Old 08-10-2011, 11:30 PM   #15
Stevec717
Stevec717's Avatar
Drives: 2011 VW GTI MKVI
It looks like the piston is hyper-extended. Did someone possibly step on the brake once caliper was off the rotor? If the piston has come out, you'd have trouble.
Steve
2011 CSG GTI w/ Sunroof & Navi - Stage 2 APR, Custom VMR 710 Wheels, BSH Race Intake, UR Downpipe, New South Boost Gauge, 3M Tint, Lamin-X Markers, Hoen H8 HID Match Fogs, Hatch Lift Kit, LED Interior Lighting.
Stevec717 is offline   Reply With Quote
Old 08-10-2011, 11:55 PM   #16
(. )( .)'s Avatar
Drives: Slow
The tool can't rotate the piston at all. And yeah I think it may be seized.
(. )( .) is offline   Reply With Quote
Old 08-10-2011, 11:55 PM   #17
(. )( .)'s Avatar
Drives: Slow
Thanks for the advice. It's getting towed to my mechanic tomorrow morning.
Old 08-11-2011, 12:45 AM   #18
RACER00
Drives: 2010 Candy White 6-manual
As a last ditch effort I would use a channel lock to pinch off the brake line, disconnect it from the caliper and remove any park brake cables, and with the caliper now free of the car, put it in a vise and try to turn the piston back in, there would be no pressure to resist it going into place, even if the piston came out too far you should be able to move it in. If no luck you should be able to take the caliper to brake shop and avoid having to tow the car. I have had this happen on one of my Mustangs (very simular caliper) and just having the caliper off the car made it easy to work on. When you reinstall the caliper and brake line then remove the channel lock and then just bleed out that caliper. Some times there is a rubber o-ring on the piston and if it comes out too far the the o-ring will come out of the groove and keep the piston from going back in, also the seal/boot can come out of its groove and be the cause for the piston not wanting to reset. Good luck and just go slow and it will work out, or in as it may do.
RACER00 is offline   Reply With Quote
Old 08-11-2011, 06:11 AM   #19
Krazy_Z
Krazy_Z's Avatar
Drives: 2011 GTI CSG 6MT
Send a message via MSN to Krazy_Z
The wind in tool I was refering tool actually screws the piston in. The piston will come oou nice and smoothly but is required to be screwed in to retract it. the tool you used in the picture is for the front calipers. I would try to give this a go before having it towed.
If you haven't seen the future, You haven't driven fast enough
Krazy_Z is offline   Reply With Quote
Old 08-11-2011, 10:35 AM   #20
Killswitch24
Drives: 2015 Golf R
The tool in the picture is correct for the rear.
2010 United Gray GTI 2dr | APR K04 SOLD
2015 Limestone Gray Golf R | No mods necessary...
Killswitch24 is offline   Reply With Quote
Old 08-11-2011, 04:10 PM   #21
(. )( .)'s Avatar
Drives: Slow
Thank gawd for AAA.
Old 08-11-2011, 04:25 PM   #22
DBESTGTI
DBESTGTI's Avatar
Drives: 2011 Stage 2 GTI
As a Volkswagen technician I can confirm that, that is the correct tool.
