Old 08-06-2011, 01:43 PM   #1
06gsxr1000
06gsxr1000's Avatar
Drives: 2011 GTI Autobahn; 2006 GSXR 1000
Stage 1 ----> Stage 2 GET RID OF JERK?
It is very hard to keep the jerkiness down in stage 1+... I have stage 1 tune and full APR CAI...is it the clutch? the car? or just the tune? Does stage 2 balance that out??? It feels to the passanger like Idk how to drive stick!!! I have to slip into every gear (TEARING UP MY CLUTCH) i have to rev match while gliding my clutch so it doesnt jerk... I cant just shift, like I would a normal car (at lower rpms) Its like the jerk is there right when Im about to shift. If I go up to 3.5k-4k RPM's it is fine, but im trying to not drive it all the time in high rpm's! I know i am tearing up my clutch by doing this but I hate the jerky feeling! Or am I tearing up my clutch? I am getting my TBE wed, and the stage 2 flash... will that get rid of the jerk?
Thanks in advance for all the help guys!!
Im on my phone so I appologize in advance if there was a thread on this already, It sucks searching from my phone
2012 Kawasaki ZX-10r
2011 GTI Autobahn 6-MT (APR STAGE 2)
2006 Suzuki GSXR-1000 SOLD
2006 Dodge Dakota SLT 4x4
http://www.golfmk6.com/forums/showthread.php?t=18689
06gsxr1000 is offline   Reply With Quote
Old 08-06-2011, 03:02 PM   #2
fredf
That's not the tune doing that.
2011 6MT
Old 08-06-2011, 03:26 PM   #3
SFvalleyGTi
Drives: Now: 135i SOLD: '11 CW GTI
I got the same problem... Issue is probably the driver.
SFvalleyGTi is offline   Reply With Quote
Old 08-06-2011, 03:46 PM   #4
06gsxr1000
06gsxr1000's Avatar
How can it be the driver... its because of the sudden take off... feels almost like im pressing a nitrous button! hahaha its weird! the sudden burst of boost makes for a jerky ride, and when i shift around 2500 when that boost kicks in it happens.. if i draw out the rpm's to around 4k it is fine.. care to explain how it could be me so i can correct myself! haha i have been driving sticks for years
Old 08-06-2011, 04:20 PM   #5
SFvalleyGTi
Drive faster or driver slower... avoid that certain rpm range. I guess it is not the driver... I got the same issue but I'm fairly new to manuals.
Old 08-06-2011, 04:44 PM   #6
lalalaprise
Drives: 2013 CW Wolfsburg GTI
Are you flooring it right before you shift? There is a surge of power at about 2500 RPM so if you are flooring it right to 2500 and than shifting I could see how there would be a problem....try and be more gentle with the throttle...or shift at 2000 instead of 2500
lalalaprise is offline   Reply With Quote
Old 08-06-2011, 06:57 PM   #7
HarryNipples
Drives: 2010 Tornado Red GTI
Turn off your air conditioner.
HarryNipples is offline   Reply With Quote
Old 08-06-2011, 07:17 PM   #8
4D17HY4
4D17HY4's Avatar
Drives: 2011 Candy White GTI 4dr 6spd
AC on makes it worse. And yes it comes on at 2800RPM or so. I don't like it at all because when I shift around 3K ish (by sound of motor) the surge comes on for half a second then i'm shifted, which makes it very jerky (I'm APR Stage1 by the way)
So to reiterate the OP's question, does the step function in torque smooth out with Stage2?
'11 GTI - 4dr - 6spd - APR Stage1 - Neuspeed Intake - Muffler Delete/4" Magnaflow tips - NSP Mech Boost Gauge - Re-badged and red pinstriping all around - Yellow tinted fogs - Interlagos rear badge insert
<a href=http://i81.photobucket.com/albums/j239/rattlesn_ak_e/GTI%20stuff/Avatar_GTI.jpg target=_blank>http://i81.photobucket.com/albums/j2...Avatar_GTI.jpg</a>
4D17HY4 is offline   Reply With Quote
Old 08-06-2011, 07:24 PM   #9
seaborno
Drives: 2010 GTI 6MT APR Stage 2
I would say no. It's the same, and honestly, in 93 mode it's harder to drive smoothly that the Stage 1 tune.
I have found that the secret is moderate throttle right through the 2800 RPM surge and shift out of first at 3500. If you're trying to shift at 2900 it gets jerky and if you shift before that there's not enough power to get going properly.
APR Stage 2 v1.2 : APR Carbonio Intake Stage 1 : APR 3" TBE : APR FMIC : P3 Digital Gauge : VAGCOM : 35% Tint : Eibach Pro-Kit : Koni FSD
seaborno is offline   Reply With Quote
Old 08-06-2011, 07:24 PM   #10
06gsxr1000
06gsxr1000's Avatar
Yes def does make it worst... ac off make it a little better and easy to deal with... when the ac is on the it f**kin blows! so anybody have an answer if stage 2 levels it out?
Old 08-06-2011, 07:27 PM   #11
seaborno
See above your last post. I think we posted at the same time.
Old 08-06-2011, 08:01 PM   #12
allset
allset's Avatar
do u mean jerky from the tourque the car makes b/c stage 1 is real jerky. Stage 2 smooths it out and widens up the power band. Not as poppy.
If this is happeneing as u release the clutch it could be the throw out bearing. U notice any noises when u let out the clutch, esp under load or on hills?
Old 08-06-2011, 08:09 PM   #13
06gsxr1000
06gsxr1000's Avatar
Yes, like a crinkling type of noise... Car only has 9100 miles though
Old 08-06-2011, 08:10 PM   #14
06gsxr1000
06gsxr1000's Avatar
Best way to describe it though is like a rough shift like driving with somebody who is just learning stick lol
