Old 12-11-2011, 12:25 AM   #43
ajyuster
Drives: 2011 2dr GTI CSG DSG, ECU
Originally Posted by ForTheLaLa View Post
Hey everyone~
This warning just came up while driving home...not sure what it really means... has this warning come up for any of you guys? Theres a warning light as well just above the digital display on the dash when it first happens.
Thanks! I attached a picture as well ... the light goes away, but the warning data is stored in the dash now.
I had this problem with my 11 gti. I took it to dealer. They checked the oil level, pressure and even tried cornering hard ( sometimes when you corner hard and have no oil the light comes on).
If you can, drive straight to the dealer. DO NOT SHUT OFF YOUR CAR because the code will get deleted and then the dealer goes "we dont see any codes".
They kept it for 3 days and then returned the car back to me with, "lets closely monitor this". Ever since i havent had that light come back on and i am at 13k.
ajyuster is offline   Reply With Quote
Old 12-11-2011, 12:43 AM   #44
realcyberbob
realcyberbob's Avatar
I have scanned my car with a Vagcom while the light was on and no code was found, weird eh??
Old 02-09-2012, 06:30 PM   #45
hatzo1
hatzo1's Avatar
Well I'll add my car to the Oil Pressure warning coming on. Came on after getting off the interstate, but after I stopped for the second time. I live close to the interstate so I drove it home slowly and checked the oil and all is fine. Turned the car back on and no warning. It actually went off when I was limping it home. I have to drive pass the dealer on the way to and from work so Ill stop by in the morning to see if anything shows up. Anybody have more info from there cars after the light?
Chris
Southern Street Tuning & Detail
2011 GTI 4dr /DSG
2015 Road Glide Special
hatzo1 is offline   Reply With Quote
Old 04-21-2012, 10:27 AM   #46
CyaL8R
Drives: 2011 GTI Candy White
Just happened to me too.
Hey everyone~
This just happened to me last night too. I also have a 2011 Candy White GTI and was driving home in bumper to bumper traffic. I'm at the dealer now...been sitting here 2-1/2 hours so far....still waiting...
CyaL8R is offline   Reply With Quote
Old 04-22-2012, 08:46 PM   #47
SuPeR GTi
SuPeR GTi's Avatar
Drives: 12' GTI MT
^let us know what the outcome is. this seems pretty random, and i dnt think its because of hard driving or cornering in this case.
Old 05-21-2012, 07:36 PM   #48
skantron
skantron's Avatar
Drives: 2011 GTI 4d CSG 6spd
I had this happen at around 1-2k miles... oil was fine. at 33k, it just happened again. again. oil is fine. Both times it was raining? both times, it was raining, but I was driving pretty easy, today, when it happened again, I was driving super easy becuase I was trying to get my gas mileage up... No error codes on vagcom either.
- Revo Stage 2 - VAGCOM - R.A.I. DP - R.A.I. CAI -
skantron is offline   Reply With Quote
Old 05-22-2012, 03:40 PM   #49
ErsteGTI
Drives: White 2011 GTI 4dr DSG
Happened to me on the way to work this morning. Bumper to bumper and with low speed intervals. Made it to work (~10 miles). Just checked oil after allowing engine to cool. Maybe a tad bit low, but still within the middle zone (B). Turned on the car to go pick up lunch and.....no warning light. Pushed it a bit to 5K rpms and no problems.
This is the second time it's happened to me. Last time, the oil level was at low portion of zone B, and I added 1/2 quart. Dealer mentioned that low oil level was probably the cause, and it's know that GTIs can loose about 1/2 - 1 quart every 1200 miles. Since then, I always keep quart of oil in car, JIC.
ErsteGTI is offline   Reply With Quote
Old 08-31-2012, 03:06 PM   #50
Arash007ir
Arash007ir's Avatar
Drives: 2011 GTI Autobahn
I got it this morning, I wasn't pushing the car, I was actually doing 5 mile an hour when it came up.
I also keep getting "Service now" for the past 5 days, which was peculiar since I had it serviced about a month ago.
I've done almost 20,000 Km, did all the services. I don't have an oil leak or anything.
Arash007ir is offline   Reply With Quote
Old 09-07-2012, 09:00 AM   #51
lilfleck
Drives: '11 GTI Autobahn, DSG
Bringing back... I just got this on my way to work this morning. It happened at a light after I accelerated through 2nd & 3rd (soft shifts, higher RPM, incline hill). Car sounds & feels fine, but it was beeping w/ the same message. I have 11k and just got the 10k service done @ 10k.
I will check the oil levels at lunch, but did the dealer find anything else that could be causing this? I saw the loose wire thing, but I feel like not every dealer would find this.
Old 11-18-2013, 07:17 PM   #52
LightningRhod
LightningRhod's Avatar
Drives: 2011 CW GTI DSG
Thread bump.
Got the warning again on my way to work today as I was cruising on the highway at 70MPH. Blinks/beeps initially, then the orange light come on and off in the MFI. For the record, the oil was changed and topped off maybe 3 weeks ago. I'll check the levels again before I leave work, but I'm sure the oil levels are all good.
I also got the warning a couple of months ago as I was crawling through a parking lot. Notification eventually went away as I was looking for a parking spot.
For the record, I'm at 76k miles.
Old 11-18-2013, 07:20 PM   #53
RacingManiac
RacingManiac's Avatar
I've had this happened twice in the 43k that I've had this car. Both time kinda came on suddenly, then only to not show again for a long time. Never have I actually seen any issue with oil level that I can tell...
Old 11-18-2013, 07:29 PM   #54
LightningRhod
Yep, same here. Each time it has happened, my oil levels are all good.
These damn electrical gremlins are annoying .
Old 11-22-2013, 01:36 PM   #55
icee
Drives: 2011 CSG GTI
I got stuck in some pretty horrific traffic the other day. It took 90 minutes to move just 5 or so miles.
The alert came up with the orange light and the 4000RPM limit warning. I've never heard that type of beep before. It sounded like it came out of the speakers vs the normal chimes and ding sounds coming from the cluster. That might just be me though.
I made it to an auto parts store where I picked up a couple quarts of oil thinking that it was just low. Oil checked out fine. I got back in the car, fired it up and the error was gone. Did a 1200 mile road trip right after with no issues.
I never did test the car if it actually limits you to < 4000 RPMs with that message active. Electrical gremlins? Car doesn't like idling that long? Whatever it was, it hasn't come back since.
I've got 45K miles on the clock.
icee is offline   Reply With Quote
Old 01-10-2014, 02:01 PM   #56
GregAmy
Drives: 2011 Base GTI
Bump. 2011 GTI, 29.5k miles, dealer changed oil two weeks ago. Short commute (15 minutes), ambient temperature in the high 20s. I parked in my driveway to get out to open the garage door (I really need to get an opener) and left the car idling, and the warning - first time for me - happened right as I DSG'd into reverse to back into my garage.
Immediately shut off the car, checked oil level and it was at max. Restarted car, no more warning, drove to work today with no issue.
Dealer says "keep an eye on it and come in if it happens again."
- GA
GregAmy is offline   Reply With Quote
