Old 08-10-2011, 08:31 PM   #1
(. )( .)'s Avatar
Drives: Slow
Brake Change Problems sighhhh
So i'm trying to change my rear brakes and I'm encountering a problem pushing back in the cylinder (into the caliper to make room for the new pads). I'm using the proper tools, I just can't seem to push the cylinder back in.
Any suggestions?
Thanks guys.
(. )( .) is offline   Reply With Quote
Old 08-10-2011, 08:39 PM   #2
Krazy_Z
Krazy_Z's Avatar
Drives: 2011 GTI CSG 6MT
Send a message via MSN to Krazy_Z
You need a caliper wind in tool. You can rent one from auto zone.
If you haven't seen the future, You haven't driven fast enough
Krazy_Z is offline   Reply With Quote
Old 08-10-2011, 08:49 PM   #3
Ricky Bobby GTI
Ricky Bobby GTI's Avatar
Drives: 2010 CW GTI
Alot of the new brakes actually screw in so I would try that instead of trying to push the cylinder in.
2010 CW GTI
Ricky Bobby GTI is offline   Reply With Quote
Old 08-10-2011, 08:55 PM   #4
Y34RZ3R0iscoming
Drives: 2002 E46 M3 (CSL conversion)
Location: Bakersfield California (Formerly from Alaska)
Any suggestions?
Thanks guys.
We have to squeeze them with bigass pliers, or put both pads in and put a screwdriver in between them with the tip on the hub-side pad, and use the screwdriver like a crowbar to depress the piston
Y34RZ3R0iscoming is offline   Reply With Quote
Old 08-10-2011, 09:00 PM   #5
(. )( .)'s Avatar
Drives: Slow
I'm using the caliper wind in tool, and it just won't depress at all.
Old 08-10-2011, 09:09 PM   #6
andylaiphoto
andylaiphoto's Avatar
well tits!
Andy Lai
Commercial Photographer
http://www.andylaiphoto.com
http://www.crossfit972.com
andylaiphoto is offline   Reply With Quote
Old 08-10-2011, 09:15 PM   #7
Ricky Bobby GTI
Drives: 2010 CW GTI
Did you remove the cap off the fluid and make sure there is room for the fluid to return? Just a shot in the dark!
2010 CW GTI
Old 08-10-2011, 09:19 PM   #8
(. )( .)'s Avatar
Drives: Slow
yep. -_-
Old 08-10-2011, 09:45 PM   #9
Y34RZ3R0iscoming
You shouldnt have to do that. I never have. not saying ur wrong, its just a step ive never had to do..
Old 08-10-2011, 10:52 PM   #10
(. )( .)'s Avatar
Drives: Slow
yeh i can't get any movement at all from the piston so i'm towing it into my mechanic tomorrow. what a bummer-_____-
Old 08-10-2011, 10:53 PM   #11
RacingManiac
RacingManiac's Avatar
E-brake is disengaged?
Old 08-10-2011, 11:00 PM   #12
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
try using a C-clamp?
Old 08-10-2011, 11:05 PM   #13
(. )( .)'s Avatar
Drives: Slow
E-brake is disengaged, and C-clamps get less grip than the actual tool.
There is a picture of the fail. Underneath the rubber seal is the piston, which is not budging.
Old 08-10-2011, 11:28 PM   #14
Killswitch24
Drives: 2015 Golf R
Can you get the tool to rotate the piston? If not, the piston may have come out too far and got seized. That can happen if you wait till your pads are worn to the backing plate. If it does rotate, there must be pressure applied to the piston to actually push it in as it rotates. That's why you need to proper tool (which it looks like you do). Good luck!
2010 United Gray GTI 2dr | APR K04 SOLD
2015 Limestone Gray Golf R | No mods necessary...
Killswitch24 is offline   Reply With Quote
