Old 12-21-2011, 10:11 AM   #57
alexgc
alexgc's Avatar
Drives: 09 GTI K04, 86 Scirocco 16V
Originally Posted by Bender View Post
any bending concerns on those nurburgrings in the mid atlantic?
No problems here with my Nurburgrings - lots of potholes and extremely uneven roads in South Jersey, took the abuse from that like a champ.
Cars: 2009 GTI (AWE K04 turbo kit, and too many more mods to even count ), 1986 Scirocco 16V
2012 SCCA South Jersey Region SMF class champion
alexgc is offline   Reply With Quote
Old 12-21-2011, 10:20 AM   #58
RacingManiac
RacingManiac's Avatar
Anyone has pics of 17" PF01s?
Old 12-21-2011, 11:11 AM   #59
SwiftGTI
SwiftGTI's Avatar
I generally avoid potholes when I drive, but I've hit a couple of fairly large ones and they've held up fine. Tough wheels relative to the weight.
As a general rule, if you're looking for light AND durable, go with wheels that are flow-formed (TSW Nurburgring/Interlagos, OZ Alleggerita HLT, RAYS, Forgestar) or if you've got money to burn, true forged wheels (HRE, DPE, certain BBS). A lot of the lightweight gravity cast wheels out there are pretty fragile.
SwiftGTI is offline   Reply With Quote
Old 12-21-2011, 11:21 AM   #60
Dub_Monk
Dub_Monk's Avatar
To the guys with the Nurburgrings what tires specs are most of you running? I plan on lowering in the spring so I'm thinking 215/40??
IG: dub_monk
Dub_Monk is offline   Reply With Quote
Old 12-21-2011, 11:55 AM   #61
alexgc
alexgc's Avatar
I'm running the stock size tire for 17's - 225/45.
Old 12-21-2011, 11:57 AM   #62
Dub_Monk
Dub_Monk's Avatar
You lowered or lowering?
IG: dub_monk
Old 12-21-2011, 12:14 PM   #63
alexgc
alexgc's Avatar
I'm lowered on Bilstein PSS10's. I think my fender-ground measurement is around 25" or 25.5" at all four corners.
Old 12-21-2011, 12:18 PM   #64
Dub_Monk
Dub_Monk's Avatar
When you get a chance post some pics of your ride Id like to get a look
IG: dub_monk
Old 12-21-2011, 12:22 PM   #65
alexgc
alexgc's Avatar
Ask and ye shall receive:
I was running, earlier this summer, close to 24" fender-ground. But, when I autocrossed at this configuration, the front fender liners were scraping the ground constantly. So, this necessitated the ride-height increase.
Old 12-21-2011, 12:54 PM   #66
Dub_Monk
Dub_Monk's Avatar
My main concern is rubing. I will be going with 18s but with stock tire on them Im not sure if it will rub.
Im planing on putting on streetlines in the spring. Not slamed by any means.
IG: dub_monk
Old 12-21-2011, 11:23 PM   #67
alexgc
alexgc's Avatar
If you don't set the Streetlines to such a low setting and you use the stock tire size for the 18" wheel (225/40), then you shouldn't have any rubbing issues. I'm sure other people will chime in here.
Old 12-22-2011, 12:31 AM   #68
rizzogti
rizzogti's Avatar
Drives: 2010 CW GTI 6sp
I have the streetlines and I have minimal rubbing only when I turn the wheel all the way.. Also roll your fenders just to be safe. Chopped up my tires pretty good... However I'm almost as low as they go so i don't think you'll have an issue. I'm on stock tires btw.
Originally Posted by GTI787 View Post
I LOVE LITTLE BOYS!!!
rizzogti is offline   Reply With Quote
Old 01-12-2012, 06:48 PM   #69
ZeroRt
ZeroRt's Avatar
Drives: 2012 GTI DSG - CSG
Will be mounting these as soon as I have time. Which I don't have.
TSW Interlagos. Tires are Conti DW 225/40/18
Equals over 11 lbs of unsprung weight per corner versus the Detroits and Pirellis
ZeroRt is offline   Reply With Quote
Old 01-12-2012, 06:51 PM   #70
maxtdi
GolfMK6 Elite
maxtdi's Avatar
39.8? That sounds way too light that scale may be off. The tire alone is about 26lbs which would put the wheel at 13-14lbs.
