Old 02-08-2018, 01:33 AM   #1
mistaleungg
Drives: GTI MK6
Which Permatex sealant for valve cover?
Looking at their webpage, there are two options.
1. Permatex® High Temperature Anaerobic Flange Sealant
withstand temperatures to 400°F (204°C), fills gaps up to 0.020” (primed)
2. Permatex® Anaerobic Flange Sealant
for use on rigid machined flanges with less than .015" gap. OEM approved – use where OE’s specify “anaerobic” gasket (cures in the absence of air). Withstands temperatures to 300°F (149°C)
https://www.shopdap.com/permatex-ana...d154103a1.html
On Deutsche Auto Parts, they recommend the second one. But I wonder if the high temp sealant will hold better?
Thank you in advance.
APR Stage 1, Michelin PSS, OZ Leggera HLT 18x8, Superpro LCA, Tyrolsport Rigid Collar, HPA 75A Puck, APR pendulum mount, 034 Motor Mount, Akrapovic Downpipe
mistaleungg is offline   Reply With Quote
Old 02-08-2018, 01:45 AM   #2
Short Bus
Drives: '10 GTI
Technically we don't have valve covers, we have cylinder head covers. The only reason it's important to point that out is because unlike valve covers in a normal DOHC setup, the upper bearing caps for the camshafts are integrated into them.
I don't know if I'm being pedantic by pointing this out or not. But to address the question if Deutsche recommends it for this specific application I'm sure it's good.
Old 02-08-2018, 05:39 AM   #3
mistaleungg
Drives: GTI MK6
Thank you for pointing out.
I have been told it should be called as the cam girdle, and opening it up will mess up the cam/ timing?
The reason why I am considering permatex is because it is cheaper and hope it performs better than the OEM green sealant.
Old 02-08-2018, 07:35 PM   #4
joshterrell861
joshterrell861's Avatar
The oem green works great on fsi. But my tsi hates it. Mines pissing out slightly too
Sent from my SM-G955U using Tapatalk
joshterrell861 is offline   Reply With Quote
