Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Off-Topic Discussions > General Car News and Discussions
Old 10-11-2009, 10:42 PM   #1
TheShow
Drives: 93 Golf 1.9diesel
1.9 diesel boost gauge and tach
Hi, im trying to intstall a boost gauge and a tachometer in my 93 golf. It has a 1.9 turbo diesel.
I have no idea where to start with the tach. I would like any information anyone has about where i put the wires and all that stuff.
For the boost gauge ive been told to put the line on either the exhaust manifold or past the turbo on the exhaust then tap into the line coming from the intake manifold to the fuel pump. Im not sure which way is best to do so some tips would be apprieciated. Some pictures on either the tach or boost gauge showing places would be awsome to.
Thanks
TheShow is offline   Reply With Quote
Old 10-12-2009, 02:42 AM   #2
Bugsy_Malone 666
Bugsy_Malone 666's Avatar
Drives: mk6/mk3 Golf/beetle/Camper all VWs
Location: In the South, near the hells mouth called basingstoke
Send a message via MSN to Bugsy_Malone 666
I think importantly its the fact you have joined golfmk6.com not mk3.
you should try vwaudiforum.co.uk or vwdiesel.com .
however in answer to your question, on diesels you need to have a specific type of rev counter for diesels, its possible to rewire a petrol rev counter depending on make (theres a thread on vwdiesel.net I think) and then you have to actually have the output from your alternator (theres an actual connector, you either have it or you dont.
as for boost gauge, it works on manifold pressure, theres a vacuum/boost line that runs from the diesel pump to the inlet manifold over the rocker cover, itso nly about 3mm pipe but you should be able to put a T-piece in there to get a boost reading * I think *
"Its just like a golf"
Bugsy_Malone 666 is offline   Reply With Quote
Old 10-13-2009, 02:50 PM   #3
TheShow
okay thanks alot
Old 10-13-2009, 04:23 PM   #4
GTI2007
GTI2007's Avatar
Drives: Golf 5 Plus TDI
Moved.
GTI2007 is offline   Reply With Quote
