Old 01-30-2018, 09:34 PM   #1
thatspsychotic
thatspsychotic's Avatar
Coilovers + wide tires?
I'm running 245/35R18 PSS tires on 18x8 et45 wheels, and of course no rubbing issues whatsoever at stock height with fender screw mod, but I'm considering coilovers due to OEM struts feeling pretty worn after 145k miles.
Question is about the maximum ride height on different coilovers. I'm drawn to the ST X coilovers as an entry level option, but I've seen some mixed info about how high you can set them for minimum lowering for max tire clearance. Tire rack suggests min drop is like 0.5" which should be fine, but I've seen other sources showing a min drop of closer to 1.5" which according to the old golfmkv.com fitment chart would cause issues at 245 section width.
I know this may sound foreign to a lot of guys leaning towards more stance, but I do occasionally autocross so I'm looking for more functional information.
Can the ST X coilovers be set high enough to avoid rubbing with my wheel/tire combo without pulling/rolling? What are some other coilover options that aren't too low to cause issues?
Present: APR Stage 1+ v2.4 | APR Carbonio | R8 Coils | GFB DV+ | Unibrace UB | Tyrolsport Deadset | SuperPro Offset LCA Bushings | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18 | NewSouth Perf. Mech Boost Gauge
Future: ST Coilovers | H&R 26/22mm Swaybars | APR/ECS Catch Can
thatspsychotic is online now   Reply With Quote
Old 02-04-2018, 04:42 PM   #2
Roctre
Roctre's Avatar
Drives: 2011 CW GTI
The higher number that you see people posting are non GTI owners. If you want to be safe and call it a day some koni yellows and VWR spring give you a good stance while being very DD friendly and firming the ride up a bit.
Old 02-05-2018, 06:15 PM   #3
thatspsychotic
Yeah that's an option as well, and a little cheaper than ST X coilovers. However I do like the ability to balance the front/rear ride height as well as potentially corner balancing with coilovers.
I did read what you mentioned about the drop difference between base Golf and GTI, taking credit for the fact that the GTI is a good bit lower than the base Golf from the factory. Looks like I should be able to keep the drop to under 1" to make sure the tires still fit and not muck up the ride dynamics too much.
