Old 02-07-2018, 07:23 PM   #15
11gti718
Stratified tune - according to accessport peaking at 29 and holding around 23-25
Old 02-07-2018, 09:43 PM   #16
GroceryGTIer
Drives: 2013 black Wolfsburg
I pressure tested my intercooler, but never heard a leak, I have not, and don't plan to take that damn behemoth off my car. I hated that install more than anything
GroceryGTIer is online now   Reply With Quote
Old 02-07-2018, 10:00 PM   #17
brobst
brobst's Avatar
Drives: CSG mk6 6MT
The Wagner ic is big like apr right?
Taper to 18-20 psi range isn't bad and is probably a combo of the large ic and the tune.
Old 02-07-2018, 10:20 PM   #18
cybonic
Drives: Mk6 Gold GTi
as of my 3rd revision stealth map peaks at 26psi, holding 23psi.
cybonic is offline   Reply With Quote
Old 02-07-2018, 11:46 PM   #19
GroceryGTIer
Yeah, it's pretty huge... I forgot the liter amount, but yes, a bit bigger than APR. The neuspeed coolers and that size will allow forf much higher pressures.
Old 02-08-2018, 10:31 AM   #20
lleron
Drives: 2012 2dr 6spd White GTI
Stratified, P&P K04 with Neuspeed intercooler, peak ~24psi and roll off to ~18 at redline (WGDC @ 100%). Boost dip is due to wheelspin.
lleron is offline   Reply With Quote
Old 02-08-2018, 04:02 PM   #21
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Now see, this is more in line with my setup, big ic pnp turbo, and you are right on my numbers.
How do you wheelspin at like 4k rpms after your boost spike?
Old 02-08-2018, 05:28 PM   #22
GroceryGTIer
I have the same, pnp and huge IC. Added forge WGA, and could easily run more boost if the top wasn't bent all to hell, I can hold 20 without leaks, have yet to adjust the wg up.
Old 02-09-2018, 11:12 AM   #23
lleron
I have no idea, but the wheelspin is repeatable, at least at the highway onramp where I can run out 3rd gear. I also have an LSD and Indy 500 tires so it surprised me also.
I do wish I went with the forge WGA to hold boost longer (stratified suggested that I didn't need it when installing the turbo) due to how much of a pain it would be to install now but for my daily driving it's fine as-is.
Old 02-09-2018, 11:35 AM   #24
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Now I'm curious of the rest of the data log. Idk about the tire but your car has all the parts I do it seems, wheels spinning if any I expect at like 2.5k.
Can you link the data log?
Old 02-09-2018, 05:01 PM   #25
lleron
Ha, I feel like we derailed this conversation a bit, but here you go:
https://datazap.me/u/lleron/1-30-18-...og=1&data=4-21
I'm still going back and forth with Stratified revising part throttle/low rpm boost control but the WOT control seems reasonably dialed in.
Old 02-10-2018, 12:26 AM   #26
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Yea I do not see anything that overly stands out to me in the mid range. But yeah I can see around your wheel spin area your air intake flow drops off and your engine timing goes negative like you are coasting. Outside of that, looks good.
Old 02-10-2018, 11:55 PM   #27
Roh Echt
Roh Echt's Avatar
Drives: 2007 MKV GTI
Originally Posted by GroceryGTIer View Post
Right now I can peak about 25 and hold 18-20 to redline. I'm wondering what everyone else is getting?
More please...tune?, dia. of intake and DP/exhaust?, FMIC situation?, injectors?, 2.55 or 3 bar MAP?, and anything else?
What is your ECU target boost? ...and the actual?
I think you'll find your numbers mirroring others boost. But your tuner should have the target psi of your tune.
I've made mine boost over 30 psi before but that was in adding WG preload trying to solve something once. One tune w/3 bar MAP I boosted 26 psi - 22 psi after dialing it down from 28 psi - 24 psi...my current tune w/2.55 bar MAP shoots for 22.5 psi - 18.5 psi, but I have it boosting 25 psi(gauge) to 21 psi. I do plan on reducing the Forge WG preload because had tested what minimum yellow spring preload would do with spring pressure alone and it only boosted 20.5 psi...so I adjusted it nearly 2mm of preload and got the current boost which I will reduce soon as said.
So, Forge's claim on their yellow spring of 10-14 psi(20-28 psi boost) ended up being at the minimum rating. I thought to use my blue spring but it is 14-18 psi(28-36 psi boost) and I do not want the WG staying shut until 28 psi with zero preload.
K04 PLAY......ZOOMDIS!
`07 GTI/GIAC K04 files/AWE DV/APR HPFP/TTRS LPFP/Torqbyte PM3/S3 INJ's&fmic/RS4 fprv/FORGE fmtc,WG act.&TB HOSE/TechtonicsTuning TB/2.25" Turbo Outlet/BSH MOUNT's/NEUS. P-FLO&throttle pipe/GIAC DSG Tune/13.2BBK/W.A.L.K./H&R SS/H&R F&R-ARB's/Bilstein B8 Dampers My Dragtime link-GIAC tune2007 Volkswagen GTI : 12.823 @ 112.050 MPH
Roh Echt is offline   Reply With Quote
Old 02-11-2018, 09:43 AM   #28
GroceryGTIer
I'm on the UM tune, a 3" dp to the stock cbe, a ported and polished hotside k04 with forge WGA, to a leaking top, wager IC, red tops, 1 step colder plugs, stage 1 intake (was left over from my ecs unit) but I'd like to do a straight, really big intake such as a reflow of some sort.
