Old 07-18-2014, 07:06 PM   #225
corman1313
corman1313's Avatar
Drives: 13 CW GTI DE
Figured it out. The coding was right. After searching all over I found one post from someone who has the same set up I do and he had the Black28 and brown and Tan27 switched and only the left LED was working. The DIY I followed to wire the rear fog said to leave Tan27 unplugged because it isn't needed after swapping in Black28 but after going back and plugging Tan27 into Black28 it worked. So the right LED DRL is powered by Tan27 or its connected to it somehow. So everything works as it should. Thank you for the help you have given. Learned a lot from this thread.
corman1313 is offline   Reply With Quote
Old 07-18-2014, 07:45 PM   #226
zVp
zVp's Avatar
Drives: 2012 Black GTI (DSG)
Glad you got it working
2012 DEEP BLACK PEARL GTI
zVp's Car Journal
Old 07-13-2015, 08:59 PM   #227
Azzore
Azzore's Avatar
Drives: 2010 VW GTI 4dr
Sorry for bringing this post back from the dead but I just got a Vagcom cable and first thing i did was auto scan the car.
I almost shit my self while the program scanned my car. I hear this electrical noise and i'm thinking the car better not burn on me anyway so after the code scans and everything is done i got some errors. After poking around i found out that each time i go to Navigation and hit scan errors it gives me the same weird electrical noise that comes from under the steering wheel. near the cable and all the cables actually.
So should i check to see if one of the Navigation wires is not connected right?
btw i got my car used and everything inside is from factory, no warranty.
First engine code is probably because of my forge bov adapter that's leaking boost. just swapped it with DV+ so i'll clear that one out later.
Monday,13,July,2015,11:41:12:13234
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
www.Ross-Tech.com
VIN: WVWHD7AJ6AW239171 License Plate: GONEIN3
Mileage: 84170km-52300mi Repair Order:
Chassis Type: AJ (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 65 72
77
VIN: WVWHD7AJ6AW239171 Mileage: 84170km-52300miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AL HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H21--- Serial number:
Coding: 040301081C070160
Shop #: WSC 01357 011 00200
VCID: 70C1210F6390A1A19EF-8025
1 Fault Found:
050217 - Implausible Data Received from Steering Column Control Module
U0429 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 84038 km
Time Indication: 0
Date: 2015.07.08
Time: 09:15:14
Freeze Frame:
RPM: 1286 /min
Load: 8.2 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 73.0°C
Absolute Pres.: 960.0 mbar
Voltage: 12.065 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 053 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2113
Revision: 51112 Serial number: 00000911160842
Coding: 0000020
VCID: 14094D9F37483D81DA7-8041
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C49250003880C06EB921A0041310800
VCID: 7AD50327F5ECEBF120B-802F
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW32.rod
VCID: 75CF101BD4F284894D9-8020
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AE
Coding: 6D180A1E90272AC480080081700005C441010086434D8D6064 8020200000
Shop #: WSC 22116 444 11182
VCID: 354FD01B9C72C4898D9-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 24110 21 0512
Coding: 009795
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 90
Reset counter: 192
Mileage: 81470 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.40 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0A2UUI
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: 3957DC2BB86A20E9691-806C
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0004WU2C00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME0738534EZZZ.
