Old 01-07-2018, 04:58 PM   #1
darsat
Coding rear LEDs help!!
Hi,
New to this forum but have a specific problem that someone might be able to help with. I have a 2012 GTI Autobahn, Xenon front lights, LED DRL and have installed OEM LED rear lights (originally from the U.K.) which have a rear fog. At the moment they all work as expected, but I get a bulb out for the rear right reverse light. I have tried changing byte 18 from 21 to 04 and to 15 but I canít get rid of the warning light. Any suggestions? Should I be using a different code or do I need a hardware solution such as putting a resistor in the tail light cabling?
Thanks!
darsat is offline   Reply With Quote
Old 01-07-2018, 07:18 PM   #2
Jeffs2013GTI
Jeffs2013GTI's Avatar
Drives: 2013 SB GTI (Sold)
I am not sure exactly how to fix this, but you can give Ross Tech a call and I am sure they can help you...
Assuming you bought your VAGCOM legit from them...
Jeff
Old 01-07-2018, 10:54 PM   #3
darsat
Yes I did buy it legit. I thought maybe I just had the wrong code but I will reach out to them. Grateful for any other suggestions too.
Thanks
Old 01-08-2018, 12:27 AM   #4
brobst
brobst's Avatar
Drives: CSG mk6 6MT
More than likely its the code. Can try 1F
Old 01-09-2018, 10:21 AM   #5
kiyoshi147
Drives: 2013 GTI DSG 4 Door w/Nav
do you have the Euro switch and trigger wires sorted out? to the best of my knowledge/experience there is no "coding only" solution to Rear Fog LED tails.
kiyoshi147 is offline   Reply With Quote
Old 01-09-2018, 10:57 AM   #6
jay745
jay745's Avatar
I code a lot of tails for people in chicago. Unless they are really goofy lights, change byte 18 to either 1F, 04, or 21 and that should get rid of the error.
Old 01-10-2018, 12:37 AM   #7
darsat
Don’t think they are goofy lights, they are legit OEM VW LED lights but just from the UK. I tried 1F, 15 and 21. 1F gave me front daytime running light error. 15 and 21 gave me the same rear backup light error. I don’t have the euro switch but also am not interested in being able to use the rear fog, just want it to be ignored and get rid of fault codes. Any other tips? Surely someone must have the same specs and situation as me?
Old 01-10-2018, 12:41 PM   #8
Jeffs2013GTI
Originally Posted by darsat View Post
Donít think they are goofy lights, they are legit OEM VW LED lights but just from the UK. I tried 1F, 15 and 21. 1F gave me front daytime running light error. 15 and 21 gave me the same rear backup light error. I donít have the euro switch but also am not interested in being able to use the rear fog, just want it to be ignored and get rid of fault codes. Any other tips? Surely someone must have the same specs and situation as me?
Which Wiring Harness are you using? Could be a bad harness wire causing a fault.
and we are assuming all bulbs are functioning properly?
Jeff
Old 01-10-2018, 01:04 PM   #9
jay745
jay745's Avatar
Try 04
Old 01-15-2018, 04:44 PM   #10
darsat
04 didn’t work either. I got the wiring harness from eBay...(?) Don’t seem to have a problem with any of the bulbs or wiring though as all the lights work and the rear fog comes on in place of the right-hand rear reverse light. It’s just that I want the car to know there is no right hand rear reverse light (because the UK spec lights have a fog instead) and be coded not to turn it on...
Old 01-16-2018, 12:00 AM   #11
DSGVW
DSGVW's Avatar
Drives: 2012 CSG GTI DSG
You can try ď20Ē as well. Similar to my setup but I opted for no rear fog. I settled on 21 for my setup.
DSGVW is online now   Reply With Quote
Old 01-16-2018, 03:59 PM   #12
Jeffs2013GTI
Could just be a bad wire harness from Ebay, just the fact that who knows who made it makes me wonder.
If you are trying all the codes that work for everyone else, and they are not working for you, then its either your doing something wrong coding wise, or your parts are crap.
One of the Two.
I would call ECS and get some good harness's. If you have actual OEM tail lamps they will have a harness for you. Try there. If they still dont work? Then its the Tail lights have a fault.
Any other reason is just grasping at straws.
Jeff
