Old 08-23-2011, 10:19 PM   #43
bubuski
El Moderador
bubuski's Avatar
Drives: MK6 GTI 5-door TR
Is there a technical difference between the IHI Hybrid and a BW K03?
Old 08-24-2011, 05:39 AM   #44
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Actually there is. I didnt know at the time I made this thread that there were two different turbos floating out there. The IHI is fractionally smaller but has CLOSE to the very same characteristics as the K03. Apparently it has a lot more lower end pull and runs out of breath quicker, than the K03.
I'll do some research today to see what I can find and edit my post appropriately. It came as quite the shocker when I found out though!
In my head --> "I just made this awesome thread about compressor maps and the K03.................a few weeks later.............FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU"
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 08-24-2011, 10:03 AM   #45
DRedman45
DRedman45's Avatar
Drives: UG '10 4dr gti(sold)-E86 //M coupe
Send a message via AIM to DRedman45
Haha yeah the bw k03 was on the fsi...ihi turbos ar notorious for not having anything on the top end
DRedman45 is offline   Reply With Quote
Old 08-25-2011, 08:07 AM   #46
ChippedGTI
ChippedGTI's Avatar
Drives: 2010 2D Candy White GTI
How incompetent can people be that they don't even know the turbo that is in the vehicle they drive? How can we sticky a discussion on this forum when the topic being talked about is a turbo that we dont even have in our cars! We have a IHI not a K03 for the love of god people learn what the hell you are talking about.
2010 Candy White GTI/ 6 Speed Manual/ Unitronic Stage 2/ A&L 3" Catless Downpipe/ MagnaFlow Catback Exhaust/ DevilsOwn Water/Meth DVC 30 Kit/ S3 Intercooler/ AWE S3 Hoses/ AWE Turbo Outlet Pipe/ AWE CCB Intake/ BSH VTA Race Catch Can/ BSH Integrated Throttle Body Pipe/ BSH Torque Mount Insert/ VF Engineering Short Shifter/ Noise Pipe Delete/ Revision D Diverter Valve/ AWE Vent Boost Gauge/ KSport V2 Coilovers/ VMR V710 18"
ChippedGTI is offline   Reply With Quote
Old 08-25-2011, 08:36 AM   #47
grambles423
Limited Activity
It was a simple mistake. You learn something new everyday. I knew all along there was a similarity between IHI and K03, even when I made the thread. The point was to provide the understanding of why the power fell off so drastically. Not to compare the two, or make it a pissing match. Thats why it was stickied.
Old 08-25-2011, 12:43 PM   #48
NS01GTI
Drives: 2012 GLI K04
NS01GTI is offline   Reply With Quote
Old 12-09-2011, 10:56 PM   #49
Peteriroc
Peteriroc's Avatar
Drives: Scirocco 2.0 TSI APR
Great post!!!
This days Ive been searching for tech info like this .
My question is:
Which is the cause of the extra power in the 2.0 TSI compared with EA113 + k03????
Is the new engine EA888 or the IHI??
First of all ---> IHI Turbo vs k03:
About that Ive got contradictory data based on my own experience and data logging.
On the one hand, if we only read the maximun pressure generated at 6k rpm the k03 may be larger than IHI:
k03 --> can get 1 bar at 6000 rpm (TFSI + STG 2 (CAI + DP))
IHI ----> can get 0,84 bars at 6000 rpm (TSI + STG 1 + CAI)
But, on the other hand, the same day we got this maximun pressures in VCDS, we also roll the dyno in both cars with the same weather conditions, and we got this:
Dyno Graph: TSI with STG 1 + CAI vs TFSI with STG 2 (CAI + DP))
So the TSI only needs 0.84 bars to generate more TOP END POWER (280Cv cranck), than the TFSI with 1 bar (274Cv cranck with more mods than the TSI).
This could indicate the IHI is bigger than the k03 --> with less pressure at 6k get more HP.
Other data could indicate the IHI is between the k03 and the k04 is this:
K03 ---> Load a 2000 rpm
IHI ----> Load a 2500 rpm
K04 ----> Load a 3000 rpm
Considering same displacement 2.0 liters, the IHI is bigger than the k03 and smaller than the k04.
You could also see this behavior in the above graffic on the dyno, below 2500 rpm the k03 has more torque than the IHI due to his small size, but beyond 2500 rpm the IHI has more power...same test could be done when you compare the IHI vs K04....
