Old 12-29-2017, 01:14 PM   #1
KillerPM
Drives: 2013 2.5 4dr
Rear washer jet hose leaking... Again
The dealership "fixed" my leaking rear washer jet hose twice under warranty. Out of warranty now, the problem has come back (water leaking into the rear hatch with no pressure out of the rear jet).
Has anyone replaced the hose with something that holds up a bit better? What type of hose did you replace it with?
Does anyone know what size ID the hose is?
With these salty snowy Canadian winters, it would be nice to see out the rear window.
KillerPM is offline   Reply With Quote
Old 12-29-2017, 02:49 PM   #2
brobst
brobst's Avatar
Drives: CSG mk6 6MT
What was the fix they did?
At this point will the issue returning a third time, perhaps they will good will service you.
Old 12-29-2017, 03:59 PM   #3
Carlosfandango
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
4mm id.
Old 12-29-2017, 04:28 PM   #4
Carlosfandango
I used a 4mm joiner from RS then sealed it with heat shrink when mine was leaking
Some of the wires were damaged at the same spot so I repaired those too then added spiral wrap to it all for future protection! Been fine for 18 months now, some have had to remove the C pillar trim to replace a length of pipe (silicone tube works best) but it depends where yours is broken, mine was getting water in the hatch too so your leak is probably by the hinge as well, I was able to repair it by just pulling the rubber part out of the way but it was a little tight, this is a known issue thatís why the MK7 has the rubber wire ducts in the centre instead.
Old 12-29-2017, 04:33 PM   #5
Carlosfandango
https://uk.rs-online.com/web/p/hose-couplings/4197300/
I still have a few of these so If you canít get hold of these where you are I can send you a couple and some of the heatshrink as long as you pay the postage cost from the uk! (about £3.00gbp) as theyíre so small and lite!
RS Canadian site:
https://www.alliedelec.com/view/search
Put this number in the search box 4197300
Old 12-29-2017, 05:03 PM   #6
MarioS
Drives: GTI MK6 Autobahn CW | GLI MK5
I found it on https://parts.vw.com/
It appears to be just regular rubber tubing. Get the size there or just order it. It wasn't that expensive.
However install seems to be a pain depending on how much you want to replace. You probably want to home run it to avoid splicing, which is what the dealership fix is.
Sent from my SAMSUNG-SM-G900A using Tapatalk
MarioS is offline   Reply With Quote
Old 12-29-2017, 06:04 PM   #7
KillerPM
They snipped the cracked section out and put a joiner in to put it back together.
The repair was done once inside the car and once in the hatch... I might push for a goodwill repair.. I will think about it...
Old 12-29-2017, 06:08 PM   #8
KillerPM
Thanks!
I can source 4mm ID stuff locally.
I think I will replace a section of it with silicone tubing. It cant be worse then whatever they are using OEM.
