Old 02-17-2011, 06:30 PM   #1
vdoobie
vdoobie's Avatar
Rear VW Emblem Removal
Hi guys, there's probably a whole mess of threads on this but I don't want to search.
I've been wanting to Plasti Dip my rear emblem, and I would like to know how to remove it. So if anyone could lead me the right way or perhaps leave a DIY on here, I'll greatly appreciate it.
Thank you
2011 Candy White GTI 6 Speed Manual Transmission, Carbonio Stage 1, Magnaflow Cat Back, ST Coils, Golf R Tails, 8k HIDs, Nokya Hyper Yellow Fogs, 20% Tints, R-Dash License Plate LED, VMR 710's 18'
vdoobie is offline   Reply With Quote
Old 02-17-2011, 06:53 PM   #2
DubbinIt
DubbinIt's Avatar
Drives: 2010 CSGTI
It is easy! Took me three minutes yesterday to figure it out. Easiest way is just to use an old credit card and slip it underneath. There is a little slot on the bottom that you can just slip it into, then work your way around the underneath portion. Go along the right side edge with the card and it will pop right off!
2010 GTI APR Stg 2 (Gone)
My Build Thread
2013 TT-RS--in safe storage
2013 MINI Cooper S
DubbinIt is offline   Reply With Quote
Old 02-18-2011, 12:26 AM   #3
2010GTI4me
2010GTI4me's Avatar
Drives: MKV R32
Credit card method is definitely the best way to go. Just make sure you take your time or you could crack it pretty easily.
2010GTI4me is offline   Reply With Quote
Old 02-18-2011, 12:40 AM   #4
vdoobie
vdoobie's Avatar
Does the back part that's black come off with the emblem too? I wanted to color match that with the car (white) and then spray the emblem black.
Old 02-18-2011, 01:05 AM   #5
2010GTI4me
2010GTI4me's Avatar
Drives: MKV R32
Nope, to get that off you're going to have to do some work inside the hatch. Probably easier to mask the whole rear end of the car from what I hear lol.
Old 02-18-2011, 01:25 AM   #6
GTIRob
GTIRob's Avatar
Drives: 2010 Candy White GTI
Taking the whole black part out is easy! Takes maybe 5 minutes, just take off the rear lining, and theres 3 screws that hold it on, then it just twists off and comes out.
2010 CW GTI | Diesel Geek Short Shifter | VMR V701s | Rear Wiper Delete | BSH 27mm Rear sway | BSH Race Intake | ST Coilovers | 42DD DP | APR Stage 2
GTIRob is offline   Reply With Quote
Old 02-18-2011, 01:29 AM   #7
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
That's what I wanted to do too. Keep your cw brothers updated
Ps VW sells vinyl inserts in different colors for the black partition, I have been told.
SOLD -> MK7 R?
Old 02-18-2011, 10:01 AM   #8
2010GTI4me
2010GTI4me's Avatar
Drives: MKV R32
I've heard of it taking people an hour or more... maybe they are just incompetent haha.
Old 02-19-2011, 02:30 AM   #9
GTIRob
GTIRob's Avatar
Really? Wow I did it just the other day while I had the lining off in about a minute and had never done it before. I might be painting that thing white soon, too and wanted to see how hard it would be to take it out.
Old 02-19-2011, 12:32 PM   #10
SlammedGTi
Drives: 2011 Candy White GTi 6Spd
Okay, so If u take off the emblem..then the black piece behind it...is it just cw under neath all that..I'd like to have no emblems at all
SlammedGTi is offline   Reply With Quote
Old 02-19-2011, 02:22 PM   #11
DubbinIt
DubbinIt's Avatar
Drives: 2010 CSGTI
@OP: Just follow some of these steps if you haven't finished it already! I would recommend this versus masking off your rear. I would hate to get even small paint particles anywhere on my car.
Got mine done yesterday!
REMEMBER TO UNLOCK THE ENTIRE CAR AND NOT JUST POP OPEN THE HATCH WHEN DOING THIS WORK!
It's simple! It took me about half an hour plus the time I spent trying to get my keys out of my car after I locked them in... I locked both key fobs in the car and had to use my valet key--pop off the keyhole cover on the driver's door and unlock--and the car was locked, so the alarm went off and I had to crawl through my car to the trunk to get the keys, because the car disabled the unlocking due to the alarm.
1. So pop open your hatch, and remove the two screws in the grab slots using a torx screw driver (forgot what size).
2. Remove the access panels on the far sides of the hatch panel and begin to pop off the clips, starting from the bottom of the panel (edge closer to the ground when hatch is closed) and work your way up.
Here is the inside of the panel to find the clips
There are four on the bottom edge, one clip right next to each access panel, then eight clips up top--four major clips and two minor clips on both top corners.
The panel off appears like this
3. Now go the outside of the hatch and remove the dust cover of the wiper (starting from left to right--pop off the left side then pull it off), then the bolt holding on the wiper. I used a door panel remover to wedge and wiggle to remove the wiper between these two points.
After that, just lift the wiper off.
4. Go back inside and remove the three bolts holding the motor on, and unclip the power and control wire from the motor.
5. Now just slide the motor straight off and you will get this
6. From here, go back outside and pull the rubber seal straight out.
This is the result
7. Zip-tie the motor's power wire, and find a place to store it. I used a piece of synthetic padding to create a stable place against the inside of the hatch latch to keep it in place.
8. Now just wipe down the outside of the hole with 70% Isopryl Alcohol and install your piece! And voila!
9. This last step is just the obvious--to replace your panel and the rest.
Please let me know if I missed any steps, although I'm pretty sure I didn't
My de-badged, de-wipered MK6 GTI
My Build Thread
2013 MINI Cooper S
Old 02-19-2011, 02:24 PM   #12
DubbinIt
DubbinIt's Avatar
Drives: 2010 CSGTI
If I am not mistaken, it seems like you're wanting to get it shaved? Popping off the VW emblem itself will leave the black surface. The black surface is part of the entire module that unlocks the back door. Take off that module and there's a hole where you can see the inside of your hatch panel.
My Build Thread
2013 MINI Cooper S
Old 02-19-2011, 05:03 PM   #13
omgturbo!
omgturbo!'s Avatar
Drives: 2010 GTI, blk full option - 6spd MT
doing this will just pop out the chrome vw right?
so say i wantd to do the background red and the vw black, i would have to take off the plastic interior part of the hatch, take out the three screws, pull the whole assembly out, then do this ^ credit card trick around the chrome to separate that, paint them both, then reinstall in reverse?
and how does the vw go back onto the assembly? glue, clips, or what?
REVO Stage 1 | Neuspeed P-Flo intake | Custom exhaust | Eurojet Downpipe | Yellow Nokya Fogs | BSH mount insert | VF Engineering Short Shifter | Tiquan pipe (Noise Pipe Delete) | 30% Front, 3% Rear Tint | 1000w JL Audio Amp and W7 Subwoofer | Video-In-Motion | Klii Vinyl rear/wheel insert | Smoked Sidemarkers | Everything LED | VagCOM by me!!
I have VagCOM! | My Feedback Thread! | HellaFast Autosport
omgturbo! is offline   Reply With Quote
Old 02-19-2011, 06:39 PM   #14
LittleJohny
Drives: '10 CS GTI 6MT w/ RNS-510
I guess I'm incompetent then
When I removed the rear trim, it took me damn close to an hour. At one point I gave up and tried to work around it.
I suppose it's just how ballsy you are. The entire time I really felt like I was going to break something... those clips are immensely strong. My father and I were trying to find clever ways to gently pry them free.
Mods: Footwell LEDs | 9W3 Bluetooth Upgrade | Vagcom mods | 18" Hartmann HR8-MS (Audi R8 replicas) | Rear View Camera | DieselGeek Short Shifter | 15% / 30% Tint | Magnaflow CBE | LED Tail Lights | LED License Plate Lights
Wishlist: Cold Air Intake | Colour Matched Side Markers
LittleJohny is offline   Reply With Quote