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME7003624DZZZT
Crash sensor for side airbag; rear; driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME1A1C4102ZZZM
Crash sensor for side airbag; rear; passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME2E484152ZZZW
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME4754731EZZZL
Crash sensor for front airbag; front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME7119421FZZZH
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
VCID: 76CD171701F48F91443-8023
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 270F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09B270C4A
Coding: ED807F07400612000002
Shop #: WSC 22116 444 57724
VCID: 69F74C6B404A5069D91-803C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AF533678D4C5B71D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667692730
Coding: 010000
VCID: 266D075751D4BF11343-8073
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
Component: RNS-MID H04 0980
Revision: AB001001 Serial number: VWZ6Z7J6335121
Coding: 040004000400009600
VCID: 236B1E4322E64A3953D-8076
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 254
Reset counter: 154
Mileage: 11024 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 194
Mileage: 15311 km
Time Indication: 0
Date: 2011.06.27
Time: 07:06:28
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2113
Coding: 0001204
VCID: 3147E40BA81AE8A9D11-8064
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 3245EB07AD1CD3B1A8B-8067
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 154
Mileage: 11024 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 194
Mileage: 15311 km
Time Indication: 0
Date: 2011.06.27
Time: 07:06:28
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 3449ED1F5708DD81BA7-8061
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018704
Shop #: WSC 22116 444 83888
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0001168
VCID: 354FD01B5C72C4898D9-8060
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 20389520297761
Coding: 412100
VCID: 2A75F36745CC9B7110B-807F
End-------------------------(Elapsed Time: 01:55)--------------------------
Thanks for your help!
- Moe
2010 MK6 GTI "GONEIN3":
Akrapovic slip on + CTS catless downpipe | JDL 3 inch custom intake | GFB DV+ | CTS throttle pipe + discharge pipe | H&R super sport springs | Cobb Tuned | BSH Engine mounts kit | CTS FMIC
Azzore is offline   Reply With Quote
Old 07-14-2015, 12:12 PM   #228
Thumper
Thumper's Avatar
Drives: 15 Audi S3/'15 Audi S4/'15 328dx SW
Ok, the noises are normal, it's the system cycling, powering, repeating, etc. It's generally the Airbag and Steering systems that do this.
The first fault in the Navigation is for the satellite tuner (if it's not activated it shows as a fault), the second one does show as a short. Does your GPS work? Any issues?
The light switch fault, does this have a euro switch by chance? I got that error constantly on mine after installing a Euro Switch.
The engine one, if you check that code at ross-tech, it states it just is a reference to the actual fault, in this case the steering wheel module. Most likely this is due to the light switch fault.
So other than maybe a loose connector to the GPS antenna, doesn't look like any real issues there.
2012 GTI 4dr Black Pearl 6spd w/Xenons - Check out my Build thread "The Wraith" - SOLD
2015 Misano Red S3 w/Sport Pack
2015 Sepang Blue S4 S-Tronic | ADS
2015 Alpine White BMW 328dX Touring M-Sport
Thumper is offline   Reply With Quote
Old 07-14-2015, 03:30 PM   #229
Azzore
Azzore's Avatar
First of all, thanx for the response.
I cleared the engine codes, and the light switch.
Yes I do have the euro switch, just took it off and cleared the code. If it's normal i'll put it back on.
The weird scary noise happens when i go to fault errors in Navigation, it also happens when i code the navigation. It is scary as hell btw.
I think it might be a loose wire or something, but it's working fine for me, never had any issues with it.
I will be updating the RNS510 to version 4120 today. Hopefully it will be easy.
Thanks,
Moe
Old 07-20-2015, 11:29 PM   #230
Furioustylez75
Drives: 2014 GTI 2.0L TSI
Does anyone know the coding for bulb out error for a 2014 gti with installed LED fogs using Vag-Com? I read a couple of forums about the tail light coding, but don't know if it will work with LED fogs.
Furioustylez75 is offline   Reply With Quote
Old 10-18-2017, 12:18 AM   #231
detroit
Drives: Fahrvergnügen
Originally Posted by k0mpresd View Post
not sure if this has been posted anywhere.
plugin for better coding descriptions on abs module long coding.
changed my coding from 288mm front to 312mm front since i have gti carriers and rotors.
http://www24.zippyshare.com/v/1513575/file.html
Instructions:
Start LCode.exe (found in the directory of VCDS)
copy your LongCoding ABS module 03 in box 1)
then click on "READ INFO TEXT FILE" and select the file eng-mk60ec1.xpl
I saw this years ago and glad I found it again today after upgrading to 312mm rotors. Thanks, dude!
detroit is offline   Reply With Quote
