Old 12-28-2017, 11:24 PM   #1
darkGTI
Drives: VW GTI MK6
"Please check tires" light always on
So just recently I got this light that says "please check tires", and it's always on. I've tried putting more air, but all wheels are at 38 PSI, all have TPMS, and all those TPMS working fine. I'm out of solutions, any ideas?
APR Stage 2|Unitronic Custom Intake|R8 Redtops|HPA SS|SPULEN Coilovers|SPM 3'' CBE|AWE Downpipe |034Motosports CatchCan|Unibrace XB|Unibrace UB|GFB DV+|Neuspeed TOP|BSH TBP|Godspeed IC|HSTuning RSR clutch|Wavetrac LSD |Fluidampr Crank Pulley|Polar FIS|PTP Turbo Blanket|H&R Sway Bar 26mm front sway bar|034Motosports 25.4mm rear sway bar|TyrolSport Front and Rear Deadset|NSQBBK|SuperPro
darkGTI is offline   Reply With Quote
Old 12-28-2017, 11:32 PM   #2
GtiJase
Drives: 2012 golf gti
You need to reset them.
Try this.
https://www.youtube.com/watch?v=mN4xEXtdx5M
GtiJase is offline   Reply With Quote
Old 12-29-2017, 08:04 AM   #3
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
Try this.
I have this button but I know some models donít, like the 2010 I believe. If you donít have the button maybe disconnect battery for 2 minutes?
Old 12-29-2017, 09:53 AM   #4
nvturbo
nvturbo's Avatar
If you aren't able to reset the code, at least one of the sensors is bad.
Old 12-29-2017, 11:19 AM   #5
Orient Express
Drives: 2010 Mk6 GTI
One possible clue
If you have a 2010 car and recently disconnected your battery, then the TPMS system lost it's settings, and is back to its default. You will need to use a VAG-COM to re-input the correct values. The other possible cause is that you have a bad TPMS sensor in one of the tires.
Orient Express is offline   Reply With Quote
Old 12-29-2017, 03:30 PM   #6
The TPMS batteries do die. As others have said, it could be a bad one but if you have access to VCDS you can check them that way. You can also turn the TPMS off completely, that's what I did. I have aftermarket wheels and I check pressures regularly anyway.
