Old 02-03-2018, 09:55 PM   #29
thatspsychotic
thatspsychotic's Avatar
Originally Posted by zef View Post
iabed industries has a bulletproof solution for a leaking RMS. I had mine done when my clutch packs and LSD were installed. It's only about ~$100 but you'll never have to worry about it again
https://www.excelerateperformance.co...-seal-solution
Did you have a specific need to change out the clutch packs? Should I consider having an LSD done at the same time as RMS since some of the labor is shared? Trying to keep this from being a $4k scope of work, but it might be worth it...
Present: APR Stage 1+ v2.4 | APR Carbonio | R8 Coils | GFB DV+ | Unibrace UB | Tyrolsport Deadset | SuperPro Offset LCA Bushings | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18 | NewSouth Perf. Mech Boost Gauge
Future: ST Coilovers | H&R 26/22mm Swaybars | APR/ECS Catch Can
Old 02-06-2018, 07:01 AM   #30
joebrowntech
Drives: BMW118
RMS leaks in vehicles could hurt its fuel efficiency a great deal. However, you could work on this by following the procedures mentioned in your user manual. But if you somehow misplaced or lost your user manual, there’s nothing to worry.You could get it easily on manuals.co
joebrowntech is offline   Reply With Quote
Old 02-06-2018, 12:01 PM   #31
zef
No need really. The car sees track time and have read that heat will kill the packs overtime, so was just done as a precautionary measure.
Not sure what the labor rate for just the RMS was, but to do RMS, LSD & Clutch Packs was 14 hours (including dropping and reinstalling the trans).
Trans is super crisp now, and loads of traction now to boot. Was well worth the investment.
Old 02-06-2018, 01:09 PM   #32
thatspsychotic
Shop quoted me 8 hours for RMS alone, so it'd still be an additional $1600+ to do the LSD between parts and labor. I do some autocross so LSD obv would help, but my suspension needs a bunch more work before I really pin my lack of traction issues to the open diff. If I had been faced with this 4-5 years ago I would have done the LSD, but I'm hesitant to more significantly commit to this vehicle with 145k on the clock.
Photo while car was on the lift, positive RMS failure:
Old 02-06-2018, 01:16 PM   #33
thatspsychotic
Lesson learned here is get a catch can, early. Forget carbon buildup. Forget oil vapors slightly reducing knock threshold. Primary benefit of a catch can on these cars is protecting the PCV from seeing boost whatsoever, completely mitigating RMS failure exposure.
Old 02-06-2018, 05:41 PM   #34
thatspsychotic
Oof, another update. DMF also showed excessive play, which actually helps explain some other symptoms I was having. This bill is rapidly heading skyward.
Old 02-08-2018, 08:48 PM   #35
Allchokedup
Drives: 2011 gti stage 2 /stg2 sb daily
I just had to replace rms, manual clutch was already slipping on stage 2 before the leak. I wemt out of town had to pull over every hour put 2 quarts in
New rms and sb stage 2 single mass. Happy for now. There was actually oil on top of the trans case and everywhere else
Allchokedup is offline   Reply With Quote
Old 02-08-2018, 11:02 PM   #36
thatspsychotic
Dang, sounds like your RMS completely tore, that's a LOT of oil on the ground. Hope you did new PCV and/or catch can at the same time, otherwise it may happen again.
I went with another DMF, not looking to go quite full racecar
Sounds like RMS failure is pretty common, particularly with Tiguans. Shop said he's done a bunch of Tiguans, and my brother's fiance's Tiguan also had it done, got so bad the low oil pressure alarm sounded on her because it was leaking onto an undertray rather than showing up on the ground.
Old 02-09-2018, 12:37 AM   #37
MKVInnie
Drives: 2010 CSG GTI 6spd
Can you explain how that works? Does this also mean the PCV would end up failing less? I've had my PCV diaphragm tear 3 times already.
MKVInnie is offline   Reply With Quote
Old 02-09-2018, 02:20 PM   #38
thatspsychotic
I'm stealing the diagram from APR's description of their catch can solution, but many catch can setups have the same end result:
The most important thing is that the connection between the intake manifold and the PCV plate no longer exists with most catch can setups. Because of this, the PCV plate will no longer be exposed to boost pressure. Boost is what causes the PCV diaphragm and/or check valve to fail (most of the time anyways if I've read correctly). Removing the intake manifold to PCV connection prevents the PCV from being a source of potential boost/vac leaks as well as protecting the RMS and other oil seals from crankcase pressurization from faulty PCV under boost.
The shop that's doing my RMS effectively said I could either replace my PCV or add a catch can. For the moment I chose to put the new PCV plate in, but I plan to add a catch can myself later this spring.
