Old 12-07-2017, 05:09 PM   #1
cchase__
Drives: Shadow Blue Metallic MK6 GTI 2 Door
Horn not working from removing air bag
I am so very confused as to what happened..
My motive initially was to remove the multi function control trim to either wrap it or to replace it (now i want to replace it with the black golf R one).
I will explain what happened.
I did not disconnect the battery (if this matters)
I then pried at the little clips in the back of the steering wheel then took off the air bag
Without disconnecting the airbag cables i removed the trim
i didn't end up wrapping the trim so i put it back on
then i put the air bag back on
Next thing i know is the horn doesn't work??
Is it possible i installed it back wrong?
The paddle sifters, controls, and lights still work.
Also there is no "click" when pressed.
Please help, it's very annoying because it doesn't make sense!
cchase__ is offline   Reply With Quote
Old 12-08-2017, 01:44 PM   #2
cchase__
Did i really kill the clock spring for removing it?
Old 12-08-2017, 05:28 PM   #3
1ashchuckton
1ashchuckton's Avatar
Have you checked for blown fuses?
Old 12-08-2017, 08:39 PM   #4
TALON AE
Drives: 2011 CSG GTI - 4dr, DSG
Iíve had this happen twice...both easily remedied.
First time, I just didnít have the airbag assembly seated properly when reinstalling. I gave it a good shove and the rubber bumpers on the underside of the assembly seated more fully...problem solved.
Second time was a little more tricky and took me longer to figure out. When I had removed the airbag assembly it came loose a little easier than I expected and I ended up yanking on the harness when it came away. I didnít realize at the time, but that yank had unseated the harness from the horn contact mechanism. There is a metal hoop that goes around the circumference of the airbag assembly. When you depress the center hub, one of 4 contacts make a connection with this hoop and completes a circuit to sound the horn. There is a pressure-fit connection at one end of that hoop where the harness ties in. I found the connector hanging from the harness. All I had to do was press that connector over the end of the hoop and, voila, all fixed.
Hopefully thatís all you did.
Good luck!
TALON AE is offline   Reply With Quote
Old 12-08-2017, 08:49 PM   #5
TALON AE
Not my picture, but check this connector.
Old 12-09-2017, 12:45 AM   #6
cchase__
OHH thank you! i saw that thing unplugged and i didn't know what it was!
