Old 10-22-2010, 01:10 PM   #57
Dana @ Ross-Tech
Drives: 2010 Gti, 2002 Gti
Originally Posted by cleanmk6 View Post
What do you mean by cornering lights using fogs?
On vehicles with factory fog lights, the 09 - Central Electronics (BCM) module can be coded to enable this feature. When you turn the wheel -or- turn on the turn signal (depending on the coding selections) the fog light turns on that side of the car.
This deactivates at higher speeds, perhaps over 15 ~20 Mph, but don't hold me to that value. Also see the "--- Lighting ---" section in my Mk6 thread for the coding.
This is not the same as the Xenon AFS "steering" lights, or the Corner Lights feature. The Adaptive Frontlight System is controlled by the Xenon module ( Address 55 ).
VW Golf/Golf Plus (5K/52) Tweaks
Dana Marie < - Yes that means I'm not a dude
Dana @ Ross-Tech is offline   Reply With Quote
Old 10-25-2010, 07:19 PM   #58
Mk62010
Drives: 2006 Jetta 2.5, 2011 GTI CW
I just run Vag on my car and found some error can someone help me to figure it out?
The problem with my parking light is because i replaced it with another bulb so it's through codes so it's fine but i don't know what wrong with the cornering lamp and the electrical malfunction ??
Thanks!!
Here are the code :
1 Fault Found:
530190 - Local Databus: Electrical Malfunction
U1030 00 [008] - Defective
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 115
Mileage: 1600 km
Date: 2001.14.29
Time: 2336
4 Faults Found:
02235 - Stationary Cornering Lamp (Left) (M51)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:04:18
Freeze Frame:
Term 15 On
Voltage: 12.90 V
ON
ON
Term 50 Off
OFF
OFF
02236 - Stationary Right Cornering Lamp (Right) (M52)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:04:19
Freeze Frame:
Term 15 On
Voltage: 12.95 V
ON
ON
Term 50 Off
OFF
OFF
02395 - Parking Light Right Front (M3)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:05:00
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
Term 50 Off
OFF
OFF
02394 - Parking Light Left Front (M1)
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:05:01
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
Term 50 Off
OFF
OFF
Mk62010 is offline   Reply With Quote
Old 10-25-2010, 08:35 PM   #59
LittleJohny
Drives: '10 CS GTI 6MT w/ RNS-510
^ Looks like your headlight fluid may be a bit low
LittleJohny is offline   Reply With Quote
Old 10-25-2010, 09:32 PM   #60
Dana @ Ross-Tech
Thanks!!
Stationary Right Cornering Lamps aren't installed in the Golf, so it looks like the 09 coding is messed up. You may have a bulb check issue beyond any "cold lamp diagnosis" coding tweaks if they aren't resistor style bulbs.
Please edit that to include the complete module ID, or better yet, post the complete Auto-Scan. If you have the original coding please include it.
Old 10-25-2010, 09:48 PM   #61
Mk62010
thanks for helping is the full scan
VCDS Version: Release 10.6.1 (x64)
Data version: 20100831
Monday,25,October,2010,19:08:27:59633
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 77
VIN: WVWFV7AJXBW052358
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: None
Part No SW: 1K0 907 115 AP HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0020
Revision: AAH18--- Serial number:
Coding: 0403010A1C070160
Shop #: WSC 01357 011 00200
VCID: 74C910B06EC9
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 053 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2208
Revision: 05151112 Serial number: 00001005050789
Coding: 0000020
VCID: 20612CE08AB1
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 114B600C492700FC880E06E992210041310800
VCID: 8429C070BE69
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_VW36.rod
VCID: 7EDD32985085
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AE
Coding: 6D180A3F80272A040088008165004904404C0086534D8D6064 8020200040
VCID: 3A55FE880C2D
Part No: 1K1 955 119 F
Component: Wischer 10071 21 0512
Coding: 009795
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:04:18
Freeze Frame:
Term 15 On
Voltage: 12.90 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:04:19
Freeze Frame:
Term 15 On
Voltage: 12.95 V
ON
ON
Term 50 Off
OFF
OFF
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:05:00
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
Term 50 Off
OFF
OFF
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:05:01
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00RDXX
Coding: 00003042
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3957E184092B
Driver's Airbag Crash Sensor:
Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1E4A0355ZZZZ
Passenger Side Airbag Crash Sensor:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME32230256ZZZH
Driver's Rear Airbag Crash Sensor:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME0C4C6511ZZZW
Passenger's Rear Airbag Crash Sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME36155350ZZZK
Driver's Front Airbag Crash Sensor:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME46113322ZZZ+
Passenger's Front Airbag Crash Sensor:
Component: F.Sens.Beif --- ----
Serial number: 35627SME5B103322ZZZ4
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JFO00067
Coding: 189A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 76CD2AB878B5
MFL:
Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0007636
Coding: 830000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 115
Mileage: 1600 km
Date: 2001.14.29
Time: 2336
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H04 0406
Serial number: 00000000000000
Coding: 370F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: F1C799A491DB
