Old 12-27-2010, 05:36 PM   #15
EJBGTIVI
Formula 2 Champion
EJBGTIVI's Avatar
Great write up- thanks for sharing. Looking forward to doing this in the spring. I miss my auto dim mirror.
EJBGTIVI is offline   Reply With Quote
Old 12-28-2010, 05:14 AM   #16
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Awesome writeup!
I wish this car came stock with a dimming mirror.
Quick question though....does it have on/off?
Or is it always on?
2017 Passat VR6
2017 Passat R-line
Old 12-28-2010, 09:48 AM   #17
jbcritch
jbcritch's Avatar
Drives: 2011 CSG MK6 GTI
Originally Posted by snobrdrdan View Post
Awesome writeup!
Or is it always on?
Thanks!
It does have an on/off switch.
2011 MKVI GTI CSG Autobahn
MY MOD THREAD: http://www.golfmk6.com/forums/showthread.php?t=12631
jbcritch is offline   Reply With Quote
Old 12-28-2010, 05:06 PM   #18
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Originally Posted by jbcritch View Post
Thanks!
Nice
Did you ever think about grabbing an OEM one from a different or wrecked VW car? (just wondering)
2017 Passat VR6
2017 Passat R-line
Old 12-28-2010, 09:18 PM   #19
jbcritch
jbcritch's Avatar
Nice
No because the OEM does not have Homelink, it is just auto dimming.
Old 12-28-2010, 11:52 PM   #20
TREGinginCO
TREGinginCO's Avatar
Drives: 2010 JSW TDI w/DSG & 2006 Touareg
That is a great write-up... because I can probably use that power lead on the map lights to power my V-1 and I can run a shorter line rather than get anywhere near my A-pillar.
TREGinginCO is offline   Reply With Quote
Old 12-29-2010, 09:02 AM   #21
jbcritch
jbcritch's Avatar
Yes you can. And there is a company that sells a mounting bracket that fits this mirror perfectly for the V1. Check out www.blendmount.com. Oh, and have you seen the below mirror?
check out www.stealthmirror.com.
Name:	stealth mirror.jpg
Old 01-19-2011, 12:21 AM   #22
GenDV138
Drives: 2011 CSG 4DR GTI 6MT
Did this today, thanks for the great DIY jb! Trickiest part was getting the wires through the headliner but that wasn't too bad.
GenDV138 is offline   Reply With Quote
Old 01-19-2011, 09:30 AM   #23
jbcritch
jbcritch's Avatar
Glad it worked for you. I agree about the headliner. That metal edge was
Old 01-20-2011, 08:15 PM   #24
GB724
Drives: Candy White 6
The blue and red wire is always hot in my car. Anyone else run into this? Even after the map lights go out when the car is off, the wire still has power.
EDIT:
The instructions require both hot and switched power wire. However, the map lights in the GTI gain power once a door is opened and retain their power for at least 15 minutes after the engine is shut off. The Homelink unit does not loose its memory, so there is no need for constant power to the Homelink unit. I chose to power both wires with the switched map light wires.
The wire you want is the first/last wire in the blue quick connect. It is red with a blue stripe:
I totally missed this. So after 15 mins or so, it will shut off then?
GB724 is offline   Reply With Quote
Old 01-20-2011, 08:54 PM   #25
jbcritch
jbcritch's Avatar
Wink
EDIT:
Yes.
Old 01-21-2011, 09:50 PM   #26
ScottyFerrari
Drives: 2011 4dr Carbon DSG
Jbcritch: I just did this mod today. With your write up and photos, it was a piece of cake. Thank you.
ScottyFerrari is offline   Reply With Quote
Old 01-21-2011, 09:52 PM   #27
jbcritch
jbcritch's Avatar
Glad it helped! Enjoy!
Old 01-22-2011, 07:53 PM   #28
aeroalex
I previously installed this mirror in my '09 Jetta and ran the wires to the fuse box. I wanted to make things a little easier on my '10 GTI so I gave this install a try and was unsuccessful getting power to the mirror. If you connect both mirror power wires to the same map light power wire (the 2nd connector just a bit further down than the 1st), won't you get a voltage drop? I pulled out my multimeter and found that when the harness was plugged into the mirror and both wires were connected I only saw about 4-6 volts at the connectors. When I unplugged one, the other went back up to 12V. I don't know why I had this issue if several other have done this successfully, though... And I don't have anything skinny enough to test the voltage at the harness, rather than at the connector. So I wanted to try and put one of the other wires on a different 12V source up there, such as power for the bluetooth or sunroof, but wasn't sure which wire was which. Any ideas that I could try?
aeroalex is offline   Reply With Quote
