Old 07-07-2011, 08:55 PM   #15
steelcurtain
Drives: '12 Audi TT-RS
I've updated the photo album with some better pics of the dirty valves and removed the bad pics. I've also placed some helpful installation notes in the description fields of the photos that have titles (excluding the cylinder pics).
'09 GTI TSI - 11.53@121.18
steelcurtain is offline   Reply With Quote
Old 07-08-2011, 12:19 AM   #16
Halvie
Drives: 2010 Penalty Box
Originally Posted by steelcurtain View Post
Thanks! 48k on the car.
First time the valves were cleaned? Those look cleaner than mine at 15k...must have gotten myself a real gem
Old 07-08-2011, 01:06 AM   #17
driftingti6
Drives: mk6 2010 4 door
great write up, bookmarked, but i dont think i could do it myself, how much the dealer charge it to do it?
driftingti6 is offline   Reply With Quote
Old 07-08-2011, 01:08 AM   #18
Halvie
My shop charged 2 hours, so like $200. Almost easier to have someone else do it, but I wouldn't mind learning how.
Old 07-08-2011, 01:14 AM   #19
DBESTGTI
DBESTGTI's Avatar
Drives: 2011 Stage 2 GTI
I would also like to point out something about the fuel injectors. If they stay in the head your fine, if any pull out of the head your not fine. There is a Teflon seal on the injector to seal it to the head, it's a one time use seal and you can not replace it without a VW special tool and some know how.
Old 07-08-2011, 01:37 AM   #20
sukanas
sukanas's Avatar
Drives: 2010 GTI CSG MT
hrm... all this looks somewhat "new" to me. would it be fair to say this is the same level of difficulty as doing coilover installations? haha
2010 GTI: 2 Door, MT
sukanas is offline   Reply With Quote
Old 07-08-2011, 09:18 AM   #21
steelcurtain
Good point. A bad seal was what motivated mento pull the mani. If you look in the pics, the injector in cyl 3 is gone. There was no seal, it was gone. This allowed the injector to just come out with the mani.
There is a special tool to install the seals but didn't use it and had no issue but the seal does get slightly stretched when applying by hand. I figured the seals would shrink back to their original diameter with the heat and pressure of the combustion chamber.
I highly recommend pulling your injectors to check on the seals. All o mine were damaged except one but I've Been chipped since 500 miles and run water meth. I you buy new injectors the seals come on them. The I Hector repair kit comes with a different type "holder" for the injector to fit into the bore. Two of the four original holders were cracked.
Old 07-08-2011, 01:32 PM   #22
DBESTGTI
DBESTGTI's Avatar
As someone who works on VW's for a living I completely disagree with your thoughts and methods involving direct injection injectors. I urge people to have the one time use seals done correctly, there's no point in going through all this work then half assing the details.
Old 07-08-2011, 07:51 PM   #23
bewshy
Drives: 2011 Black GTI 4dr DSG
I've seen the tool run from $150 - $250. Ouch.
bewshy is offline   Reply With Quote
Old 07-09-2011, 09:13 AM   #24
steelcurtain
Exactly. Myself and others have not used the tool without issue. Is it the correct way? No. Does the injector still seal replacing them by hand? Yes. For me and others it did. Can you screw it up so it creates an issue? Yes. Choose your method wisely.
I guess it wouldn't take much to take your injectors to the dealer to have a VW mechanic use the tool to perform the procedure properly. I can appreciate doing things the right way.
This DIY is not about replacing the injectors or seals so let's move on.
Old 07-09-2011, 09:18 AM   #25
DBESTGTI
DBESTGTI's Avatar
It's part of doing the job, but since it doesn't shine a positive light on your DIY yes we can ignore it if you'd like. I wanted to make sure those interested knew the correct way, but your right they can choose your way instead of they want. I'll leave it alone.
Old 07-09-2011, 09:39 AM   #26
steelcurtain
I'm not trying to ignore anything. It has nothing to do with shinning a positive light. I referenced there was a tool for doing it the correct way in my original post.
It's just that the tone of your responses have come across as being a little snide IMO. There is no reference to injector seal removal or replacement in this DIY so IT IS completely off topic.
Old 07-09-2011, 10:16 AM   #27
DBESTGTI
DBESTGTI's Avatar
lol
ok ok I'm done for real this time
Old 07-09-2011, 11:41 AM   #28
steelcurtain
lol
In the DIY troll. Not the comments after the OP.
