#1 |
![]() Drives: 10' Black GTI MT Join Date: Mar 2011
Bluetooth 9w7 / RCD-510 Problems.
I got my new Bluetooth module. Install was easy but I'm having a couple issues.
SPECS: 2010 MK6 GTI / RCD-510 and an iPhone 4 with latest software non jailbroken. (Also tested iOS 5). 1) There's supposed to be three icons on the MFD display. Battery, Bluetooth, and iPod icons... I only have the Bluetooth icon and two small squares where the other icons are supposed to be. My phone is an iPhone 4 with no jailbreak and the latest software. 2) My voice activation is not working AT ALL. I can press the largest button on the center roof console but it doesn't make any sound or do anything. Any suggestions? Maybe this is a defective unit? Brandon
Cosmetic: Cleaned Visors | 20% Tint | Seat Handle Inserts | Golf R LED Tailights | EuroSwitch | Mudflaps Performance: APR ECU Stage 2 | APR Carbonio Stage I | EuroJet Gen2 TBE | DieselGeek SS | AutoTech Insert Last edited by Brandonjjon; 07-03-2011 at 12:52 PM. |
#2 |
![]() Drives: 2010 UG GTI 2Dr "Gus" Join Date: Aug 2010
I have the two small squares with mine. Im not sure whats going on with the voice activation, maybe you need to do some coding?
#3 |
Most people have said that it's just plug and play.. with OPTIONAL coding for the multi function steering wheel to change the mute button to the push-to-talk button. :/ But apparently the center roof console button (largest button of the three) is supposed to automatically work.
Cosmetic: Cleaned Visors | 20% Tint | Seat Handle Inserts | Golf R LED Tailights | EuroSwitch | Mudflaps Performance: APR ECU Stage 2 | APR Carbonio Stage I | EuroJet Gen2 TBE | DieselGeek SS | AutoTech Insert |
#4 |
Bump :/
#5 |
I would try unplugging it then plugging it back in...
#6 |
I did that. No resolve. :/
#7 |
![]() Drives: Rising Blue Golf R 2-Dr Join Date: Apr 2010
I have recently installed my 9w7 and Im experiencing the same issue.
2012 RB Golf R NAVI/SUN / KESSY / APR STG 1+ / APR HPFP / OEM Golf R Tails / Euro-Switch / APR FMIC / VWR Intake / RNS-510 / 9w7 premium BT Sold: 2010 CW 2DR GTI |
#8 |
![]() Drives: 2010 Gti, 2002 Gti Join Date: Apr 2010
Those modules do require coding, have either of you scanned the car with VCDS? If so post the Auto-Scan with the 9W7 installed.
#9 |
![]() Drives: 2010 GTI 4 dr CSG 6 MT Join Date: Jul 2010
Did any of you get the problems with the voice activation and the missing icons resolved?
I'm interested in upgrading to 9w7 as well for my RCD-510 unit, but it depends on how much of a pain it's gonna be to get those things worked out. I'm thinking that maybe the RNS-510 only displays all the icons. The voice activation needs to work though I thought only the voice command button on the steering wheel needs to be recoded to work while the overhead button should already work. |
#10 |
![]() Drives: 2010 CS 5 Door GTi & Other VWs Join Date: Feb 2010
This will not help but atlas give you hope. I just got the 9W7 and have the 2010 GTi with RCD510. It was indeed plug and play with the car. It paired no problem. I do have all three symbols on the MFD. The overhead button works for voice dialing. The button on the steering wheel will need coding from Vag for PTT. The LED overhead no longer works (expected).
Only advice I could offer is the delete the phone and re add it. Atop of that I would remove the 9W7 and e connect it. Another thought although I do not know if this matters but have you updated your stereo firmware? Kevin |
#11 | |
#12 | |
. So aside from that I have an iPhone 4 (go figure ... I am a corporate rep from Apple ...) Yes all three symbols come up. Such a worth while upgrade! Kevin ![]() |
#13 | |
Wow, good deal! That's good to know the module can work. That's gives me an idea... I may try finding a totalled newer VW with 9w7 at a wrecking yard or someplace.
