Old 12-04-2010, 08:09 AM   #1
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
The Official Driver Gear/VWR Spring Thread
I guess I'm always the guinea pig.
I bought a set of the VW DriverGear springs for a TDI 4 door w/DSG. I have a 4 door GTI w/DSG. The weight difference is ~20lbs. between the cars.
Eibach makes them for VW, but they are NOT the "Pro-Kit" springs.
These springs are linear (like OEM). The "Pro-Kit" springs are progressive type springs.
Part numbers:
2 door Manual, 2.5, GTI, or TDI = 5K3071677A
2 door DSG, GTI or TDI = 5K3071677B
4 door, Manual, GTI or TDI = 5K4071677A
4 door, DSG, GTI or TDI = 5K4071677B
BOUGHT FROM: www.keffervwparts.com
Parts needed for install: (REQUIRED ONES IN BOLD -- others are optional & removed during install)
Rear:
1. Lower Control Arm Bolts, N-106-107-02, 2 needed
2. Lower Control Arm Nuts, N-101-064-02, 2 needed
Front:
1. Drive Axle Bolt, WHT-002-795, 2 needed -- (IF REMOVING AXLE BOLTS!!!)
2. Stabilizer bar connecting link nut, N-015-081-6, 2 needed
3. Front lower control arm nuts, N-103-320-02, 6 needed
4. Strut lower bolt, N-909-548-02, 2 needed
5. Strut lower nut, N-101-064-02, 2 needed (same nut as used on rear shock lower nut)
6. Strut upper bolts, N-101-277-07, 6 needed
7. Strut assembly rod nut, N-910-216-01, 2 needed
8. Strut Bearings, 6N0412249C, 2 needed
MISC tools needed:
1. Fwd HUB puller (rented at O'Reillys, Evertough 67032)
2. Spreader Socket (VW tool # 3424)
3. Spring Compressor (rented at AutoZone)
4. Open Socket (VW tool # 3186)
5. Torx L-wrench T45 or 7mm allen (for strut shaft)
6. Suspension limiters (VW part number 000-071-501-A)
7. 24mm 12-point socket (for axle bolts)
8. 14mm Triple Square bit (for strut pinch bolt)
9. Torque wrench
10. 2 foot breaker bar (used to get the additional 90 degrees on the front axle nut)
DIY install with pics:
http://www.golfmk6.com/forums/showthread.php?t=67825
or
http://forums.tdiclub.com/showthread.php?t=273002
Anyways....they're supposed to only be for the Golf, but they fit the GTI as well (I ran them on my MKV as well).
They don't "slam" the car, but it does get rid of most of the ugly wheel gap.
Nice slightly firmer ride, but waaaay better handling than the stock springs and you still use the stock dampers...all while keeping your suspension parts under warranty
I'm still waiting for them to "settle" I suppose, but this was right after I installed them....I happened to park next to a stock GTI (4 door DSG) and took some comparison (iPhone) pics....you be the judge:
Comparison...
Other pics....just 2 days after installing....
STOCK:
EIBACH PRO-KIT:
2017 Passat VR6
2017 Passat R-line
Old 12-04-2010, 08:14 AM   #2
Danny Boy
Danny Boy's Avatar
Drives: 4dr DSG CW
they seem a little taller than the eibachs. how come you switched?
I am the REAL Jose/Ben/flipachu aka King Perez De Tagle
Danny Boy is offline   Reply With Quote
Old 12-04-2010, 08:26 AM   #3
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
They're definitely not as low as the Pro-Kit
Why'd I switch?...2 reasons:
1. Winter time
2. The Pro-Kits need better dampers than the stock ones...well at least here in Michigan. The roads SUCK.
On smooth roads...the stock dampers can handle it & they're awesome.
But when it gets rough....they get bouncy
So I'm gonna save up for some Koni's for the spring/summer time
2017 Passat VR6
2017 Passat R-line
Old 12-04-2010, 09:44 AM   #4
Carbon Steel
Carbon Steel's Avatar
For me it is the perfect height, too bad VW does not put those in production. Looks good, safe clearance, better handling, and the warranty is intact, win.
Oh, nice car.
peace
Old 12-04-2010, 10:39 AM   #5
dsm1983
Drives: ...
yessir
dsm1983 is offline   Reply With Quote
Old 12-04-2010, 10:43 AM   #6
Stocktastic
Stocktastic's Avatar
Drives: I gotter meotter.
I might just have to order some of these.
Stocktastic is offline   Reply With Quote
Old 12-04-2010, 11:14 AM   #7
MattTheCarNut
MattTheCarNut's Avatar
Drives: 2010 GTI 2DR DSG
Oh, wow. That looks fantastic! Did you get a discount on the price? Bad news to hear about the Pro-kit/stock dampers/rough roads combo. Now I'm unsure which setup to get....
Thanks for being our GP!
2010 MKVI GTI in United Gray with Titan Black Leather
3DR | DSG | Autobahn Pkg | 18" Detroits | RNS 510 Navigation | Bi-Xenons | 9W7 Bluetooth | LED Golf R Tail Lignts | LED Rear License Plate Lights | Noise-maker Delete | OEM Front Spoiler Lip | Painted Side Markers | Magnaflow CBE | H&R Sport Springs | 35% Carbon Tint | VAG'd
MattTheCarNut is offline   Reply With Quote
Old 12-04-2010, 11:20 AM   #8
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
Ohh look at that..would you look at this...yah look at it!!
Nice drop, subtle and gets rid of the freakin gap, might consider it.
Old 12-04-2010, 01:55 PM   #9
Grownman
Drives: .
Same here!
Grownman is offline   Reply With Quote
Old 12-04-2010, 02:42 PM   #10
CodeB4U
CodeB4U's Avatar
Drives: Chevy SS, MK6 GTI,240 SX, NBS Tahoe
In all seriousness, that drop along with the warranty is freakin perfect.
I hate rim tuck, i dont mind a few mm of tire tuck, but rim tuck on a car like this is a no-no for me.
Those springs could be a few MM lower, but for "OEM" that's freakin nice.
CodeB4U is offline   Reply With Quote
Old 12-04-2010, 06:36 PM   #11
v3on
v3on's Avatar
Drives: 2011 CW GTI
Where can I buy it ? Any help will be pleased !
[2011] CW 4D GTI 6MT - CURRENT
[2011] CSG 4D GTI DSG - GONE
v3on is offline   Reply With Quote
Old 12-04-2010, 09:22 PM   #12
Schn3ll
Drives: '11 UG GTI
+1, I would buy these asap.
Schn3ll is offline   Reply With Quote
Old 12-04-2010, 09:30 PM   #13
J-Cooz
J-Cooz's Avatar
Drives: 2010 Golf Sportline
Those are perfect!
J-Cooz is offline   Reply With Quote
Old 12-05-2010, 12:36 AM   #14
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Paul @ Keffer VW on the Vortex....ordered directly thru their website. I'll have to find the link later though
~$225 + Shipping
So $242.30 SHIPPED
2017 Passat VR6
2017 Passat R-line
