Old 12-06-2017, 01:52 PM   #1
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Dyno sheet thread
When reading through material and different tunes, stages, etc I think it would be nice if we had a repository of mods and dyno sheets for people to reference. Especially since custom tunes are becoming more popular now. Maybe we can do it like this format.
Tuner:
Turbo stage or setup:
Additional bolt ons:
Fueling:
Dyno information: i.e. temp, type, correction if any
For example mine
Tuner: Eurodyne custom file
Turbo: Port and polish k04
Bolts ons: stage 2 intake, apr intercooler, charge n discharge pipes, turbo back, dv+, fluidampr
Fueling: pump 93 gas
Dyno information: 4th gear 78F michigan, dynojet I believe STD 1.03
Old 12-06-2017, 01:53 PM   #2
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Reserve for cleanups and edits and table of contents
Old 12-06-2017, 01:58 PM   #3
Mk6 Steve
Drives: 2013 Black GTI coupe DSG
Tuner?
APR V3.1, APR K04, Carbonio Stg 1 + 2 w/ AEM dry-flo filter, APR RSC TBE, Do88 Ic, 034 Catch Can Kit (summer), OEM pcv "AH" (winter) AWE S3 top, Neuspeed charge pipe, Rev D, R8 coils w/ NGK 2668, 034 motor/trans mounts, HPA 75A, TyrolSport subframe and brake stiffening kit, Unibrace UB, F+R Centric w/ StopTech Strt pads, USP SS brake lines, Depo dark cherry tails, ECS Blind Spot Mirrors, Enkei 18x8 black M52 w/ Conti DWS, Soundaktor delete, VCDS Hex-Can, P3 gauge
Mk6 Steve is offline   Reply With Quote
Old 12-06-2017, 02:12 PM   #4
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Originally Posted by Mk6 Steve View Post
Tuner?
Added that line. Good point
Old 12-06-2017, 04:17 PM   #5
zef
Should also mention UNCORRECTED, SAE or STD
Old 12-06-2017, 08:57 PM   #6
MmmmmBoost
Drives: 2013 GTI MK6
Unitronic
Stage 2 (93 File)
Intake, Downpipe, gfb DV+ at the time.
Fueling: Chevron 92
Dyno information: 4th Gear, Dynocom (Similar to a heart breaker), std j607.
MmmmmBoost is offline   Reply With Quote
Old 12-09-2017, 01:02 AM   #7
ChefT
Drives: '11 Steel Gray GTI; APR Stage 2
Great idea for a thread, OP. Now letís get some apt tunes in here. Curious to see what my Stage 2+ should be making to the wheels.
ChefT is offline   Reply With Quote
