Old 12-06-2017, 09:35 AM   #15
Doesn't the door skin just unbolt and give you access to everything?? Might want to try that before touching the interior.
Old 12-06-2017, 10:46 AM   #16
JSwag420
JSwag420's Avatar
Drives: '12 CSG DSG GTI
Door skin? Isn't that the inside of the door panel? I've heard that it's the biggest nightmare to remove and you'll end up breaking clips 90% of the time.
JSwag420 is online now   Reply With Quote
Old 12-06-2017, 03:06 PM   #17
No, the door skin is the metal exterior. I believe it unbolts pretty easily, then everything is exposed.
Old 12-06-2017, 03:15 PM   #18
JSwag420
JSwag420's Avatar
Interesting. I'll look into that.
Old 12-06-2017, 03:17 PM   #19
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Doesn't that black piece behind the door skin have to be riveted out?
Old 12-06-2017, 04:00 PM   #20
gijoewoz
Drives: 2005 Impreza RS
I'm assuming all MK6 GTIs are the same with regard to the doors/windows, and if so the black panel is secured with rivets (one very stupid thing about an otherwise pretty clever car) that need to be drilled out. The proper sized rivets are tricky to find and require a bigger rivet gun than normal, so keep that in mind BEFORE you drill out the old rivets. I believe on the MK5 you could simply unbolt the door skin, not the MK6.
Old 12-06-2017, 05:30 PM   #21
Guess I was thinking of my MK5...I assumed the feature carried over, but I could be wrong.
Old 12-06-2017, 06:04 PM   #22
Blakcard
Blakcard's Avatar
My car had about 200K on it at the time so not sure if I would have been able to call if defective on their part? Its seen its fair share of Tim's drive through windows
Old 12-06-2017, 06:42 PM   #23
JSwag420
JSwag420's Avatar
50k here. My friend had it happen at 15k and replaced under warranty ofc no questions asked because it's a known problem. For me though, $700!
Old 12-07-2017, 12:52 AM   #24
marksix
Drives: 2.5 MK6
Had the same problem on my 2.5. Took it to my mech, he took off the trim molding and cleaned the window track properly.
It doesn't happen anymore.
marksix is offline   Reply With Quote
Old 12-07-2017, 01:12 AM   #25
mataempat
Drives: Golf Mk6 1.4 TSI 160
Had the same problem. Took off the inner door skin after removal of the glass. Lube everything that can move including the glass carrier and track. Squealing came back after few months.
It turned out to be misaligned window track. Had to change the entire inner skin because the tracks are riveted to it. Also noticed some crimping on the regulator cable. All good now.
mataempat is offline   Reply With Quote
Old 12-07-2017, 09:08 AM   #26
JSwag420
JSwag420's Avatar
Mine is as clean as it can possibly get without removing anything. Did he have to remove the entire door panel I'm assuming to remove the trim molding?
Old 12-07-2017, 09:13 AM   #27
JSwag420
JSwag420's Avatar
That's what I'm thinking it is along with a regulator cable going. I'm sure I could silence it if I could get access to behind that panel. Any tips on removing it? I know people say it's an absolute nightmare.
When I try to lube things w/ the window down it just makes a mess and hardly covers anywhere. It's amazing to see how many others have this problem.
Old 12-07-2017, 10:12 AM   #28
mataempat
Door card removal was pretty straight forward. Expect to replace few clips. Quite cheap at the dealer.
To remove the glass itself, you should follow this guide here http://workshop-manuals.com/volkswag...ndow/removing/
It's a bit tricky to pull the plastic rivets out. On the reinstall, make sure the rubber seal is properly seated against the metal sheet. It's not advisable to put any adhesive around it as that can change the inner door pressure. Side crash sensor depends on it for proper operation.
