Old 02-24-2010, 01:42 PM   #1
bubuski
El Moderador
bubuski's Avatar
Drives: MK6 GTI 5-door TR
VAG-COM (VCDS) helper
Many thanks goes to the author of Waks Wide Web as ALOT was borrowed from it.
What is VCDS?
VAG-COM Diagnosis Software.
What is VAG-COM?
A common misconception of VAG-COM is that it is a VAG group product used by dealers to do "something" with the cars ECU. It is NOT. Dealers use the VAS 505x devices which are explained in the thread linked.
VAG-COM is an independently written PC application that Ross Uwe originally wrote as a tool to check out his own car and be a useful tool to the enthusiast community. It basically combines the diagnostic abilities of a number of dealer only electronic gizzmos and puts their power into the hands of owners and enthusiasts.
With an appropriate cable it can be utilised to examine any VAG group cars ECU for diagnostics and maintenance procedures. It is also used to tweak settings and enable features deactivated for certain markets.
The software is downloadable and a cable can be bought from Ross-tech as they deliver internationally.
What do I need?
You will need to download the VAG-COM software. In basic form it can only read error codes for you.
A dongle adapter is needed to connect your laptop/computer to your VW.
In order to clear codes and change functions in the vehicle, the VAG-COM software can be activated in one of 2 ways.
1. Buy a cable from Ross-tech.
The cable will cost you between US$249-349 depending on the version you want. The license is built into the Ross-tech cables so can be easily moved from one laptop to another. The cable somehow extracts a license to the software which enables full access to the software. Links for Cables and prices. The Micro-CAN (USB) is the cheapest option which supports most newer VAG cars including the Mk6. But you can but the HEX-USB+CAN (USB), HEX-COM+CAN (Serial) or Micro-CAN (USB) for your Mk6.
2. Ross-tech sells the software only with a license for fee of $99, for those who have an interface cable. The license is not transferable and they will not provide hardware support.
What about ebay cables?
At the moment, the cheap Ebay cables do not support Can-Bus in newer VAG cars. Even if you find one, As ChicityGTI said "I would only trust Ross-tech with the cables...cheap e-bay alternatives just don't sound too appealing when playing around with the ECU on a 25k piece of machinery."
I personally have read about cheap vag-com cables burning the USB ports on laptops. Although, I have not read about the vehicle port being burnt out which will be very bad.
What to do first?
When you have your cable, you'll need to know where to plug it in.
The diagnostic port(DLC Location) on a LHD Mark 6 is under the dash, to the left of the steering wheel.
For ALL the features plug your cable into your PC and car, then switch the IGNITION ON to ACC.
For any of the real time live data reading, the engine must be STARTED as well.
Aftermarket Radio? Read http://www.ross-tech.com/vag-com/aftermarket-radio.html
Will you rather find someone with a Ross-tech cable to help you for $20, a 6-pack or FREE?
Go to the weekly meets in your area or try the links below at your own risk.
VAGCOM finder.
http://vagcomlocator.com/
http://www.vagtoolfinder.com/
Remember - Autoscan, save file.
http://www.ross-tech.com/vcds/tour/autoscan.html
http://www.ross-tech.com/index.html
http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
***At your own risk. It is always recommended to perform a complete AutoScan and save it prior to coding changes. All codings might not work on all vehicles due to production changes.
This is just a guide so I am not responsible for any damage or problems that may result from following these instructions. Remember to save the old settings before any change.***
What MK6 tweaks can I do?
http://wiki.ross-tech.com/wiki/index...K/52%29_Tweaks
How do I data log?
ID:	10975  Click image for larger version
Old 02-24-2010, 07:25 PM   #2
pyro h4cker
pyro h4cker's Avatar
Drives: MKVI
Great start let's keep this going
pyro h4cker is offline   Reply With Quote
Old 02-24-2010, 08:27 PM   #3
jmblur
Drives: MkVI GTI 2dr DSG CSG
From Dana @ Ross-tech (http://forums.vwvortex.com/zerothread?id=4743553)
Daytime Running Lights
- 09-central elect. Coding, Long Coding helper, the lamp systems are different:
--- Factory Xenon – Byte 11
--- Factory Halogen – Byte 15
Emergency Brake Warning active
Flashes hazards when "emergency braking" detected
- 09-central elect. Found in Coding, Long Coding helper.
