatar
No offense at all, but on a stage 2 car, there really isn't much added hp/trq to have to worry about it. When adding an additional 50 hp to the car, an LSD and tires should be more than enough.. But once you get above 300 or even 350-500 range, it becomes very hard to put that power down from a dig. If I don't baby first and second gear I barely move. Then, I normally spin third till it hooks then I'm off. BT builds might be a little more forgiving because most custom tunes can use progressive boost maps which limits the boost in lower gears and helps traction a lot. But right now I am still k04 running the 100 oct file daily and I have a hell of a time putting my low gears down from a dig. And as you can see in signature, I have damn near every suspension mod (within reason) you can have.
Old 12-30-2017, 07:59 PM   #19
Jlove8128
Drives: UG 4 door
OP check your part number on the map sensor. If itís a 3 bar you have the new tune.
I donít have any experience with the old tune, but the new tune falls on its face when I am running through gears. When I shift from third to fourth at full throttle it dies and I have to let off for 5 seconds then can get back on it. This is maddening. One I look like I missed a gear. 2 it has made loose to cars I was walking easily.
APR KO4 v3.1/APR Mobile//APR Carbonio//Eurojet TBE// Southbend Stage 2 Endurance Clutch//Koni Coils//VMR V810 Gunmetal//Audi Flat Fives//OEM Front Lip//OEM Euro R Tails//OEM GTD Grille//S3 Short Shifter//BFI Shit Knob//P3 Analog Boost Guage//LED Footwells/Interior/Plate Lights//Color Matched Side Markers//Hatch Pop Kit//R8 Coil Packs//Vag-Com Tweeked//Soundaktor Delete
Jlove8128 is offline   Reply With Quote
Old 01-02-2018, 01:27 PM   #20
damagi123
damagi123's Avatar
Drives: 2012 GTI DSG
haha im on the 3.1 file with a WALK and just a dogbone insert and I was joking that they'll beat you to 35 because they can just floor it and get everything their vehicle has to give while im managing wheelspin.
Old 01-02-2018, 01:51 PM   #21
riceburner
Drives: 2012 GTI DSG / K04
wasnt this thread supposed to be about what cars you can beat on the street?
Old 01-07-2018, 03:38 PM   #22
SnailPower
SnailPower's Avatar
He did mention Stage 2 APR in the beginning. He probably just left the + off the end, otherwise K04 is called Stage2+.
I haven't raced jack just about since I got my k04 installed but I also haven't had much time with it before the cold weather settled in and I had to change to my winter tires. I'm also still on stock intercooler. I need to upgrade that before the summer otherwise it'll bog bad.
I'd say you will impress people on the highway when you can pull strong but it's still not the greatest drag car in the world if that is what you are looking for. GTI is good at everything but great at nothing, lol.
Internal : APR Stage 2+ tune - Soundaktor Delete - Diesel Geek Sigma 6 Short Shifter - R8 Coils - ECS Dogbone Mount Insert - GFB DV+ - NGP Type I Coilovers - KMD Tuning Front Stress Bar - WhiteLine Endlinks - IE CAI - IE K04 - EuroJet DP - Magna Flow Exhaust
External : H8 Pure Yellow Fog Bulbs - 20% All Around Tints - ECS JOM Euro Style Badgeless Grille
Old 01-07-2018, 04:25 PM   #23
Jeffs2013GTI
Jeffs2013GTI's Avatar
Drives: 2013 SB GTI
These type of posts are interesting to me to see everyone's opinions.
So much depends on your cars set up. Sure you listed your mods but there is so much more to that. Mods not done properly, like suspension work and such can actually make your car handle worse, but if this is a drag race, may not matter so much.
Most fast FWD cars I have seen have SUPER sticky tires, I mean with a DOT of 140 or less. To get traction to the ground.
If your DSG and you use LC and have sticky tires? I think you would be hard to beat, you would be consistent too.
If you come across another modded car, for example my old car was a modded Evo 9 MR. I had a 2 step launch control on it, and basically off the line? Nothing could catch me. Dont care what you drove.
So pick your battles wisely. Have fun and be safe. The GTI seems to have a good platform from what I am reading, but its still FWD and has its limitations like any car.
If your racing off a roll, then things are different. I just think that is silly racing from a roll
If you want to race, do it right, go to the track and do it. Street stuff is stupid
Jeff
