Old 01-20-2018, 12:00 PM   #1
Jufbmjds
Drives: Mk6 golf Se2009
Reverse parking sensors not working (2 Faults found on diagnostic test)
A couple of weeks ago my battery mysteriously went dead. I jump started it and had the battery tested by halfords and they said it was fine (although as the car had been driven is this a good enough test?)
Now when I put the car in reverse the parking sensor light flashes and I get a long beep. The radio does not switch to parking sensor display.
I don't hear clicking from any of the sensors (but I dont know how anyone can with the engine running!)
I just took it to the garage for a scan, and he said their were loads of codes (and the cleared them all!), now 2 remain that wont clear (he cant look at it for another 2 weeks):
Click here for 2 codes
Any ideas?
Thanks so much for your help in advance!
Jufbmjds is offline   Reply With Quote
Old 01-24-2018, 07:31 AM   #2
spopinski
Drives: Golf MK6 1.4 TSi
If it's long beep then most likely the problem is your OPS module needs to be replaced
spopinski is offline   Reply With Quote
Old 01-24-2018, 08:49 AM   #3
Jufbmjds
Could it be a fuse?
Old 01-26-2018, 09:43 AM   #4
Jufbmjds
I just added the fault codes if that helps!
Old 01-26-2018, 02:41 PM   #5
spopinski
It says module EEPROM error right? Well I think it related to the dead battery you experienced. Just search 5K0919475 on Ebay, it won't be expensive.
But you should find why the battery was behaving like that in the first place. Maybe some kind of short circuit happened.
If the OPS module is below your tail light, then that space is notorious to get wet over time due to the tail light housing- rubber gasket aging.
parking sensor
