Old 05-19-2011, 12:59 AM   #15
Sieran
Sieran's Avatar
Drives: 2011 4-door GTI
Just had this happen to me on the way home... wasn't driving hard either.
I sped up (maybe 50% throttle at 3krpm) to pass a car and as soon as i let off the throttle it came up with this warning.
I pulled over and i happened to have my vag-com cable with me so i plugged it in. Couldn't find any faults?
Calling the dealer in the morning.
Sieran is offline   Reply With Quote
Old 05-19-2011, 11:31 AM   #16
4D17HY4
4D17HY4's Avatar
Drives: 2011 Candy White GTI 4dr 6spd
Interesting repeat of occurrences
'11 GTI - 4dr - 6spd - APR Stage1 - Neuspeed Intake - Muffler Delete/4" Magnaflow tips - NSP Mech Boost Gauge - Re-badged and red pinstriping all around - Yellow tinted fogs - Interlagos rear badge insert
<a href=http://i81.photobucket.com/albums/j239/rattlesn_ak_e/GTI%20stuff/Avatar_GTI.jpg target=_blank>http://i81.photobucket.com/albums/j2...Avatar_GTI.jpg</a>
4D17HY4 is offline   Reply With Quote
Old 05-19-2011, 02:43 PM   #17
Sieran
Sieran's Avatar
Dealer called few minutes ago...
They told me they found the cable to the throttle body unclipped and partially unplugged.
They plugged it back in and went for a few "aggressive" test drives to check to make sure the cable stayed seated. Error is gone also.
I'll see when i get it back.
Old 05-19-2011, 02:48 PM   #18
4D17HY4
4D17HY4's Avatar
GOod to hear, but "aggressive test drives"? lol
Old 05-19-2011, 03:11 PM   #19
Sieran
Sieran's Avatar
Probably just taking it around the backsides of the dealership and punching it hard onto the service road.
As long as they don't smash it.
He think's it was becoming loose enough during acceleration to cause the problem so i am guessing they are just going to gun it a few times to make sure it stays connected.
Makes sense to me because it happened right after passing a car...
Old 05-19-2011, 05:11 PM   #20
Sieran
Sieran's Avatar
They said they found "several loose wires" on the plugs in the images below. I thought he meant the plugs themselves were loose. The actual pins were pulled out of the plugs and had to be reseated.
Anyone else having this issue maybe check these?
Old 05-26-2011, 03:28 PM   #21
ColdBrew
Drives: 2011 White GTI DSG Autobahn
I just had this problem this morning while pulling in to my garage. I thought maybe it was because I came down my drive way (steep hill) and it pull the oil away from the pickup. But I enter my garage the same way every day and this is the first time. Mine has around 1100 miles on it.
ColdBrew is offline   Reply With Quote
Old 05-27-2011, 02:39 PM   #22
scooby103
Drives: 2010 GTi
Did you guys check your oil levels? I'm thinking 90% of these alarms are caused by low oil (not enough to flash light) but low enough that when on either a steep incline or hard turning would cause the pickup to run dry for 1/2 a second.
scooby103 is offline   Reply With Quote
Old 05-27-2011, 04:14 PM   #23
Sieran
Sieran's Avatar
Yep, oil level was filled perfectly to the full mark.
Old 06-23-2011, 06:35 PM   #24
nexstar7
it happened to me. i checked the oil level and it was a 3/4 short @ 8,500 miles. the book does say that you might go throught a quart of oil in your first 10,000 miles. so i did an oil change. im not doing the 10,000 deal, that bs. im going 3 to 5,ooo from now on.
nexstar7 is offline   Reply With Quote
Old 06-28-2011, 03:31 PM   #25
Jacris
Jacris's Avatar
Drives: 2011 MK6 GTI
Also saw this message within the first 1500miles. It cleared and has never come back. Did my own first oil change at 3500miles and filled to the high mark. Just shy of 5qts.
Stage 2
Jacris is offline   Reply With Quote
Old 06-28-2011, 07:07 PM   #26
nexstar7
does anybody know how to reset the computer so it stops telling me my oil needs changing.
Old 06-28-2011, 08:22 PM   #27
realcyberbob
realcyberbob's Avatar
I have also had this issue 3 times within the first 2000 miles. Took it to the dealer and after a day of testing they couldn't find anything.
Old 06-28-2011, 10:08 PM   #28
zanyrsc
zanyrsc's Avatar
Drives: 4 Door GTI DSG
in the MFI there is a service option. select it and press reset.
zanyrsc is offline   Reply With Quote
