Old 12-14-2017, 05:14 PM   #29
Sniper260687
Drives: GTI
Originally Posted by Rickybobbi View Post
I wonder if its a US thing only but here in Canada I have never seen a GTI with halogens, only 2.5's have em and only the GTI's and R's have the projectors.
Conrats on the car BTW
Oh you know how the USA is....no one knows either why we need those idiotic ugly pointless orange side markers.
Thank you!
First day so far so good
Sniper260687 is offline   Reply With Quote
Old 12-17-2017, 04:40 PM   #30
CHACwave
Drives: GTI 2010 MK6
Originally Posted by Sniper260687 View Post
Cool good to know.
BTW
What do you guys think of these lights?
and what bulbs do i need?
The descriptions claims not to come with any HID....lol
https://www.ebay.com/itm/172192673243
I love them ... I got them ... they are plug and play with bulbs in them already ... easy installation as well ... needed to remove front bumper
Sent from my SM-G955U using Tapatalk
CHACwave is offline   Reply With Quote
Old 12-17-2017, 05:13 PM   #31
Sniper260687
Drives: GTI
The description says no low beam lights included?
Old 12-17-2017, 05:15 PM   #32
Carlosfandango
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
Those lights are crap! Donít buy them!
Old 12-17-2017, 05:18 PM   #33
CHACwave
I bought mine with bulbs for that price and have had them for over 1 year ... no issues ... am pleased with my purchase AND they look good ... that's my experience
Old 12-17-2017, 05:20 PM   #34
Carlosfandango
Thatís true, they do look good!
Old 12-17-2017, 05:36 PM   #35
Carlosfandango
Iím kidding! Theyíre crap!! Before I retrofitted genuine xenons with AFS I searched many threads etc and these lights were failing all over! I mean , look at the wiring for a start! The led controllers were overheating on the majority of them and melting the housing too! I then decided to go with the OEM reps which are built a bit better than these but they didnít last either! The quality control is just non existent so they just fall apart! Save yourself the hassle, time and money (in the long run) and buy genuine or for easy plug and play get the osram lights, Iíve seen no reports of problems with them at all! But Iím personally glad I fitted the genuine ones as the AFS is excellent, Iíve got all the info for coding and fitting if you go the genuine route, youíll need to do the byte 18 coding for the rears too unless you get reps with a shitty code box.
Old 12-30-2017, 09:42 PM   #36
Sniper260687
Drives: GTI
So i installed the lights today, pretty easy job considering there was no panel underneath.... kinda pissed.
Then i saw, should i be concerned? It is fresh however i do not see any stains on my garage.
IMG_20171230_182238 by sniper260687, on Flickr
IMG_20171230_182247 by sniper260687, on Flickr
2017-12-30_07-19-12 by sniper260687, on Flickr
Oh yeah the lights. Pretty happy with the lights, yet there is a disgusting huge gap under, between the lights and the bumper.....
IMG_20171230_191703 by sniper260687, on Flickr
IMG_20171230_191658 by sniper260687, on Flickr
Old 12-30-2017, 11:31 PM   #37
Carlosfandango
Buying a used 2010 GTI, questions and concerns.
That gap is probably from them just not being seated properly, itís quite common to think theyíre home (OEM or aftermarket) but in fact they either havenít slotted into the tray underneath or theyíre sitting above the little pin that should poke through the hole at the base of the lens, either way they feel like theyíre in properly when you do it! Have another play with them! Youíll know when it finally slots in right!
The OEM ones do simply fit better though! Thatís just how it is! These will likely fit in properly but you just have to mess with them whereas the OEM HELLA ones just drop in without any drama, as would your halogens if you were to put them back on.
Old 12-30-2017, 11:47 PM   #38
Carlosfandango
Check the areas above the oil that is around the lip of the pan as it could be coming from around the turbo, I canít remember off hand the exact cause if that is the case! It could equally be the oil pan gasket or that bolt just not done up tight but itís hard to say from just pictures, a new sump plug should sort the other oil patch, Or it could just be a bit loose!
Old 12-31-2017, 04:04 PM   #39
Sniper260687
Drives: GTI
Well i had to align the red lines with the grill, so i cant move them much
Old 12-31-2017, 04:49 PM   #40
Carlosfandango
The red shouldnít go out of line as they will sort of rotate rather than drop, they need to be seated properly or theyíll vibrate like mad which will be visible at the cut off of the beam over bumps etc!
Old 12-31-2017, 10:57 PM   #41
Blakcard
Blakcard's Avatar
[QUOTE
Currently i have a 17 Audi TTS.
Yes,my GF is aware i dont wanna get marry [/b]
2017-12-11_08-03-57 by sniper260687, on Flickr
[/quote]
Duuuuuuuuuude, that plate is priceless!!!!
Congrats on the purchase man. I see the bug has already bit. Have you done any mods on the TT? Get good plugs and R8 coils, check the pcv, and I think someone has already said to check the tensioner... don't sleep on that one.
Old 12-31-2017, 11:21 PM   #42
Sniper260687
Drives: GTI
[QUOTE
Congrats on the purchase man. I see the bug has already bit. Have you done any mods on the TT? Get good plugs and R8 coils, check the pcv, and I think someone has already said to check the tensioner... don't sleep on that one.[/quote]
Thanks boss!
Oh yeah the TTS is heavily modified pushing 400 to the wheels, basically stock TTRS numbers.
One of the reason why i got the GTI, the TTS got really uncomfortable being a daily.
I checked the tensioner looks good lol but idk how to look and see if is in good conditions