So, the time turbo takes to load with same displacement indicates turbo size
Second matter --> TSI/EA888 vs TFSI/EA113
Everybody knows the new TSI is an upgrade of the TFSI engine:
http://www.golfmk6.com/forums/showpo...99&postcount=8
So this could be the reason why the TSI performs better than the TFSI.
I mean if data about the turbo size are finally proven (with data not opinions ) we could determinated where the extra power comes:
1.- If IHI > K03 -------- extra power in TSIs would come from the turbo not the new engine
2.- If K03 > IHI -------- extra power in TSIs would come from the new engine not the turbo.
In conclusion, if we have a better engine block (TSI), with a bigger turbo like a k04 we could get more TOP END than a TFSI (rated in 360Cv cranck with a STG 2+)
Sorry for all this heavy data
Best regards.
Scirocco 2.0 TSI /K04 --> 410.5 Cv - 616.8 Nm Crank (104 file) // 357 whp & 395 wtq .....APR K04 v2!!!
http://www.golfmk6.com/forums/showthread.php?t=50509
http://www.golfmk6.com/forums/showthread.php?t=56571
Peteriroc is offline   Reply With Quote
Old 12-10-2011, 01:08 AM   #50
DRedman45
DRedman45's Avatar
there are so many more factors other than the turbo that explain why the tsi makes more power
the TSI(ea888 w/ IHI turbo) has a better flowing head, stronger rods, better fuel system including direct injection, and is chain driven
the FSI(ea113 w/ k03) actually has a stronger block...and the "new" ea113 w/ k04 has a stronger bottom end and better cams
these factors make it impossible to compare the differences in the IHI turbo on the tsi and the k03 on the fsi based off of dynos of the two
I will miss my K04 gti
Old 12-10-2011, 06:49 AM   #51
Peteriroc
Peteriroc's Avatar
We agree "there are so many more factors other than the turbo that explain why the tsi makes more power"
As I said, there can be two factor, the engine or the turbo:
You told, in other post, IHI is smaller than k03 (any tech data to prove that??) so the extra power wolud come from the new TSI engine (better HPFP, I think is the main reason).
So if we have a better engine block (TSI), with a bigger turbo like a k04 + TSI we could get more TOP END than a TFSI + KO4 (rated in 360Cv cranck with a STG 2+).
What do you think?
Regards
Old 12-12-2011, 01:33 AM   #52
DRedman45
DRedman45's Avatar
What do you think?
Regards
I do not know the exact compressor, tubrine, ar on the IHI and k03, but i do know for a fact the k03 has a slightly larger cold side
The tsi will make more power than an equally moded fsi for sure for k03, k04, gt28, or gt30...the fsi however has a stronger block and can support more bore than the tsi, so the huge HP fsi's still have the stage 3+ tsi's beat
Old 12-12-2011, 09:28 PM   #53
Peteriroc
Peteriroc's Avatar
This is what Mike@Forge said about new TSIs
- Lower compression forged pistons
- strengthened connecting rods
- enlarged wrist pins
- stronger piston rings
- upgraded bearings
- reinforced engine block
- upgraded camshafts (longer duration, same lift)
- upgraded injectors (+13% flow)
- larger K04 turbo producing 1.2 bar of boost (+3 PSI over K03 equipped GTI)
- larger intercooler (+30%)
- relocated bypass valve
For his words I undestand TSI has a stonger block no??
There is also this pictures from APR...
Anyway the only reason for the extra powe is a better HPFP the other data aims to durability not performance.
What do you think DRedman45??
Best regards
Old 12-12-2011, 09:35 PM   #54
DRedman45
DRedman45's Avatar
I agree with you completely...i have been haha
internally the tsi is stronger stock than the fsi for sure...the actual block itself is stronger on the fsi though....that, plus the easy to upgrade fueling, and the availability of more aftermarket internals(cams, valvetrain, big bore pistons) is the only thing the fsi has going over the tsi
in a couple years when we start getting aftermarket cams with ported and polished heads with an apr stage 3+ set up there will be huge numbers out of the tsi
Old 12-18-2011, 08:46 PM   #55
Peteriroc
Peteriroc's Avatar
+100
Time will clarify the TSI vs TFSI performance
Old 12-18-2011, 08:49 PM   #56
Peteriroc
Peteriroc's Avatar
Here you are a K03 from a TFSI
These are the Turbo Oulet Pipe from a k03 vs k04
