Old 12-08-2017, 04:38 PM   #1
jkhania
Drives: 2010 White GTI
Headunit replace w/ carplay
I wanted put out some feelers to see who's updated their headunits to headunits with Apple Carplay.
I was hoping to hear model specific feedback. I was hoping to retain the functionality of the steering wheel buttons and the internal mic.
jkhania is offline   Reply With Quote
Old 12-11-2017, 01:03 PM   #2
gijoewoz
Drives: 2005 Impreza RS
Mobile audio has been a HUGE hobby of mine for about 10 years. I bought my MK6 in June, and a new stereo was the first thing that the GTI needed. I went through A nice Pioneer (brand loyalty from having used their active capable head units exclusively for years) and a Kenwood double din, but pulled them and put the OEM unit back in.
My car came with the RCD 310, and it's not that great. It distorts at 21 on the volume knob, the ipod interface is mediocre, and the features are limited, however neither aftermarket unit was good enough either. On both the Pioneer and Kenwood I had issues with Carplay (and just about every other feature). Sometimes my phone would connect, other times it wouldn't. Both unit would freeze periodically, both had screens that were far too busy and unintuitive, and I had issues with glare and polarized sun glasses hiding the screen. In the end I decided I'd rather have a free mediocre head unit than an $800 mediocre head unit.
If you use idatalink you can keep steering wheel controls and all of the other features, however, there is a catch. The OEM mic will still work, and the MDI plug will still work, but if you want to use Carplay you must run the mic from the new head unit, and if you want album info to display correctly, you must run a new USB cable. I was under the impression that since I was using the idatalink maestro that I wouldn't need to run a mic or cable, but I was wrong.
I'm in a tough spot because mobile audio is important to me, but besides the Pioneer P99 (only single din, and not super modern features) there isn't an aftermarked head unit that I'd use. I'm going to end up running a RCD 510 to a DSP to fix the sound, but that won't help with Carplay. For me that isn't an issue, I don't really want my phone tied to the car anyway, but I can see how my solution won't work for most people.
I suggest that if you decide to use idatalink with an aftermarket stereo that has Carplay to look at Kenwood. I prefer Pioneer for sound quality, but the Kenwoods will integrate better.
Old 12-11-2017, 01:31 PM   #3
zef
I just installed a Kenwood unit yesterday. Crutchfield gave me an adapter to allow me to retain steering wheel controls (along with all the other hardware/adapters/harnesses needed). I am using Android Auto which I am guessing is similar, but I did not need a new USB cable. The overall install process was relatively painless.
Old 12-11-2017, 01:50 PM   #4
gijoewoz
With my ipod/ipone, I could use the OEM MDI plug to connect to the Kenwood head unit, but it would not display album art, and maybe not even track info ( I don't remember). I had to run the included USB cable to the back of the Kenwood in order for everything to work as intended.
Old 12-11-2017, 10:26 PM   #5
DSGVW
DSGVW's Avatar
Drives: 2012 CSG GTI DSG
Have this, rock it daily. Perfect OEM CarPlay replacement and plug and play since OEM.
Donít look back, itís as awesome as the thread depicts. Iíve had 5-6 different OEM and aftermarket radios in my MK6 and this one is FINALLY a keeper.
RCD330
http://www.golfmk6.com/forums/showthread.php?t=110801
Old 12-12-2017, 11:51 AM   #6
gijoewoz
RCD330
I am suspicious of this head unit. It's a long thread, so I haven't read through it all, but has anyone bench tested the RCD330 to see what kind of signal it puts out? Anyone know what DACs are used, where it clips, etc.?
Old 12-26-2017, 06:37 PM   #7
jkhania
Gijoewoz - thanks for the feedback. I was afraid that many of the adapters would have unforeseen restrictions. I too am hesitant to spend hundred of dollars only to trade one minor inconvenience for another.
Don’t look back, it’s as awesome as the thread depicts. I’ve had 5-6 different OEM and aftermarket radios in my MK6 and this one is FINALLY a keeper.
RCD330
Where did you find your and did you do the install?
Old 12-26-2017, 06:41 PM   #8
jkhania
Zef - can you provide the model or link?
Old 12-26-2017, 08:20 PM   #9
Cadubya
DUBYA
Cadubya's Avatar
Drives: 2011 K04 GTI 4DR 6MT
I just got a pioneer AVH-2230NEX with idatalink maestro and sxm
CLICK HERE FOR MY BUILD
Old 12-27-2017, 12:14 PM   #10
gijoewoz
Make sure that you run the included mic, and USB cable. The idatalink won't give you everything that you need.
Old 12-27-2017, 03:13 PM   #11
Cadubya
DUBYA
Cadubya's Avatar
Word thanks for the reminder.
Old 12-27-2017, 04:28 PM   #12
gijoewoz
Sure, the idatalink will keep the OEM mic and USB, but those will have limited functionality, so if you want everything with the Pioneer to work as intended, you'll need the Pioneer mic and usb, a little irritating since I suspected the idatalink would take care of that without issue, but not quite.
Old 12-27-2017, 07:55 PM   #13
Cadubya
DUBYA
Cadubya's Avatar
What functionality will be limited?
Old 12-28-2017, 01:07 PM   #14
gijoewoz
If I remember correctly you cannot use Carplay without the Pioneer mic (the Siri features won't work through the VW mic). Without the Pioneer USB cable you can still play audio, but you won't get track information unless you use the Pioneer USB cable, so basically, even though idatalink keeps the OEM USB (MDI) you won't ever want to use it. I had hoped that idatalink would make it so I didn't need to run excess wires, but I ended up needing to run the mic and USB anyway, which was a bit disappointing.
2010, apple, carplay. gti, headunit, radio