Address 19: CAN Gateway Labels: 7N0-907-530.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 150710F2000857
Coding: ED811F0600160200000000
VCID: EDFF85D48DE3
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R9S5D06
Coding: 0000002
VCID: FEDDB298D085
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0406
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAF58EC8BC0D
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 3147D9A4D15B
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 3147D9A4D15B
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2149
Coding: 0001076
VCID: 3449D0B02E49
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1446940
VCID: 3449D0B02E49
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H13 0043
Revision: -----26S Serial number: VWZ4Z7K1150821
Coding: 2500040004
VCID: 61E769E4C13B
Address 77: Telephone (J412) Labels: None
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668394431
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA_VW36.rod
VCID: 3245D6A8D45D
1 Fault Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [000] - Open Circuit
Freeze Frame:
Fault Status: 00000000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
End ---------------------------------------------------------------------
Old 10-26-2010, 06:01 PM   #62
Dana @ Ross-Tech
Revision: 00104 AE
VCID: 3A55FE880C2D
Coding: 009795
4 Faults Found:
014 - Defective
014 - Defective
ROD: UHVNA_VW36.rod
VCID: 3245D6A8D45D
1 Fault Found:
Byte 14, Bit 6 looks like the problem in the 09 module. It looks like stationary cornering lights (like the Tiguan / Passat would have) are enabled. Please copy and paste this coding in, and watch the space the forum font slips in:
6D180A3F80272A040088008165000904404C0086534D8D6064 8020200040
Do you have the overhead roof telephone button console installed? I don't think so based on the CA market, so try coding the 77 module to: 0A00000000010110
Old 10-26-2010, 07:19 PM   #63
Mk62010
I do have the overhead roof telephone button. and i don`t really understand this`*Please copy and paste this coding in, and watch the space the forum font slips in:
6D180A3F80272A040088008165000904404C0086534D8D6064 8020200040*
Sry i am a noob.
Old 10-26-2010, 07:23 PM   #64
Mk62010
Sry i am a noob.
NEVERMIND! This work like a charm! thanks alot ! Error code gone for the cornering light!! is there anyway to get ride of the parking light error code since i bought some bulb that throught codes. Or changing the bulb would be the only way? Thanks again !!
Old 10-27-2010, 10:27 PM   #65
Dana @ Ross-Tech
Good deal! The 30 Byte coding strings (60 digits) end up with a space between bytes 24 and 25. So, pasting that in would result in an error. I should have been more specific ;-)
I doubt the parking light fault code can be fixed with coding. This is in Byte 18 and please read up on that byte before making any changes! I have this linked from the Mk6 Vortex sticky in my sig:
http://forums.vwvortex.com/showthrea...1#post67300665
Also look at the LED tail retrofit thread, which discusses Byte 18, you will find in the "Retrofits" links.
That BCM you have is the newest SWL and even the comfort turn signals seem to be fussy when altering the number of flashes. I would look for special cheater bulbs.
Old 10-28-2010, 07:29 PM   #66
Mk62010
Yea ! I pasted it and it didn't work and I realized that little spacing.
Alright going to look throught the link. If i save the Coding that i have now for back up and if anything wrong after I will just have to put this code back and it will come back to now right?
Old 10-28-2010, 08:21 PM   #67
roastpuff
roastpuff's Avatar
Drives: Mk6 GTI
Hey Dana, do you know if there is any visible difference in steering coding between cars equipped with the DCC suspension and non-DCC cars?
Old 10-30-2010, 06:36 PM   #68
Dana @ Ross-Tech
Well, you can save the coding I modified and paste it in to restore defaults, BUT this does not apply to Byte 18. Meaning, once you have changed the Byte from Hex value from the "00" shown to any other value, simply pasting the original coding back in will not restore the exterior lighting scheme.
All of the other Bytes (29 in this case) are okay and will restore to the proper function / settings.
Please check those links out before you end up with a weekend of Byte 18 coding and experimenting. If you have already tweaked it, 03 should restore the lighting as mentioned in the VW Vortex post on a US/CA Golf.
Most of the 44-Steering Assist modules do not support coding. Do you have a scan from the car in question, or scan from a vehicle with Address 14: Susp. Elect. (J250) / Adaptive Chassis Control factory installed?
If you were referring to the address 16-Steering wheel module, I would say probably not to the coding. Some of the 2010 and newer cars use UDS modules, and they use a completely different coding chart.
Old 10-30-2010, 08:07 PM   #69
roastpuff
roastpuff's Avatar
Drives: Mk6 GTI
I have a scan from a US-spec GTI, but these do not come with ACC installed so that's an issue... I am trying to determine whether or not extra coding is needed because supposedly the ACC will change the steering assist ratio.
Guess I need to find a Euro-spec vehicle with DCC installed and have them do an Auto-scan.
Old 10-31-2010, 11:43 AM   #70
AdeVill
Drives: Golf Mk6 1.4TSi
Hi Dana. Maybe you could help me. I got a 2010 1.4TSI comfortline (midline) and i see that the highline models's MFD has a nice big display of the car doors when opend and also access to the comfort settings menu, etc. Will it be possible to enable those features on mine with some nice software tweaks ?
AdeVill is offline   Reply With Quote
