Old 12-30-2017, 12:58 PM   #1
donaven.ecobiza1220
Driver side door lock and unlock switch not working
Just recently my door lock/unlock switch just stopped working, I havent done anything to the car since it worked, maybe its some kind of a wiring issue? There are some cases where it works if i open the driver side door and then close it, but also sometimes that doesnt work as well. Passenger side swtich works.
2010 Gti dsg
Sent from my SM-G935P using Tapatalk
donaven.ecobiza1220 is offline   Reply With Quote
Old 01-02-2018, 03:14 PM   #2
evo v
Drives: 2009 Audi A3
I had this problem on the GTI that I rebuilded. I opened the switch and found that the circuit board was corroded. Some of the lines were gone. The door cardboard is designed in a way that the water can get to the switch. I used jump wires and it is working fine for a year now. If you are not into soldering you can find new switch online. It's easy to replace it.
evo v is offline   Reply With Quote
Old 01-03-2018, 12:12 AM   #3
donaven.ecobiza1220
Cool thanks for the reply! Im gonna take a look inside and see what i find
Old 01-03-2018, 01:44 AM   #4
MLue1
2010 Gti dsg
I've had this problem problem off and on, usually in the spring and fall. I haven't opened the switch but it seems to be a contact problem. I find that if I use my finger nail to pry on the top edge of the switch it starts to work again and stays working for awhile so i haven't had a real cause to getting a permanent fix. The worst case I solved by using the trim tool for the radio to pry on the top edge of the switch, which got it working again.
Good luck
Old 01-03-2018, 11:18 PM   #5
PhthaloType
PhthaloType's Avatar
I've owned three Volkswagens, and each of them, at one time or another, has had a door lock issue.
2013 GTI Autobahn
4-Door
6-Speed Manual Candy White Titan Black
Bone stock!
PhthaloType is offline   Reply With Quote
Old 01-03-2018, 11:20 PM   #6
brobst
brobst's Avatar
Drives: CSG mk6 6MT
I agree. My rear drivers side locking cord is not always working properly
