Old 12-09-2017, 07:04 AM   #1
clementkk
Drives: mk6 gti
Ko4 fuel consumption
Ko4 and full Stage 2+set up.
Intercooler, DP, KN FILTER, tires set at 38psi.
MT
Even when driving conservatively I still only get about 22mpg half and half city and highway. 15mins trip Includes 8mins of highway and regular streets in the south bay area.
What are the possible cause of such low mpg ?
I think 26-28 combined is a more reasonable mpg range .
14 gallons fill up sometimes only run me 280 miles.
Currently thinking about an updated ko4 tune , new spark plugs , MAF sensor cleaning , and maybe a new set of PSS tires .
What else could effect mpg ? I know driving style is a big part, but even if I drive like a granny , still the same .
Could it be the injectors? Carbon build up on Intake valves ?
clementkk is offline   Reply With Quote
Old 12-09-2017, 12:07 PM   #2
What tune do you have? Do you normally drive like a granny?? Might try some hard driving for 30 min (3k rpm or higher) aka the Italian tune up. Burn off that carbon. I average 30mpg with K04, mixed driving.
Old 12-09-2017, 02:17 PM   #3
Mk6 Steve
Drives: 2013 Black GTI coupe DSG
I would get under the car and begin looking for boost leaks if your maintenance is on point. It wouldn't hurt to change the plugs and gap them to your tuners specs.
APR V3.1, APR K04, Carbonio Stg 1 + 2 w/ AEM dry-flo filter, APR RSC TBE, Do88 Ic, 034 Catch Can Kit (summer), OEM pcv "AH" (winter) AWE S3 top, Neuspeed charge pipe, Rev D, R8 coils w/ NGK 2668, 034 motor/trans mounts, HPA 75A, TyrolSport subframe and brake stiffening kit, Unibrace UB, F+R Centric w/ StopTech Strt pads, USP SS brake lines, Depo dark cherry tails, ECS Blind Spot Mirrors, Enkei 18x8 black M52 w/ Conti DWS, Soundaktor delete, VCDS Hex-Can, P3 gauge
Mk6 Steve is offline   Reply With Quote
Old 12-09-2017, 02:43 PM   #4
clementkk
Drives: mk6 gti
Boost leaks is possible, getting the DV+ installed soon and check for Boost leaks.
I sometimes can hear some compression surge at lower rpms like 3/4k, not very loud and noticeable, dont know why but will check for it.
I normally get back from night shift at 2a.m. so highway is all mine. Italian tune all the way home
Tune is apr ko4 tune, but the old version
Carbon buildup inside the cylinder is not really a big problem because I either drive it hard or use some fuel additives. Its the Intake valves carbon I am worried about , the car does not have a catch can
Old 12-09-2017, 03:11 PM   #5
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Yeah I think you should at least hit 300mpg. I was doing log revisions on e30 k04 and still hit 320 to the tank, so I feel like 300 is a good minimum unless you drive like an ahole all the time lol.
Basic maintenance items first, spark plugs, filters (air and fuel), boost leaks. If you have a boost gauge or log ability you could always log and make sure you are hitting target numbers.
Also remember winter blend gas around this time of year may play a small role.
brobst is online now   Reply With Quote
Old 12-09-2017, 03:39 PM   #6
Gino
Drives: 2012 CSG GTI
Haven't really gauged my Stratified tune MPG. When I had Unitronic K04 tune, I would get 20-24 mpg city. Coasting on the free way 30+ mpg. I drive 80mph the whole time on freeway when I can. 14 gallon fill ups and when in the red every time, would get 300-320 miles. I got a 01 TDI now so I can have a better mpg car.
Stratified Ported&Polished APR K04 | Dual Nozzle SnowPerformance W/M | MFactory LSD | IntegratedEngineering CAI | BillyBoat TBE | Neuspeed Discharge/Charge/FMIC/IC Delete..FSB/RSB..RSe11 w/Michelin PSS | 034 Motor/Trans/Dogbone Intsert+Mount | ECS CatchCan/BoostTap | Koni Coilovers (WestEnd Corner Balance) | Unibrace XB/UB | Whiteline F/R Endlinks | Brembo 17z/Hawk Street/StainlessLines | TyrolSport SLC | OEM LED Tails [Click4List]
Gino is online now   Reply With Quote
Old 12-09-2017, 05:08 PM   #7
clementkk
Drives: mk6 gti
Tune plays a role but I mean come on my 01 2.0 NA mk4 golf has the same mpg
Old 12-09-2017, 05:37 PM   #8
brobst
brobst's Avatar
Drives: CSG mk6 6MT
I'm thinking the apr tune can at least mpg 300mpg total. Thats really only like 21-22 mpg
Old 12-09-2017, 09:57 PM   #9
Might try gapping the plugs and torquing them in, could be loose.
Old 12-09-2017, 10:35 PM   #10
BudgetPhoenix
Drives: 09 GLI
320 miles to tank IS like 23mpg. So not much better really
Old 12-09-2017, 11:28 PM   #11
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Thats my point, its a baseline. I'm usually 400 on pump gas
Old 12-11-2017, 09:54 AM   #12
GreyGti1990
Drives: 2011 Gti 4-door
Yea I average 28-30 mpg all day long and i'm stock turbo... unless stuck in traffic on the highway. If you have never had your carbon cleaning done... it could be that; i hear carbon buildup can decrease MPG's.
But if not carbon build up then yea, check for boost leaks, replace sparkplugs (gapped correctly) and replace coilpacks. Fuel filter is a good idea too. Clean MAF and intake cone filter. After that... it should all be on your right foot for mpg's.
Old 12-27-2017, 06:08 PM   #13
adema69
Drives: mk6 gti
Thats the mpg I get when I'm on an ethanol blend (e40). I average 19-21mpg and on 93 28-30 driving normal.
adema69 is offline   Reply With Quote
Old 12-27-2017, 08:05 PM   #14
jay745
jay745's Avatar
I get about 250 miles to a tank. I didn't spend that kind of money to do any of this "normal driving" business other people are talking about though either
