Old 02-07-2018, 01:48 PM   #1
GroceryGTIer
Drives: 2013 black Wolfsburg
K04 owners what psi do you peak and hold?
Right now I can peak about 25 and hold 18-20 to redline. I'm wondering what everyone else is getting?
Old 02-07-2018, 01:51 PM   #2
jay745
jay745's Avatar
I haven't driven mine since october but usually peak 28-29 and hold about 26 or so. APR does request more boost though in place of pulling timing like other tunes.
Keep in mind during cold winter your car will actually boost less psi because the air is more dense.
Old 02-07-2018, 02:00 PM   #3
GroceryGTIer
Which IC are you running?
Edit: looked at your build thread, still on the neuspeed?
Old 02-07-2018, 02:03 PM   #4
jay745
jay745's Avatar
I just sold the neuspeed a few weeks ago. I'm putting a eurojet sandwich mounted ic in now. Only reason for making the switch is because I'm adding an external oil cooler and needed the space for it up front. There was no way to mount it with the neuspeed ic being there.
Old 02-07-2018, 02:05 PM   #5
GroceryGTIer
Oh ok, so these numbers are on the neuspeed then?
Old 02-07-2018, 02:07 PM   #6
jay745
jay745's Avatar
yes, I haven't driven it yet with the eurojet IC installed. I don't think it'll change all that much though.
Old 02-07-2018, 02:10 PM   #7
GroceryGTIer
I see, that seems to be a fair amount of psi for that turbo. I'm running a wagner, but I swear I must have a leak because only holding 20 seems really low to me.
Old 02-07-2018, 02:14 PM   #8
jay745
jay745's Avatar
What tune do you have? I have a few friends with k04's on varying tunes, all of our cars run fairly the same (none being significantly faster than the other) but the boost psi is all over the place based on which tune. Some companies advance timing to achieve the same results as apr gets by adding psi.
Old 02-07-2018, 03:45 PM   #9
Jcarollo765
APR 3.1 Tune- Peak 28-29 psi, hold 21-22 redline
Night Fury '13 Wolfsburg GTI/Carbon Grey/4-Door/DSG
Current Mods: APR K04 V3.2 & TCU V1.6//42DD DP//Unitronic Intake//H&R 26/24 Sways//Unibrace XB//SuperPro ALK//BSH Engine & Pendulum Mount//HPA 75a//Do88 Intercooler//H&R Cup Kit//Evo Boost Gauge//Soumatrix Speakers//BFI Stage 2 Tran Mount//GFB DV+//H&R 10/10 Spacers//Tyrol Brake Kit & Pads//Corgi Hair
Jcarollo765 is offline   Reply With Quote
Old 02-07-2018, 04:05 PM   #10
GroceryGTIer
I went from DM to UM's tune. Supposed to peak at 23-25.
Old 02-07-2018, 04:19 PM   #11
jay745
jay745's Avatar
It's probably just the cold air causing it to read a little less psi. Run logs often to see if it's running lean. I know of a few cars that have gotten badly damaged from UM running too lean.
Old 02-07-2018, 04:39 PM   #12
GroceryGTIer
I can smell, and see a lot of gas in my cc, which leads me to believe either I need a carbon cleaning, have a bad injector, or clogged injector. Also have high rpm misfires
Old 02-07-2018, 05:39 PM   #13
riceburner
Drives: 2012 GTI DSG / K04
I'm on Apr tune as well and mine also has a high 20s spike but holds pretty low 20s to redline. Runs strong was a pretty close match to Jay's car
Old 02-07-2018, 05:44 PM   #14
jay745
jay745's Avatar
Close match? Thought dsg's were supposed to be faster?
