Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - > Volkswagen GTI / Golf Topics > VW Golf R Forum
Old 12-20-2017, 04:01 PM   #1
Drives: 2013 Golf R 4 Door
Rough Idle / Engine Shake
Hello Everybody,
I've read some other forums mostly AU and EU about rough idle/shaking issues, just wanted to hit up this community, see if anyone else has/had this issue and what the culprit might be in my case.
Ive had this problem for quite some time now, and at 1st it was avoidable - within normal-ish - behavior, however it has recently escalated to something that requires more immediate attention.
When I start the car the engine feels great, -runs smooth, revs clean- for the first 1/2 second, and then devolves into a shaking mess. This is at its worst on a cold start, it shakes horribly until the engine reaches whatever temp that the RPM's drop to about ~750 at which point it still shakes, but at like 30% of inital -yet still highly noticeable- especially when looking at the passenger seat/steering wheel.
The car is pretty stock, i have a K&N, some R8 coils and new NGK spark plugs - the plugs ive changed twice thinking they were the issue.
The car throws no codes. Really doesn't feel like a misfire, the engine mounts are all good - the clutch is do for a replacement but idk how/if that would be related. I only mention the clutch because gear switching has become stiff, and i know the mk6 R was not known for a robust clutch - also looking for a clutch make/model suggestion from those of you with experience, and could the stiff shifting be a synchro issue, are those a per-gear thing or is there just one, can it be swapped out during the clutch job?
Any info would be greatly appreciated!
TLDR:Car shakes at idle like a terrified crack-head going through withdrawls -anyone else? Potential culprits?
Aside: No issues when at higher speeds/gears no shaking issues with acceleration fuel economy etc.
#madrussian is offline   Reply With Quote
Old 12-20-2017, 04:13 PM   #2
sterkrazzy's Avatar
Drives: mk6 gti
I could be wrong here, but generally it seems like when you have an issue like this and your first guess is it's a coilpack/plug or a vacuum leak, but you know that's not the issue (or you don't have any codes) it usually ends up being a carbon build up issue and it's time to get your valves cleaned.
Old 12-20-2017, 04:16 PM   #3
brobst's Avatar
Drives: CSG mk6 6MT
Yeah we would like to see mileage on car
Old 12-20-2017, 05:07 PM   #4
car just rolled over to 72k mi. I thought it might be carbon but don't really know how to check that for sure. I'm sure any shop i take it to will just say 'yup, you need them cleaned'
Old 12-20-2017, 06:04 PM   #5
Drives: MK6 Golf R
Check the maf sensor. Easy way is while the car is off just unplug it and start and run the car normally and see if the issue persists if it doesnt you may need to clean or swap it out. Also check for carbon buildup too
Mk6 Golf R | APR Stage 2+
joeyfrost is offline   Reply With Quote
Old 12-20-2017, 06:40 PM   #6
Ah yes the MAF, taken it out, put it in, replaced it with a new one, no difference, ended up returning the OEM replacement i bought after it didn't solve the issue. the check engine light came on, so it registered that it was missing, but thats about it. anyone have a clutch suggestion for me? I need to order the part soon.
clutch, golf 6 r, shaking