#14 |
![]() Drives: 2010 Jetta Sedan Join Date: Jun 2011
I have 9w7 and have used it with RCD510 and RNS510 and have all the icons including battery and signal strength when its connected to my iPhone 4 (I have white display on a 2010 Jetta)
either you guys have the 9w3 or incorrect coding. Can you post your model number of the Bluetooth module and the code in 09-Elec? |
#15 |
![]() Drives: VW Golf MK6 Join Date: Jun 2011
Hi, I just completed the install of a 9w7 unit (or 9ZB which is also A2DP compatible) in my car.
The module 7P6035730E is connected to the RNS510 and only bluetooth icon shows in MFD with _ on either side...so it's like _bluetooth icon_. There is no battery level meter showing which I understand should show on iPhone 4. I also tried with Nokia 6300 and still only bluetooth icon. Perhaps this is why I am having issues playing back A2DP audio, sometimes it works, sometimes it doesn't... I checked in VCDS and there are no fault codes coming up for the telephone or nav unit. Please can you help? Thanks. |
#16 |
![]() Drives: Volkswagen Golf TDI 2010 Join Date: Jul 2010
Hello folks ! I'm having a 9W7 installed (7P6 035 730 D), and also at the same time a brand new RNS 510, latest north american release with voice control. The 9W7 seems to be coded properly and have no fault with a scan, but I don't have the battery/Ipod Icon on the MFD. Anyone can help me ?
Here's the complete scan of the car: VCDS Version: Release 11.11.0 Data version: 20111111 Wednesday,30,November,2011,09:34:40:27645 Chassis Type: 3C0 Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 53 55 56 62 6D 72 77 VIN: WVWNK73C99E082728 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb Part No SW: 06J 906 026 AF HW: 06J 906 026 AF Component: MED17.5 TFSI 2,0 3318 Revision: AAH03--- Serial number: VWZCZ000000000 Coding: 0404010A18070160 Shop #: WSC 05314 000 00000 VCID: 6EFD1513798C1AE No fault code found. Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb Part No SW: 3C0 614 109 P HW: 3C0 614 109 P Component: J104 C4 440 V2 0011 Revision: --025--- Serial number: 00000786264969 Coding: 0000373 Shop #: WSC 05311 000 00000 VCID: 2B7BDC078A1E2F6 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE Component: Climatic PQ35 143 1313 Revision: 00143033 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 70C10B6B63B80CE No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 E HW: 3C8 937 049 E Component: Bordnetz-SG H54 2602 Revision: 00H54000 Serial number: 00000009027449 Coding: 078C8F0500041A0A470000000F000000001B55435C00012000 0000000000 Shop #: WSC 05124 000 00000 VCID: 334BC467522E776 Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB Component: Wischer 180908 003 0205 Coding: 00046997 Shop #: WSC 05124 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 HW: 5N0 959 655 Component: J234__003 VW10 HI 1815 Revision: 19013000 Serial number: 0039BPMPBGF8 Coding: 0012339 Shop #: WSC 05311 000 00000 VCID: FAD5A943B5C4C6E No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE Component: J0527 0020 Revision: 00026000 Serial number: 3C9953507CP Coding: 0000312 Shop #: WSC 05311 000 00000 VCID: 6FC308177E86136 Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb Part No SW: 3C0 920 871 R HW: 3C0 920 871 R Component: KOMBI H04 0107 Serial number: 00000000000000 Coding: 360F00 Shop #: WSC 05311 115 00000 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040 ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod VCID: 334BC4679A2E776 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 L HW: 3C0 907 951 Component: J533__Gateway H13 0152 Revision: H13 Serial number: 3300P08B060530 Coding: F9817F06420612002002 Shop #: WSC 05311 000 00000 VCID: 2A75D90385E436E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 AT HW: 3C0 959 433 AT Component: IMMO 042 0383 Revision: 00042000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 7CD92F5B3FF078E Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380 No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl Part No SW: 5N0 035 342 B HW: 5N0 035 342 B Component: SG EXT.PLAYER H13 0090 Revision: A1001003 Serial number: 7668030844 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 266D2D3351FC12E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 