Old 02-04-2018, 07:02 AM   #1
Xapz
DSG: Hard Downshift Clunk
Hey guys so let me give you a little back story first
I bought a 2010 MK6 GTI last year & I can’t lie I love the car, now keep in mind this is my first DSG & my first VW so stick with me.
So a year and a half go by & I start to notice a TERRIBLE clunking sound when changing from from P > D
I took it to my VW dealer and find out that the tranny is going bad. No flashing indicator yet, but with the terrible lurking, bad shifts etc: I knew I needed a new transmission.
Fast forward to last month: I finally got my NEW DSG put in (since we couldn’t find any used ones at the time)
Keep in mind before the new DSG came along / the first time I noticed the terrible clunking (with the old tranny) I always had the music seriously bumping, subs and all so any noise prior to this first discovery wasn’t noticed by me but I’m worried still even with this new DSG.
So here’s my question to you all who drive a MK6 or 7 DSG, is the hard “clunk” when downshifting from 2 > 1 “normal” I’ve read quite a few post talking about this but not sure if we’re talking about the same noise since others have described it maybe as a “pop” or “grind” sound but this happens I’d say 45-50% of the time (when coming to a hard stop or a sharp turn)
Should I be worried and have it checked again at a different dealer? I do have extended warranty for another 23K miles & I also have complete coverage on the tranny for another 10K
Toe, bearings, & sub-frame: all checked out to be normal spec: I couldn’t replicate sound for the tech when we went on a drive together yesterday and he also mentioned they DO have hard forced shifts when coming to a hard stop or downshifting quick from second to first gear..
Anyways what do you guys think?
(ONLY ECU DONE - APR)
Otherwise bone stock @ 126K
Xapz is offline   Reply With Quote
Old 02-04-2018, 12:48 PM   #2
MTBFL1
Drives: Stage II GTI
It's pretty normal to me. I assume what you're describing is that it feels like it's dropping into first, then the car shutters a little bit and engine brakes A LOT. If so that's totally normal
Journal Thread|APR Stage II|Carbonio Intake|USP catted downpipe|034 Rear Sway Bar|034 Dogbone Insert|Michelin Pilot Super Sports|Depo LED tails|OEM/Thule bike rack|
Flickr
MTBFL1 is offline   Reply With Quote
Old 02-04-2018, 02:39 PM   #3
Xapz
I know the DSG has some delay especially dropping gears but is the noise that comes with that engagement normal? The forced clunk at fast turns or hard stopping sometimes, I can hear the transmission even with windows up when this does happen
Old 02-04-2018, 07:07 PM   #4
blower
I know the clunk you are referring too...and no its not normal for a new transmission. It is normal to find this sort of behavior when you have some serious miles on it but not for a new one.
The aforementioned engine braking from 2nd to 1st is not the clunk i think you are referring to...that should happen without a sharp sudden clunk, but can cause a bit of driveline vibration as the clutch is slipped in.
The clunking is known as a rough shift and is a common problem on aging clutch packs where the plates tend to stick or the mechatronics solenoids are sticking. I'm assuming a new clutch pack came with the new dsg box! - reusing the old clutch pack would certainly cause this sort of an issue.
Old 02-04-2018, 07:56 PM   #5
riceburner
Drives: 2012 GTI DSG / K04
Hey did read whole post sorry but when going from p to d -ake sure you always do this:
When PARKING the car, put foot on brake and hold while going into park like always... Once in park, keep foot on brake and engage the ebrake before letting off the brake pedal. The issue with not using the ebrake is that if you let it roll back or whatever it rests on the gears while in park to remain stationary which causes a strain of some sort. I had the same issue and since I've been ebraking before parking haven't had ansingle clunk
Old 02-04-2018, 09:12 PM   #6
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
I dont ever downshift the DSG into first. Mine only drops into first when i get down to 5mph which is pretty much only when im coming to a stop. I downshift to second and let it go into first on its own
Old 02-05-2018, 10:42 AM   #7
Cbell3186
Drives: 2011 DSG
I would say its not a clunk. More of a rev match and then the engine slows the car down faster than usual when at higher RPMs. To echo what @riceburner said. When parking, always use the parking brake, especially on an incline. If I don't then in get a clunk when pulling the gear shifter out of P. On a side note, even in pretty spirited driving I rarely take a turn in first gear, always second. Maybe shake that habit and see if that is a little more "peace of mind" for you when putting the car through its paces.
Cbell3186 is offline   Reply With Quote
Old 02-05-2018, 11:21 AM   #8
riceburner
Yeah don't shift into 1st from second
Old 02-05-2018, 11:36 AM   #9
jay745
jay745's Avatar
check all of the mounts, motor, trans and dogbone for any signs of wear or something. I've seen cracks in the trans near the dogbone that would cause these type of symptoms
Old 02-05-2018, 11:47 AM   #10
DASVDUB
DASVDUB's Avatar
This, mine acts all fucking weird. Let itself shift down to first if need be.
DASVDUB is online now   Reply With Quote
Old 02-05-2018, 12:08 PM   #11
1ashchuckton
1ashchuckton's Avatar
I've not experienced a hard downshift into first. Although many years of driving old British cars without a syncro first gear have trained me not to do that. I will only drop into first if I am almost to a stop, but letting the DSG do that for me is better. 2nd works better for tight turns 1st is too darned low.
Old 02-05-2018, 01:01 PM   #12
riceburner
x2 when i've accidentally shifted into 1st coming to a stop the trans kind of gives up and just goes into neutral or something lol.
Oh also want to side with others that takeoff's will be shaky usually. especially if on mounts
Old 02-05-2018, 01:19 PM   #13
DSGVW
DSGVW's Avatar
Drives: 2012 CSG GTI DSG
What car did you drive prior to this? Just curious as VWs and GTIs especially are notorious for clunky downshifts with the DSG tranny. Granted I'm tuned and TCU (DSG) tuned as well but mine is clunky when slowing fast or slow and clatters a bit if you listen for it. Granted I've driven a MK6/MK5 for almost 10 years now straight so I'm immune to these noises, lol.
If you want super smooth downshifts when coming to a stop, drive in Manual mode and leave it in gear and don't downshift. If will only drop into lower gears when it absolutely has to and it's much smoother than D or S modes. Just FYI.
Old 02-05-2018, 01:22 PM   #14
Jaber
Modero
Jaber's Avatar
When you're new to DSG and get it in the summer, you haven't experienced rough/hard shifts until you have driven it in the winter First 5minutes or so, you're like DAFAQ going on here.
But as you drive with DSG more and more, you start to get into the habit of being smooth with your inputs and avoiding certain things that can confuse the trans on what you want to do.
Member Journal
