Old 03-16-2011, 01:36 PM   #43
Justinjor
Justinjor's Avatar
Drives: MK6 GTI
Order placed. We just bought a house and I'll have my first garage since I moved out of my parents house when I was 17. It seemed only appropriate to make sure I could open the garage door with my mirror At least, that's what I told the wife so I could make the purchase
■2010 GTI■APR S2■Carbonio S1/S2■Noisepipe Delete■Ultimate Racing TBE■Rev D Diverter Valve■H&R Sports■ SOLD
2008 Vette-10.67@129.0 mphSOLD
2013 Mustang GT 10.5@130
2013 CSG DSG GTI - wife's ride - bone stock
Justinjor is offline   Reply With Quote
Old 03-16-2011, 10:09 PM   #44
jaydub
jaydub's Avatar
Drives: 2011 GTI 4-Door 6MT
Another big thank you for this DIY. I was able to get it all installed using your directions because honestly, the ones with the mirror suck.
I took mine a step further and cut/soldered the long wire they give you because space will be limited once I mount my Valentine 1 up there. I took a few pics to document it.
After cutting, I wrapped some self-adhesive shrinkwrap tubing to the end of the wires. I just wanted it to be very clean.
Here's the ends I cut.
Got a nice, clean solder.
I shrinkwrapped each of the wires individually, then all together.
The soldered section is actually about 2" inside the headliner, so it all looks clean.
jaydub is offline   Reply With Quote
Old 03-17-2011, 09:05 AM   #45
jbcritch
jbcritch's Avatar
Drives: 2011 CSG MK6 GTI
Nice!
2011 MKVI GTI CSG Autobahn
MY MOD THREAD: http://www.golfmk6.com/forums/showthread.php?t=12631
jbcritch is offline   Reply With Quote
Old 03-26-2011, 08:28 PM   #46
Justinjor
Justinjor's Avatar
Drives: MK6 GTI
Ugh, so I got my kit in and tried installing it this weekend and cannot get the unit to receive constant power. I think my ground is bad. I tried sanding down that screw to give it a good connection but it's still screwing into plastic and does not give a good ground. The unit will come on, but the green light will just flicker.
How should it look when plugged in? solid green? Also, anytime I try and hit a homelink button, the green light goes out for a second, then flickers very rapidly.
Ugh, why can't this be easy. lol
Old 03-26-2011, 09:32 PM   #47
jbcritch
jbcritch's Avatar
The unit will light up solid green when powered and red when homelink is activated. You may have the wrong screw. The one I tapped is a metal screw into metal. Be sure to sand the metal panel and not just the screw.
Old 03-26-2011, 10:08 PM   #48
Justinjor
Justinjor's Avatar
Drives: MK6 GTI
The screw in the picture is going into plastic, isn't it? I don't see any other screws that resemble the one in your picture.
Old 03-26-2011, 10:49 PM   #49
jbcritch
jbcritch's Avatar
Yes and no. The screw goes through the plastic and into metal. Make sure the metal makes contact with metal. Also pull the wire taught to the side of the screw to ensure the screw is in contact with rhe metal.
Old 03-26-2011, 11:38 PM   #50
Justinjor
Justinjor's Avatar
Drives: MK6 GTI
I had my test light out and it showed a good ground there but for whatever reason, the mirror isn't getting good power. I'll have to take another stab at it tomorrow.
Old 03-27-2011, 10:34 AM   #51
jbcritch
jbcritch's Avatar
Good luck. Pm me if you want to talk via phone.
Old 03-27-2011, 10:44 AM   #52
Justinjor
Justinjor's Avatar
Drives: MK6 GTI
Hey jb, It was a bad ground after all. I just borrowed dremel and power drill from the in-laws and bought a self-tapping sheet metal screw. 20 mins later, she's green and amber just like she should be Now I'm waiting for the black paint to dry(i should have done that yesterday but forgot) so I can button her back up. I did a test fit and it really looks nice. Thanks again
Old 03-27-2011, 12:27 PM   #53
jbcritch
jbcritch's Avatar
Glad to hear you got it figured out and fixed!
Old 03-27-2011, 12:39 PM   #54
Justinjor
Justinjor's Avatar
Drives: MK6 GTI
Yep, to anyone doing this install yourself, I'd recommend just grinding off the paint next to that screw in the picture and throwing a self-tapping sheet metal screw up there. Just my $.02.
Old 03-30-2011, 01:54 AM   #55
themaxx
Drives: 2011 GTI, 4-door, carbon, manual
Thank you for posting this write up.
themaxx is offline   Reply With Quote
Old 03-30-2011, 09:00 AM   #56
jbcritch
jbcritch's Avatar
good advice.
you are welcome!
