Old 07-26-2011, 09:08 AM   #29
RacingManiac
RacingManiac's Avatar
From personal experience, I've done NVH, BSR (Bump Squeak Rattle), Windnoise and Driving Experience evaluation for JD Power IQS activities. Its nothing more than sitting in a car and going with your instincts on what rides good and what sounds are annoying. It can be very subjective sometimes, thats why we use a lot of transducers, microphones, and frequency modulators to accurately quantify those characteristics, so its not totally based off someone's opinion. However, experience starts to trump the doubt.
Ah, but thats not ride work. Ride engineer although speaking of rattling and sound, is mostly concerned with ride. Its hard to talk to them sometimes, as you build your shock, you hand it to them and have it installed on the car. They go out and drive around some ride loop, come back and they tell you what is wrong with it. A lot of it is just a feel thing. It can be how the sharpness in a bump is tuned out or not, or how the body settles after a whoop or a dip. The car at this point usually will be fully instrumented with string pots, accelerometers to try to find some data to correlate to the event they describe but at the end of the day their butts are the key....
OEMs keep these guys around for a long time....and I often hear when some OEs changed their ride engineer that the next batch of products don't ride the same as before because of it...
IMO unlike objective handling and balance, which coming from a racing background is easier to fathom and deduce as the data are easily correlate-able, ride work is an art in itself....
Old 07-26-2011, 09:18 AM   #30
Erwan
Thanks for the info, I'll def have to spend some time and try to do some calculations.
However I do have one comment for anyone reading this, learn to drive your car and push its limits before you start playing with suspension....I don't know how many times I've heard people tell me they want coils or suspension upgrades to improve handling when all they do is drive on the street and barely push the car. Trust me the car's stock suspension is very capable, I've been tracking my car a fair amount this summer and I can tell you that my suspension has not been a limitation. My driving and learning to drive a car to its limits is the first issue....I'm now looking into getting a rear sway bar but again I'm just now pushing the car to the point where I will be able to make use of this sway bar.
All in all just take a step back and think about what you're going to be doing and how much you've actually pushed the car, is the suspension REALLY limiting you and your driving? Ignore this rant if you're lowering your car for looks haha
Old 07-26-2011, 09:27 AM   #31
RacingManiac
Originally Posted by Djunited View Post
don't all the major suspension companies out there do these calculations before they release their products? i don't care much about the ride comfort. i want to enjoy twisty mountain roads so firmer is better for me. they probably lower the car by 1" all around.
edit: posted right after you did so did not see your post
They might, but a car company usually spend 2-3 years engineering a car, with a huge staff of engineers with teams specifically focused on something like ride and handling, vs a aftermarket company who tries to put a product out 6 month or a year after the debut of a new car. The amount of work put in is not comparable. Now most of these stuff gets installed by owners who can't or won't bother to compare result, so all they need to do is convey subjectively that it feels better to drive. And much like TechEd's post on Vortex mentioned, the car lowered with stiffer spring or damper will feel more alert, more responsive, but is it ultimately more capable is up for debate....we don't run downforce, we don't need absolute flatness of the chassis or maintaining ride height. Mechanical grip comes from tires and presenting the suspension to what the tires want. That is the whole deal with keeping the ride height within the range of the stock ride height, because that's where OEs designed the suspension kinematic based on the tire characteristic. And unless you actually objectively measure gains or losses its hard to draw accurately how you have affected the car. It might feel better at 5/10th because you are working the tire harder with more load transfer due to stiffer ride, but it may well start to over work the tire at 6/10th or 7/10th and you have a very difficult car to drive. And in real world where the surfaces are not always glass smooth, bumps that might get damped out or controlled stock may well have you get into bump stop(if you are lowered) and kick you off your intended line....
This is not to say you can't get better than stock, just if you really want to you need to be prepared to do it methodically....
Old 07-26-2011, 09:32 AM   #32
RacingManiac
Absolutely....it also helps in my case in my first autoX with this car to have someone more experienced drive my car and was easily a couple of sec faster. If I can't get there by myself then there is no point making my car faster...
Old 07-26-2011, 10:05 AM   #33
ElectricEye
ElectricEye's Avatar
Drives: '15 MK7 GTI Reflex Silver
Originally Posted by Hilfloskind View Post
I really believe after experiencing this process myself that, without being scientific about it, going from stock to coils and back gives you an appreciation for the fine tuning that goes into this car's suspension engineering. I just don't think anyone less than a perfectionist with solid understanding of mechanics would be able to maintain or extract true performance gains from a lowered setup on these cars. At minimum, having corner balancing done seems like a requirement for anyone looking for more than to "get rid of that gap".
Agreed
I've always been of the mindset that the vehicles engineers worked their buts off in designing and tuning the suspensions on this and other performance cars.
I find it comical to read posts where people insist on getting rid of wheel gap, or cry "lower it" to everyone.
It borders on obsessive.
Those German engineers know what they are doing, and I'm sure they try countless variations to come up with the - yes compromise - they choose.
Yet some "tool" with a couple of dollars to spend thinks he can do better in his driveway.
I love this thread, I thank you - and will now go back to learning.
"The right car for our times. Hell it's the right car for any time."
