Old 12-04-2017, 09:03 AM   #1
Cbozman22
Drives: 2010 gti
2010 gti starting issues
I have a 2010 gti Iím having some issues with, it starts up for when itís freezing cold outside but when itís anythjng above 45 degrees it cranks and cranks and cranks, it always eventually starts but it takes forever. I also already tried holding the gas down and starting doesnít seem to do anything please help I have a 36hr drive home from fort bliss coming up and donít want her to crap out on me
Cbozman22 is offline   Reply With Quote
Old 12-04-2017, 10:14 AM   #2
Slowgti08
Slowgti08's Avatar
Drives: 2008 VW GTI
Dying battery?
Old 12-04-2017, 10:49 AM   #3
Cbozman22
Drives: 2010 gti
[quote=Slowgti08;2561263]Dying battery?
No turns over just fine thinking something with fuel
Old 12-04-2017, 11:25 AM   #4
tturbocar
Drives: 2012 Mk6 4Dr
any cel's? any odd noises? have you had the battery checked? any recent maintenance done?
tturbocar is offline   Reply With Quote
Old 12-04-2017, 11:39 AM   #5
Cbozman22
Drives: 2010 gti
Just changed oil havenít had battery checked but I know itís good, have 2 codes both are for o2 sensors no noises once it starts runs perfect
Old 12-04-2017, 06:22 PM   #6
Boscogn
Boscogn's Avatar
Drives: CSG 2013 GTI DSG 4DR
How old is ur battery? My money is on battery.
Edit: O2 sensors are cover under 60k emissions warranty if that still applies.
Old 12-04-2017, 06:27 PM   #7
Cbozman22
Drives: 2010 gti
Iím unsure how old the battery Iíll get the battery tested and see but it cranks over just as fast as always
Old 12-04-2017, 06:27 PM   #8
Cbozman22
Drives: 2010 gti
And it starts faster in the cold which doesnít make sense
Old 12-04-2017, 06:31 PM   #9
jettaglis
jettaglis's Avatar
It is probably bleeding off residual fuel pressure. There is a check valve within the low pressure fuel pump that hold the fuel in the lines/ fuel rail. If the valve fails the fuel back flows into the tank- then you need to crank the vehicle a while to get the fuel back up to the engine. My $ is on the in-tank pump, if we are guessing.
Uni stage 3....gt3076
Instagram: vsc_tuning
Old 12-04-2017, 06:33 PM   #10
Cbozman22
Drives: 2010 gti
Thatís what I was thinking but I also tried priming it a few times before starting still doesnít help
Old 12-04-2017, 06:37 PM   #11
Boscogn
Boscogn's Avatar
If you have one of those jump packs just make sure car is starting slow then slap it on and see if it starts right up. I don't get how fuel would be affected based on temps? Doesn't hurt to check it out though.
Old 12-04-2017, 06:39 PM   #12
Cbozman22
Drives: 2010 gti
It starts perfect when itís freezing outside but if itís warm outside it doesnít want to start was hoping someone has seen this before
Old 12-04-2017, 06:44 PM   #13
Boscogn
Boscogn's Avatar
I had opposite problem would bitch and moan on cold mornings and would then start right up after it warmed up. Then it died and I replaced the battery all good.
Old 12-04-2017, 06:45 PM   #14
Cbozman22
Drives: 2010 gti
Was also thinking maybe the fuel filter could be the issue