Auto-Lock
- 09-central elect.Found in Coding, Long Coding helper.
Coming Home
If the vehicle is not equipped with an "Auto" headlight switch, coming home activation will likely require you to pull the high beam stalk back briefly after shutting the vehicle off and before exiting. The description should be found in your owners manual.
Leaving Home
Leaving home will likely require the "Auto" switch and a light sensor. The description should be found in your owners manual.
Alarm Confirmation via lights and horn
I've been told it's possible to set up fogs as DRLs - but haven't seen a how to. Any leads?
jmblur is offline   Reply With Quote
Old 02-25-2010, 01:19 AM   #4
euro89
euro89's Avatar
Drives: CW MK6 GTI, Manual
http://forums.vwvortex.com/zerothread?id=4724268
euro89 is offline   Reply With Quote
Old 02-28-2010, 02:50 AM   #5
kimsballs
Drives: 2010 GTI Manual United Gray
Any one here have a VAG in Germany, buy you a bottle to do a couple options for me.
kimsballs is offline   Reply With Quote
Old 02-28-2010, 05:37 AM   #6
LittleJohny
Drives: '10 CS GTI 6MT w/ RNS-510
Are all vag-com cables the same? From what I've been able to learn, the only requirement for the mk6 is that the cable supports the CAN interface. I've seen a few on eBay that claim to do this, would I be able to use this cable to make the same programming changes? Will I be able to run the Ross-Tech software (would I need to?)?
LittleJohny is offline   Reply With Quote
Old 02-28-2010, 11:10 AM   #7
pyro h4cker
Drives: MKVI
you would need to run vcds (ross tech software) and they're key encryptions are built into the cable, so i doubt the ebay cable will work
Old 03-20-2010, 07:37 PM   #8
LittleJohny
From member jmblur:
Gauge sweep:
Only works with cluster codes that end in "H" (US) or "D" (Europe) - "G" will not work! an error will be shown if you try and your car can't support.
VCDS Version 912 beta
Select under 17 Instruments -> Adaptation -> Staging
and activate.
Driver's heated seat memory:
08 Auto HVAC -> Adaptation
"Storage of seat heater level driver" from drop down. Change to On and Save.
Again, won't work with all cars - option will just not be there.
Cornering lights:
In 09 Central Electronics, Long coding, Byte 14
Maybe this thread should be sticky'd?
Old 03-25-2010, 12:15 PM   #9
gunmetal5
gunmetal5's Avatar
Drives: GTI 2010
This seems like it would be a great mod. The unit seems expensive though. Does anyone in socal, LA area have a unit they'd be willing to share?
gunmetal5 is offline   Reply With Quote
Old 03-25-2010, 03:07 PM   #10
dstill
Drives: Mk6 Golf 140 TDi SE
From member jmblur:
Gauge sweep:
and activate.
Cornering lights:
Bubuski, where would i find the code for my cluster?
Thanks in advance.
dstill is offline   Reply With Quote
Old 03-25-2010, 03:47 PM   #11
bubuski
El Moderador
bubuski's Avatar
Thanks in advance.
The only way I know is through VCDS.
Old 03-25-2010, 08:44 PM   #12
bubuski
El Moderador
bubuski's Avatar
Original post updated.
Old 03-27-2010, 07:47 PM   #13
DRDUNKS
Drives: MK6
Has anyone used a VAG-COM to disable the TPMS (Tire-pressure monitoring system) on a mk6 golf/gti? If you have could you post what steps you did to deactivate the TPMS?
Thanks in advance for your time and advice.
Reason why i am asking…
I just took off my winter stock steelies and put on my 18" audi wheels. The audi wheels don't have the TP sensors so i'm stuck with the TPMS error light always on.
DRDUNKS is offline   Reply With Quote
Old 03-27-2010, 07:53 PM   #14
2010 UG
Drives: United Gray MKVI GTI
Just the other day I asked the same thing from someone who has apparently done it.
http://www.golfmk6.com/forums/showthread.php?t=4657
2010 UG is offline   Reply With Quote