3C0 035 684 F HW: 3C0 035 684 F Component: RNS-MID H59 2625 Revision: AB001001 Serial number: VWZ6Z7L4206071 Coding: 04000402040000810000 Shop #: WSC 00001 001 12345 ASAM Dataset: ------------------------- ------ VCID: 266D2D3351FC12E 2 Faults Found: 01550 - Signal for Reverse Gear 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 33 Mileage: 38952 km Time Indication: 0 Date: 2098.14.17 Time: 09:31:11 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 33 Mileage: 38952 km Time Indication: 0 Date: 2098.14.17 Time: 09:31:16 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N Component: J386 TUER-SG FT 1517 Revision: 72009005 Serial number: 00000820289006 Coding: 0001205 Shop #: WSC 05311 000 00000 VCID: 6FC308177E86136 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 5N1-909-144.clb Part No SW: 5N1 909 144 J HW: 5N1 909 148 F Component: J500__APA-BS KL.081 0502 Revision: 1AH02240 Serial number: 00081990370602 Coding: 0000258 Shop #: WSC 05311 000 00000 VCID: 3957F64F70428D6 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 AT HW: 3C0 959 433 AT Component: KSG PQ46 ELV 042 0612 Revision: 00042000 Serial number: VWZCZ000000000 Coding: 1A900E80D103807F7F041415F08A0F0E087C01 Shop #: WSC 05311 000 08193 VCID: 7CD92F5B3FF078E Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N Component: J387 TUER-SG BT 1517 Revision: 72009005 Serial number: 00000666689004 Coding: 0001204 Shop #: WSC 05311 000 00000 VCID: 70C10B6B63B80CE No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 5N0-907-801.clb Part No SW: 3C8 907 801 A HW: 3C8 907 801 A Component: J540 EPB3 VW-10498 0003 Revision: 009 Serial number: 00000000189527 Coding: 0000057 Shop #: WSC 05311 000 00000 VCID: 2871230B9BE804E No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0136 Revision: 00H04000 Serial number: Coding: 2323457 Shop #: WSC 05311 000 00000 VCID: 3449C77B572070E Subsystem 1 - Part No: 7L6 941 329 A Component: AFS-Lst.-Modul l 0004 Coding: 00000035 Subsystem 2 - Part No: 7L6 941 329 A Component: AFS-Lst.-Modul r 0004 Coding: 00000035 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 3C0 035 684 F HW: 3C0 035 684 F Component: RNS-MID H59 2625 Revision: AB001001 Serial number: VWZ6Z7L4206071 Coding: 04000402040000810000 Shop #: WSC 00001 001 12345 ASAM Dataset: ------------------------- ------ VCID: 266D2D3351FC12E 2 Faults Found: 01550 - Signal for Reverse Gear 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 33 Mileage: 38952 km Time Indication: 0 Date: 2098.14.17 Time: 09:31:11 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 33 Mileage: 38952 km Time Indication: 0 Date: 2098.14.17 Time: 09:31:16 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 AD HW: 1K0 959 795 P Component: J388 TUER-SG HL 0307 Revision: 42004101 Serial number: 00000000676739 Coding: 0001168 Shop #: WSC 05311 000 00000 VCID: 72C501636DB43EE No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: None Part No SW: 3C9 827 383 F HW: 3C9 827 383 F Component: J605 HECKDECKEL 0720 Revision: 00H27001 Shop #: WSC 05314 000 00000 VCID: 3449C77B572070E Part No: 3C9 827 384 F Component: J756 HECKDECKEL 0720 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 AD HW: 1K0 959 794 P Component: J389 TUER-SG HR 0307 Revision: 42004101 Serial number: 00000000677311 Coding: 0001168 Shop #: WSC 05311 000 00000 VCID: 73CB046712AE376 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb Part No SW: 3C8 035 730 B HW: 3C8 035 730 B Component: Telefon 011 0723 Revision: -------- Serial number: 35909603195473 Coding: 030000010100010000000000 Shop #: WSC 00001 002 12345 ASAM Dataset: EV_UHVPremi A02003 ROD: EV_UHVPremi_VW46.rod VCID: 2265312335D4EEE No fault code found. End ---------------------------------------------------------------------
2014 Mazda CX-5 GS AWD (wife's car) 2012 Volkswagen Golf R 6 speed 2011 Audi S4 premium, Navi and Bang 6 speed 2011 Ford Mustang Shelby GT500 convertible 6 speed Last edited by lemarin; 11-30-2011 at 10:13 AM. |
#17 | |
#18 |
![]() Drives: one with 4 wheels Join Date: Aug 2010
sorry to thread jack, but is it the RCD or the RNS that has Navigation? I have the version that does not have Navi.
#19 |
#20 |
| Thread Tools | Search this Thread |
| Display Modes | |