"What the world really needs now is not cars that are fast, but cars that are practical , fuel efficient, and fast." - The GTI is all of this and more: Automobile Magazine
ElectricEye is offline   Reply With Quote
Old 07-26-2011, 02:39 PM   #34
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Actually, it is. Its more so the post production evaluation, but when we develop a vehicle, at our various build events we test drive the vehicle and verify build characteristics and design impementations that have been revised or have been completely changed from model to model. Literally, I hop in a vehicle, drive it into the ground and evaluate what needs to be changed, whether it be suspension components or exterior functions. I guess I should accurately say my post is an afterthought to the whole Vehicle design process.
All of this is during the prototyping phase (which is directed toward what you were talking about) and later on the pre production build phases. Normally by the latter, we have fully hashed out all design issues and are focusing more so on production related occurances and supplier part maturation. But, as you described above, the EXACT process when we develop suspension characteristics always happens before our protyping phases, normally with current production models. That is why you see test mules look like shit because they are carrying new technology with an older body style and to mimick tests that would be seen in a new platform is quite difficult. But luckily we can quantify using our various test benchmarks that we've collected from part prototyping.
Maybe it would be easier to mention that I DO work for an OEM as a Vehicle design quality engineer and we DO part testing exactly as you named above. Actually I know a buddy of mine that was responsible for a design change for Ford's revoknuckle system that saved them a lot of money and actually quelled torque steer by a factor of 5%. Not bad......
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 07-26-2011, 02:44 PM   #35
grambles423
Limited Activity
Originally Posted by ElectricEye View Post
Agreed
We do, as a team. I know guys in our chassis group that absolutely despises modification to the suspension just because they work so hard to fine tune it to have some Joe Schmo destroy it.
I agree, which is why I'm trying SO HARD to figure out how to make my car perform with better aftermarket parts...or just go back to stock. I wonder if people actually realized how much thought went into making the suspension perform the way it does........Whenever vehicles are designed, there is sort of what they call a "THEME" to every project. One of the GTI's theme was defintely suspension compliancy. Thats why it does so well stock. Then people have to wreck it and slam it to the ground and expect the ride to be not affected.
I bought the car with Neuspeed Sport Springs and Bilsteins Sport Shocks and I immediately could tell there is absolutely no communication between spring and shock. I really would love to go back to stock, but I feel I would miss my ride height (Which i could get over eventually). I think FSDs might be the perfect balance.
Old 07-26-2011, 02:54 PM   #36
Hilfloskind
Hilfloskind's Avatar
Drives: 2011 GTI CSG 4d/6s
I agree about the theme. One of the legendary features of this vehicle is the handling performance...
Originally Posted by jackgti View Post
But I just got the cat-backs so maybe ill invest in some nice downpipes in the future
Grambles' Unicorn Gym Theory
My Build Thread
Hilfloskind is offline   Reply With Quote
Old 07-26-2011, 02:56 PM   #37
Bender
Bender's Avatar
Drives: 2014 Focus ST
This thread
Seriously though this is about as informative as they get.
What springs are you thinking of running with the FSDs?
Old 07-26-2011, 02:57 PM   #38
ElectricEye
Thanks for your response grambles423 - I'm truly a laymen, and will readilly admit it.
That's why it's so great to hear from someone who obviously knows what he is talking about.
Yes, I've always imagined suspension engineers cringing at what some people do to their hard work.
I don't golf, but I find it similar to someone going out and buying an expensive set of clubs, taking them home and filing down the heads.
Then saying "Bro' looks great!"
Great? You just ruined them!
Old 07-26-2011, 03:06 PM   #39
grambles423
Limited Activity
I'm got the Neuspeed Sports. I'll probably just stick with those. It it all gets too annoying, I'll just slap the stockers back on.
I appreciate it. I try to stay confidential, but diving into specifics of what OEMs do really make me wanna break that confidentiality and tell all secrets. If ever anyone...ANYONE offers you all a position in the automotive field (More so with an OEM) take it. My love for cars took me down a road early in my life, and I NEVER thought I would be so deep in the company today.
Its hard though, owning a vehicle your company doesnt make. Its not really shunned, but more so people ask, why the hell didnt you buy a *****??? Because, my love for the GTI started back when I drove a MK2 GTI when I was only 11-12, then was exemplified when I drove my buddy's MKV a few years back. I'm know as the "traitor" lol but I destroy almost every car in the parking lot with just a stage 1.
Old 07-26-2011, 03:13 PM   #40
Bender
Bender's Avatar
This thread might shed some additional light, at least in terms of characteristics of certain components.
http://www.golfmkv.com/forums/showthread.php?t=26766
Old 07-26-2011, 08:41 PM   #41
D Darko
D Darko's Avatar
Drives: '10 GTI: Black/4dr/6spd/Dynaudio
THIS is the kind of thread I joined the forum for...Thanks for posting this type of info gentlemen. Keep 'em coming....
APR Stage II v1.2, APR Downpipe, Carbonio (w/Modshack support), Southbend DXD Stage 2 Endurance (Revised and Cryo'd), Peloquin LSD, Tyrolsport Deadset Kit, BSH Insert & Pendulum, Dieselgeek Short Shift Kit, APR/Hotchkis Sways F/R, Unibrace UB, p3cars Digital Boost Gauge, OEM Rev 'D' Diverter, OEM 9w7 Bluetooth, OEM LED R Tails, Smoked Sidemarkers, Tint (35/50)
"Why are you wearing that stupid man suit?"
D Darko is offline   Reply With Quote
Old 07-27-2011, 09:27 AM   #42
Bender
Bender's Avatar
Can one assume that a high-quality coilover has properly paired springs and dampers (an H&R for example)?
I know they might not be properly paired to our suspension, per-say, but at least engineered together?
