Old 02-05-2018, 12:53 AM   #43
KFahey
KFahey's Avatar
Drives: 2011 MK6 GTI-MT
Originally Posted by Yadadameans View Post
I am not sure since I didn't get a Forge WG. But from the looks of it, that one looks like its correct for the K04
Yadadameans, have you boost leak tested your setup? I have the same hybrid k04 as you from HPA.
Sent from my SM-G935V using Tapatalk
APR K04 V3.1 | Unitronic CAI | CTS TBE | NewSouth Boost Gauge | R8 Coils | RSR Clutch Kit | OEM LED Tails | VWR Springs | KONI Yellow Front Struts | GFB DV+ | CTS Intercooler | 034 Street Mounts
KFahey is offline   Reply With Quote
Old 02-05-2018, 01:17 PM   #44
redubbed
Forge got back to me today. The Wastegate Actuator for a K04 on a TSI (CBFA or CCTA) is the one I posted earlier. I asked about a DIY & the salesman explained that (as I've been reading) that it's pretty straightforward.
He said to install it with the flap closed, then preload it 3-4 threads. I also inquired about which spring to use & he siad the Yellow spring that's included if perfect for a tuned, K04 TSI (UM, APR, etc.) at 20-24lbs.
I've ordered one & will post a DIY once I get it.
redubbed is offline   Reply With Quote
Old 02-05-2018, 03:04 PM   #45
Yadadameans
Yadadameans's Avatar
Drives: CSG GTI
I have not.
Yadadameans is offline   Reply With Quote
Old 02-06-2018, 10:24 AM   #46
OhioMK6
OhioMK6's Avatar
Drives: 2012 CSG GTI - 2DR Manual
I also have a Forge wastegate actuator that I'm putting on my OEM Borg Warner K04-64 that I'm modifying to fit. Thanks for posting about the recommended pre-load from Forge. I'm also going to ask Stratified how much preload they want me to put on it since they have tuned with the actuator before.
2012 CSG Manual
Borg Warner K04 | Stratified Protune | SouthBend Stage 2 Daily Clutch | ECS Tuning Intake - SPM Downpipe - Corsa RSC Catback - GFB DV+ - Audi R8 Coils + NGK IX Plugs - Koni Coilovers - 3SDM 0.06 Wheels - Hankook Evo V12 - HAWK HPS 5.0 Pads - ECS Tuning SS Brake Lines - Ziza Golf R Tails - ECS Tuning Street Shield - Eonon GA5153f Android Headunit
OhioMK6 is offline   Reply With Quote
Old 02-09-2018, 10:34 PM   #47
Yadadameans
Drives: CSG GTI
I suggest you guys changing out the DV on the HPA to the Oem Rev D one. The one on the HPA isn't as great and it's like a knock off even though it's still a piston design.
Old 02-10-2018, 12:10 PM   #48
KFahey
KFahey's Avatar
I'm running the actuator they supplied with gfb dv+, works well
Old 02-10-2018, 05:59 PM   #49
Yadadameans
Drives: CSG GTI
The actuator it comes with is actually really weak, but if yours works fine then that's good. I replaced mine with a kinugawa actuator and you can feel how much stiffer it is than the one HPA provided
Old 02-10-2018, 06:02 PM   #50
KFahey
KFahey's Avatar
I actually meant the diverter valve solenoid/actuator ....running their stock wastegate as well don't seem to have any issues at all....just a boost leak with their shitty machined parts
Old 02-10-2018, 11:47 PM   #51
Chris659
Drives: 12 Beetle Turbo
I run a Turbosmart plumb back on mine with no complaints. I agree the one they supply you with is a cheap knockoff
Old 02-12-2018, 10:50 PM   #52
clarxion
Drives: Golf GTI Mk6
This is correct. 3 HPA turbos DV already failed only 2 months. I managed group buy for my customers. And 3 of them already stuck and throw error code on DV.
Replace it using D, and working well now.
clarxion is offline   Reply With Quote
