Old 01-31-2018, 09:04 PM   #1
vwander
Control arm bracket replacement costs?
My steering's begun to wobble a bit past 60mph. Most things I read suggest that it's maybe an issue with the control arm bushings or mount. Any ideas on how much I should be paying for replacing the control arm brackets/bushings and getting an alignment?
2013 mk6 in southern california. Dealership prices are all over the place and I'm not able to get any reasonable idea from looking online.
Also, any suggestions on good indie mechanics in the area for this would be much appreciated. Not a big fan of the local dealers anymore...
vwander is offline   Reply With Quote
Old 01-31-2018, 09:33 PM   #2
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
It's pretty simple to swap
If you buy the bushing itself (which is the cheapest route)....that would require more work. You'd have to have the old bushing pressed out & the new one pressed in on the LCA
OR you could buy a new control arm with a new bushing in it (more expensive, but you can install yourself).
Remove the bolt, remove the 3 nuts on the LCA, then pull the LCA from the rear mount or pull the mount down with it.
Then swap it in & reinstall the same way
The rear arm mount is easy to swap too, especially if you're working on the LCA at the same time...just two bolts hold it in place.
I'd grab new OEM bolts when reinstalling that mount though
2017 Passat VR6
2017 Passat R-line
Old 02-01-2018, 08:21 AM   #3
TimS
Drives: '12 Golf R
Have you had the tires rotated and balanced yet?
