Sauce118
For those of you who have the experience and knowledge of WM Tuning...
How important is timing pull below 3k? I understand you don't want to see 12's, but realistically if I am pulling an occasional 6 between 1800 and 2800 is that really a big deal? As others have explained to me, it is an unrealistic driving condition, which makes sense. But, I was also told by some very respectable people to try and get it down to around 3-3.5 max (below 3k). My only thing is that to get it down into the 2's and 3's I have to spray A LOT of meth. I am between .6's at the IM with gain maxed and .8s at the IM at about 50% gain ( don't see any improvement below 50% w/ .8s). Now if the CF below 3k is not something to worry about, then I can literally spray a LOT less. I then can easily get by with absolutely no CF above 3k and some random pings up to 5-6 below 3k. If I have to spray the hell out of it to keep it safe, then that's what I have to do. I just feel like I am using so much meth all the time and constantly re-filling the 10L tank. I run Aquamist HFS-4 DP set to 100% BOOST PI-R and Triggers at 9psi (any lower and I spray during "normal driving"). I currently took the .8s back out to put the .6s back in to do some more troubleshooting. I started running a E30 blend, which helps A LITTLE BIT, but nothing really worth noting (maybe takes a whole CF point off each cyl; but I can tell the car likes the E30 ).
I guess my overall question is.... If its okay to pull around 6 between 1500-2800 then I can get away with spraying a lot less meth. To keep them down in the 2s and 3s I have to crank that baby up.
Also, the only CF i am getting at ALL is below 3k. I havent seen anything but 0's above 3k since I got her "dialed in". What are you guys thoughts??
