#1 |
![]() Drives: 2011 Golf GTI Join Date: Sep 2017
Fog Light Voltage with LED's
I'm struggling a bit with the CANBUS system. I've got the fog lights set up to run at the same time as the DRLs. I'm wanting to replace the fog lights with LED's, but because the fog lights when used with DRLs run at a lower voltage (they're dimmer), the load resistors I purchased don't seem to work as they require 12v.
If I put the LED fog lights in without the resistors, they work and will dim, but they generate a bulb out warning. Any ideas? What setup will work so I can use LED fog lights as DRLs without getting a bulb out warning? Any ideas if the deAuto LEDs work at lower voltages without generating bulb out warnings too? Cheers! |
Display Modes | |
