HYDE161
HYDE16 REVIEWS FORGE MOTORSPORTS MKVI TWINCOOLER [INTERCOOLER] KIT - DIY Pictorial
So I dealt with the cold northeast winter weekend and finally installed my Forge Motorsports Twincooler [Intercooler] kit.
All in all, I was very impressed with the intercooler core, the high quality hoses & clamps and the detailed instructions.
As with my last -DIY MKVI FORGE MOTORSPORTS TWINTAKE - First DIY Pictorial- review, I took a ton of pictures and posted them for each step. With the Forge Motorsports Twincooler [Intercooler] kit, the –included instructions– were so clear I didn’t feel the need to repeat all of the steps and pictures. I did however take some pictures of what I found.
Word of caution before install: As with any aftermarket kits, make sure to clean out the new piping. I used an air hose to blow out any possible debris inside the piping. I would even go as far to say scrub the pipes out with a soft nylon brush, soap and water to remove any dirt or debris. Blow out every piece with an air hose to remove water or packing debris.
Bumper removal: There are a lot of bolts to remove but they come out quickly. Remove the bolts for the grill and pull it straight out, remove the fender bolts and bolts for under the bumper and underside tray. I did find that the instructions missed two bolts underneath where the grill was. They are facing forward on the inside corner of each headlight. Pull the corner of the bumpers out and then pull the whole bumper forward.
Front end open:
Hose Removal: Use a flathead screwdriver to pry the round retaining clips just enough so that the connectors can be pulled off of the outlets. Word of advice: on the passenger side, keep track which retaining clip goes to the stock intercooler and outlet pancake pipe. I noticed afterwards that the clips were slightly different and a tiny bit different in size. On the driver’s side leave the retaining clip on the stock intercooler outlet connector; this will make it easier when installing the new hose.
Front end open:
