Old 03-06-2011, 06:49 PM   #1
ataman
Erasing Fault Codes via Vag-Com
I am trying to erase fault codes, when I go each controller, I do not see any fault codes but when I do a Auto-Scan, they still show up....
How can I can delete fault codes from all logs?
2011 GTI 4 Door DSG / APR Stage 1 / Carbonio Intake / S3 IC / AWE TOP / Rear Camera / Escort 9500ci / VAG COM / LED Interior / Euro Switch
ataman is offline   Reply With Quote
Old 03-06-2011, 07:13 PM   #2
LittleJohny
Drives: '10 CS GTI 6MT w/ RNS-510
When I go into the controllers I see the fault codes just fine...?
Mods: Footwell LEDs | 9W3 Bluetooth Upgrade | Vagcom mods | 18" Hartmann HR8-MS (Audi R8 replicas) | Rear View Camera | DieselGeek Short Shifter | 15% / 30% Tint | Magnaflow CBE | LED Tail Lights | LED License Plate Lights
Wishlist: Cold Air Intake | Colour Matched Side Markers
LittleJohny is offline   Reply With Quote
Old 03-06-2011, 07:24 PM   #3
ataman
When i go to each control module, click on fault codes, it says " no fault codes found"
When i do a auto scan, i end up with bunch of fault codes.
Old 03-06-2011, 07:35 PM   #4
Djunited
Djunited's Avatar
Drives: K04 GTI
happens to me as well. i even get cruise control fault code and front sensor code even though i don't have either
BUILD THREAD bczracekar VIDS
Old 03-06-2011, 07:44 PM   #5
LittleJohny
Weird... I don't know how to help... all I can say is mine works as intended.
For example when I go into Engine and click Fault Codes, I see the same cylinder misfiring errors you saw (but for different reasons).
Old 03-06-2011, 09:17 PM   #6
ataman
I am trying to delete them. I saw them before as well. I clicked erase... They disappeared from the control module but not from auto scan.
Old 03-06-2011, 09:29 PM   #7
Keithuk
Keithuk's Avatar
Drives: 2010 Golf GTD (170)
After you do an Autoscan and it finds faults in one section or more. You click the Clear All DTCs button and it clears all fault codes and rescans. Does it still show faults in each section or just the numbered sections at the top?
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
I can clear the faults and after a rescan it still shows these at the top and it shows No fault code found in each section.
Can you post your log file? Which version of Vag-Com are you using?
http://www.ross-tech.com/vag-com/tour/autoscan.html
Keith
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Keithuk is offline   Reply With Quote
Old 03-06-2011, 09:44 PM   #8
ataman
[Clear All DTC's]
This function is only available when using a HEX Interface and is implemented in two ways. On pre-CAN vehicles, VAG-COM will access each control module and clear DTCs from each one individually. On vehicles using CAN for diagnostics, VAG-COM performs this function without accessing all the control modules individually. If you are not using a HEX Interface then you'll need to go into each module that has faults to clear them individually.
I am using CAN, so I can not click this. I go to each control module and erase it. But it still show up here is the log
VCDS Version: Release 10.6.3
Data version: 20101206
Sunday,06,March,2011,14:36:54:57528
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 47 52 55 56 62
72 77
VIN: WVWHV7AJ6BW140543
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Sporadic communication error 1000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AP HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH18--- Serial number:
Coding: 0403010A1C070160
Shop #: WSC 01357 011 00200
VCID: 74C90BB86E3D
3 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 1923 km
Time Indication: 0
Date: 2003.14.22
Time: 11:20:13
Freeze Frame:
RPM: 6378 /min
Load: 85.1 %
Speed: 125.0 km/h
Temperature: 94.0C
Temperature: 10.0C
Absolute Pres.: 960.0 mbar
Voltage: 14.224 V
000771 - Cylinder 3: Misfire Detected
P0303 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 1923 km
Time Indication: 0
Date: 2003.14.22
Time: 11:20:13
Freeze Frame:
RPM: 6378 /min
Load: 85.1 %
Speed: 125.0 km/h
Temperature: 94.0C
Temperature: 10.0C
Voltage: 14.224 V
000770 - Cylinder 2: Misfire Detected
P0302 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 1923 km
Time Indication: 0
Date: 2003.14.22
Time: 11:20:13
Freeze Frame:
RPM: 6378 /min
Load: 85.1 %
Speed: 125.0 km/h
Temperature: 94.0C
Temperature: 10.0C
Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 054 L HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2602
Revision: 05351112 Serial number: 00001010060481
Coding: 0000020
VCID: 1F633414B73B
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 114B600C492600FA881006E8921C0041350800
VCID: 76CD31B07841
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 1524 km
Time Indication: 0
Date: 2003.14.16
Time: 20:38:32
Freeze Frame:
Count: 3
Count: 12
Count: 12288
Count: 397
Count: 44544
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_Climatronic_VW36.rod
VCID: 6EFD19D00011
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AE
Coding: 67180A3A88272AC40088008170008F0442050386534D8D20E4 8860240040
VCID: 3A55E5800CD9
Part No: 5K1 955 119
Component: Wischer 20101 26 0512
Coding: 009795
5 Faults Found:
01504 - Bulb for License-Plate Light (X)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 7
Reset counter: 89
Mileage: 1524 km
Time Indication: 0
Date: 2003.14.16
Time: 21:03:24
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01502 - Bulb for Rear Fog; Left (L46)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 1524 km
Time Indication: 0
Date: 2003.14.16
Time: 21:03:37
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
00984 - Left Tail Light (M4)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 4
Reset counter: 89
Mileage: 1524 km
Time Indication: 0
Date: 2003.14.17
Time: 06:49:30
Freeze Frame:
Term 15 On
Voltage: 14.20 V
ON
ON
Term 50 Off
OFF
ON
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 89
Mileage: 1524 km
Time Indication: 0
Date: 2003.14.17
Time: 06:49:30
Freeze Frame:
Term 15 On
Voltage: 14.20 V
ON
ON
Term 50 Off
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 89
Mileage: 1525 km
Time Indication: 0
Date: 2003.14.17
Time: 15:31:50
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R018AJ+
Coding: 00003042
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3957FA8C09DF
Driver's Airbag Crash Sensor:
Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME00231259ZZZF
Passenger Side Airbag Crash Sensor:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME004A135AZZZR
Driver's Rear Airbag Crash Sensor:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME1606747FZZZ.
Passenger's Rear Airbag Crash Sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME22427500ZZZE
Driver's Front Airbag Crash Sensor:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME425D2024ZZZ8
Passenger's Front Airbag Crash Sensor:
Component: F.Sens.Beif --- ----
Serial number: 35627SME41302024ZZZ-
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JJP001NH
Coding: 189A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 76CD31B07841
MFL:
Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Serial number: 0168287
Coding: 830000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H20 0420
Serial number: 00000000000000
Coding: 370D00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: F1C782AC912F
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 221010F1002404
Coding: 350002
VCID: 3041C7A8DAA5
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 91
Mileage: 1558 km
Time Indication: 0
Date: 2003.14.18
Time: 16:14:16
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 91
Mileage: 1558 km
Time Indication: 0
Date: 2003.14.18
Time: 16:14:16
03272 - Control Module for Audio Interface
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 91
Mileage: 1558 km
Time Indication: 0
Date: 2003.14.18
Time: 16:14:16
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAF595C0BCF9
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668848666
Coding: 010000
VCID: 27732CF4EF6B
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
Component: RNS-MID H10 1040
Revision: AB001001 Serial number: VWZ6Z7K6295046
Coding: 240700400100009000
ASAM Dataset: ------------------------- ------
VCID: 236B38E49B53
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 89
Mileage: 1520 km
Time Indication: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2151
Coding: 0001204
VCID: 334BC8A42BB3
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 3147C2ACD1AF
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109106130
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1_VW36.rod
VCID: E7F3ECF4AFEB
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 3245CDA0D4A9
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1446940
VCID: 3449CBB82EBD
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
1 Fault Found:
02629 - Sensor for Swivel Module Position; Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 96
Mileage: 1731 km
Time Indication: 0
Date: 2003.14.20
Time: 19:25:46
Freeze Frame:
Voltage: 13.63 V
Speed: 39.0 km/h
ABS 1
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 236B38E49B53
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 89
Mileage: 1520 km
Time Indication: 0
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 354FF6BC25C7
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 364DF1B038C1
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668793737
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA_VW36.rod
VCID: 3245CDA0D4A9
3 Faults Found:
9457427 - Negative output audio channel for speech/telephone
B104F 13 [008] - Open Circuit
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 91
Mileage: 1558 km
Date: 2003.14.19
Time: 11:17:07
9457171 - Positive output audio channel for speech/telephone
B104E 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 91
Mileage: 1558 km
Date: 2003.14.19
Time: 11:17:05
0022 - Radio: No Communication
U1066 00 [008] - Short to Plus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 1558 km
Date: 2003.14.19
Time: 11:17:10
End ---------------------------------------------------------------------
A lot of these faults happened when I was playing with bulbs and installing rear camera. Only the headlight and misfire are real...
Old 03-07-2011, 12:54 AM   #9
ataman
I managed to get them deleted! User Error!
Old 03-07-2011, 05:41 PM   #10
Keithuk
Keithuk's Avatar
Revision: 00H31001
VCID: 76CD31B07841
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 1524 km
Time Indication: 0
Date: 2003.14.16
Time: 20:38:32
Freeze Frame:
Count: 3
Count: 12
Count: 12288
Count: 397
Count: 44544
Count: 0
Count: 0
Count: 0
I get that exact error on mine and I clear all errors but is still shows
I also get
Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
Component: BCM PQ35 M 103 0575
Revision: 00103 AG
Coding: 48180A3A9025F1C044080080340001E443510088536D816064 8000200000
VCID: 306A9D7CDAA5
Part No: 1K2 955 119 F
Component: Wischer 16120 21 0512
Coding: 009795
Part No: 1K0 955 559 AH
Component: RLS 211209 05 54 0402
Coding: 0330AD
Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Part No: 1K8 951 605
Component: LIN BACKUP HO H10 9003
1 Fault Found:
00897 - Windshield Washer Pump (V5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 199
Mileage: 8538 km
Time Indication: 0
Date: 2010.14.23
Time: 16:36:30
Freeze Frame:
Term 15 On
Voltage: 13.90 V
ON
ON
Term 50 Off
OFF
OFF
but the windscreen washers have always worked as ther should do they never miss a beat.
I wonder why it shows your Date: 2003.14.16 it won't be that old will it?
So what did you do to clear the codes?
Keith
