Old 02-08-2018, 01:25 PM   #1
burnsbp
Downpipe questions
Hello all Iím new to the car scene. I have a mk6 gti 4 door MT6. I currently have a cts turbo intake and a forge blowoff. I recently just revived my down pipe and was planning on installing it today but a friend had a comcen with the downpipe sense I am untuned and have a blowoff. Just asking if you guys have any input on this as I am unsure. Thank you
burnsbp is offline   Reply With Quote
Old 02-08-2018, 01:35 PM   #2
jay745
jay745's Avatar
It might run like crap until you get tuned. You won't see much of a gain without the tune anyways.
Old 02-08-2018, 01:45 PM   #3
burnsbp
I’m okay with it running bad as long as I’m not blowing the motor or causing damage
Old 02-08-2018, 02:22 PM   #4
lilonespaz
lilonespaz's Avatar
i ran a turbo back exhaust for like a week before getting tuned. No issues besides the CEL from the downpipe. Other than that it ran okay
Old 02-08-2018, 07:31 PM   #5
BudgetPhoenix
Drives: 09 GLI
Ive tried flashing back to stock with my turbo back exhaust. It ran perfectly fine but threw o2 sensor lean codes even with spacers.
Old 02-08-2018, 08:40 PM   #6
Allchokedup
Drives: 2011 gti stage 2 /stg2 sb daily
Same car, i ran dp on stage 1 didnt see any issues. Local tuner told me stay out of throttle because it might lean out..mejhhh went stage 2 pewpew
Allchokedup is offline   Reply With Quote
Old 02-09-2018, 07:33 AM   #7
CHerna
CHerna's Avatar
that's a myth. well, with these cars anyway.
| Stratified Pro-Tuned | Eurojet TBE | Integrated Engineering Stage 2 CAI | R8 Coil-Packs | GFB DV+ | BC Racing BR Series Coil-Overs | Rotiform KPS | OEM Lagunas | Nitto NT555 G2 |
IG: @MightyCarlitos
Old 02-09-2018, 09:49 AM   #8
lilonespaz
lilonespaz's Avatar
Yeah the only CEL the downpipe causes is a faulty O2 Sensor/Cat Efficiency because sensor bank 2(on CCTA) or sensor bank 3(CBFA) are only there to check how efficent the CAT is cleaning the exhaust gases. When you change the DP the gases pass through the new cat(or lack there of a cat) with higher levels of "bad" gas in them which throws the code that your cat isnt working efficiently(or scrubbing the exhaust of those gases).
Sensor bank 1/2 (depending on motor) is the one that has to do with fueling and AFR which checks for how much fuel is in the exhaust gas mixture. This can provide a lean out code but only if you put a spacer on it. The only one that should ever get a space is the LAST O2 sensor furthest from the turbo the other sensors should not be touched as those can cause your car to run lean/rich.
