Old 02-17-2011, 05:06 PM   #15
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
Originally Posted by Ronkerjake View Post
Arin, can you verify if the 2010 ECU was updated? I've been hearing rumors that stage 1 and 2 for the 2010's has been tweaked. Yea or nay?
Yup. All the North American CCTA/CBFA 2.0 TSI's are updated.
Old 02-17-2011, 05:41 PM   #16
dbest6808
Drives: 2010 GTI DSG
Question
So Arin here's my question I already have stage 1. I'm installing the RSC Turboback and will go to stage 2. Will the stage 2 flash be at no cost?
I may do the install myself or go to my local APR here in White Plains NY which also happens to be my VW dealer.
dbest6808 is offline   Reply With Quote
Old 02-17-2011, 07:21 PM   #17
Arin@APR
Arin@APR's Avatar
If you have APR stage 1, we do not charge you for the stage 2 file.
Old 02-17-2011, 11:10 PM   #18
dwp2
Stage 1 Tweaks?
Arin,
Can you share any details on the differences between the old and new Stage 1 flashes?
Can I get updated, without removing the ECU, since I already have a Stage 1 flash?
2010 CSG GTI | 2D 6MT | APR Stage 1 | Carbonio Stage 1 | S3 FMIC
dwp2 is offline   Reply With Quote
Old 02-17-2011, 11:46 PM   #19
Stevec717
Stevec717's Avatar
Drives: 2011 VW GTI MKVI
Stupid question maybe, but does an APR Program require removal/modification of the ECU, or just a software reflash?
Thx
Steve
Also, do you have any test data or specs on how much torque the stock clutch can handle?
Stevec717 is offline   Reply With Quote
Old 02-18-2011, 01:44 AM   #20
Arin@APR
Arin@APR's Avatar
Originally Posted by dwp2 View Post
Arin,
3 years after the release of our first stage 1 & 2 TSI tunes, APR motorsport and our APR engineering teams have jumped deep into the TSI engine and even slept with pistons, injectors and turbos on their pillows at night. They've learned quite a bit, sweet talked the turbos and massaged the injectors. The result? Better tunes. :-)
Every now and then their will be a stubborn ECU that needs to be pulled to reflash but for the most part, it's all through the port.
Old 02-18-2011, 01:45 AM   #21
Arin@APR
Arin@APR's Avatar
Removal. Yes.
Modification. No.
It's just a software update. :-)
Old 02-18-2011, 06:00 AM   #22
A23
A23's Avatar
Drives: MKVI GTI
Removal. Yes.
Modification. No.
I just got the 6-hour trial from APR Malaysia last week and they did not need to remove the ECU. Just flashing through OBDII Port. Can you clarify?
A23 is offline   Reply With Quote
Old 02-18-2011, 06:21 AM   #23
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
Probably the encryption is a US thing, people from around the globe are all reporting chipping using only the OBDII port, i sent out my ECU to APR US, they are probably not going to open up the casing of the ECU.
SOLD -> MK7 R
Old 02-18-2011, 06:32 AM   #24
xHeartcoreboyx
Originally Posted by edgary View Post
I suppose that answers your question (emphasis mine)
It would probably be better to run the 95 ron file.
Basically, if your pulling timing because the fuel is not up to snuff, the ECU will pull a little more than it needs to pull, just to be safe. It may actually pull enough to make your timing advance less than what you would see on the 95 ron file. You can grab a vag-com, log, and test it our yourself to see.
That's a good point, i have been reading about this topic before and the car should run better on the appropriate map.
Another question..!
Is it OK to switch to stock mode with the APR 3" DP installed? will i get a check engine light for the dp?
Is it BAD to have the stage2 software with the stock DP?
I am asking this because i will be receiving the DP and chipped ECU from APR in like a week and half or so, i will install the ECU on my own at home and then drive my car to a good shop that will install the DP, should i switch to stock mode first?
SOLD -> MK7 R
Old 02-18-2011, 11:19 AM   #25
Arin@APR
Arin@APR's Avatar
Yes. Not all ECU's have the new encryption. North American ECU's were hit first and the hardest.
Old 02-18-2011, 11:24 AM   #26
Arin@APR
Arin@APR's Avatar
No CEL & it's not bad to do. :-)
To be safe, that would be the best idea.
Old 02-18-2011, 11:35 AM   #27
xHeartcoreboyx
Ohhh the excitement! thanks for the heads up
SOLD -> MK7 R
Old 02-18-2011, 11:40 AM   #28
omgturbo!
omgturbo!'s Avatar
Drives: 2010 GTI, blk full option - 6spd MT
i was just about to ask this but nevermind lol thanks!
REVO Stage 1 | Neuspeed P-Flo intake | Custom exhaust | Eurojet Downpipe | Yellow Nokya Fogs | BSH mount insert | VF Engineering Short Shifter | Tiquan pipe (Noise Pipe Delete) | 30% Front, 3% Rear Tint | 1000w JL Audio Amp and W7 Subwoofer | Video-In-Motion | Klii Vinyl rear/wheel insert | Smoked Sidemarkers | Everything LED | VagCOM by me!!
I have VagCOM! | My Feedback Thread! | HellaFast Autosport
omgturbo! is offline   Reply With Quote
